Question about Aprilaire 1120 Humidifier
My water never stops running into Aprilaire 112
When furnace stops and Aprilaire is off water keeps coming
  • 189 Answers
Disconnect the two yellow wires. The water should stop. If it does you have a bad (or miswired) humidistat. If the water does not stop the solenoid valve is bad. These valves are known to be expensive. You might want to consider replacing the whole unit.
Good luck
HVAC Teacher
Posted on Mar 08, 2009
Aprilaire 700 water never shuts off
the float may be bad or sticking allowing water to run continusly even when unit is off.
Nov 06, 2013 | Aprilaire 700 Humidifier
Is Aprilaire 500M suppose to turn on when furnace motor turns on?
The humidifier should turn on and off with the blower motor of the Furnace. This can be done by wiring the the humidifier to the HUM terminal on the furnace control board and then stepping down the power with a transformer. If the humidifier has it's own tarnsformer then a current sensing relay can be used by attaching it to the blower motors common wire.
Jan 13, 2013 | Aprilaire Humidifiers
Aprilaire 500 water won't stop running down to condensate pump
Hello, sounds like rhe solenoid valve is stuck open. This will keep water flowing through the humidifier even if the Furnace is off. The solenoid valve will have to be replaced.
Dec 01, 2012 | Humidifiers
House is dry though it's quite cold outside and furnace is running. Aprilaire is turned up to 35 (I have a dial, not a digital panel). the water panel is completely dry (should it be?)
unless the humidty in your home is higher then 35%. if it is then the humidifier would not run. try turning it up higher and see if it comes on. Do you hear a click in the humidistat? as you turn up the dail when you hear the click is when the humidifier should come on. Also remember your furnace must be running for the humidifier to come on. if you hear the click and the humidifier fan comes on but no water, you may have a clogged inline filter located in the solinoid valve or a bad soliniod. all parts for your humifier can be purchased from
Feb 05, 2010 | Aprilaire 700 Humidifier
I have an Aprilaire 550 hooked up to my furnace,
in order for the humidifier to come on with the heater there has to be a temperature sense curuit to turn it on/off at a certain temp, the humidity curcuit on the unit will turn it off at set %
Jan 31, 2010 | Aprilaire 550 Humidifier
Aprilaire 600 humidier: water continuously runs
sounds like you may have it wired to a continuous power source vs one that shuts off with the furnace. The most common wiring is red to C & white to W
Jan 08, 2010 | Aprilaire 600 Humidifier
I have a aprilaire 112. How do you test the solenoid valve to determine if it working properly?
without using a meter? OK take the water line loose from the humidifier that connects to the solnoid. Turn the humidifier on or raise the humidity and water should flow. Keep in mind that if wired correctly the humidifier will only work when your furnace is running although some can be wired to bring on your furnace. You should hear or feel the click if no water comes out you may have no water flow as these valves are pretty durable and seldom fail
Dec 11, 2009 | Aprilaire 700 Humidifier
Aprilaire 600 bypass water flow rate
The water is only dispensing over the evaporator pad while the furnace is in the heating mode. When the furnace finishes cycling the humidifier will also stop.
Mar 04, 2008 | Aprilaire 600 Humidifier
Aprilaire 110
Modle 110 has a relay in it see if it is stuck.Hope this helps
Nov 05, 2007 | Aprilaire 600 Humidifier
Aprilaire 760 Humidifier water continues to run
You need to determine whether the problem is in the solenoid or in the furnace electronics. You could put a voltmeter on the solenoid connection to see if the furnace is still holding the solenoid open after the blower stops. This will tell you whether it is the solenoid or not.
Feb 18, 2007 | Aprilaire 700 Humidifier
Humidifiers Logo
505 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
