Question about Canon PowerShot SD1100 IS Digital Camera
How to repair lcd screen canon powershot sx110-is
Hi,canon powershot sx110 is cracked lcd screen need to see how to replace it .can you help ?thanks, jeff
  • 47 Answers
Http://digitalcamerarepair.googlepages.com
Posted on Mar 04, 2009
I have a digital camera that keeps telling me to reinsert memory stick
Posted on Feb 19, 2009
2 Suggested Answers
kram26
  • 544 Answers
SOURCE: how to repair lcd screen canon powershot sx110-is
hi,
For that camera that died, here are some non-intrusive simple fixes that you should try before throwing in the towel. Copied this first post from somewhere. It was a fix for a Canon A520, but am not sure if it would work for other cameras with the same problem? For those of you with a camera that will not power up or turn on, especially if this occurred after a power interruption with your lens extended, please give it a try. If you do, please leave a comment on specifics like your camera make/model, and whether it worked for you or not.
"DEAD CAMERA, LENS OPEN-If the batteries run down completely while the camera is still open, it may not start up again when new batteries are installed. But if you remove the memory card, then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time."
OK, so the above didn't work. Next thing to look at are the batteries themselves. Are you using alkaline batteries, or worse yet those "Super Heavy Duty" batteries? If so, betcha we've just discovered your problem. Alkaline and regular "super heavy duty" batteries just don't have the power for more than a few pics in a digital camera. Some may even have problems just powering startup of the camera. It doesn't matter if they're new, and right out of the package. Digital cameras for the most part should only be used with rechargeable NiMH batteries (if you still have your instruction manual, open it to the "batteries" section. Pretty sure you'll see a statement similar to what I've just said). Most retailers sell NiMH batteries for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
OK, so maybe those newfangled batteries didn't fix your camera, don't give up just yet. The next thing to check is that your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip.
The next thing to try is examine both the battery and flash card door. There's usually a little switch on both doors (note some SD card doors do not have this switch) that activates when the doors are closed. If they don't, the camera won't start to prevent damage to the flash card or camera startup sequence. For most cameras its usually a little piece of plastic on the door that pushes in on a pin switch when the door is closed. Closely examine both doors to try to identify these switches. A lot of times that little plastic nib wears down or breaks off, but can easily be jury rigged with a small glued-on replacement.
If you've tried all of the above and still no luck, the problem is then likely to be internal to the camera. Am planning on posting sometime in the future some likely things to check, hopefully with a pictoral guide. One example would be that if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
As before, if one of these simple fixes worked in your particular case, please leave a comment on your camera's make, and which fix worked.
Good Luck!
Camera Repair please don't forget to rate our answers..
CANON SX110 DIGITAL CAMERA
sounds like a LCD fault could be just a ribbon cable connection. If double checking your batteries are good and removing the mem card has no effect then it may have to go for professional service.
Dec 02, 2011 | Canon PowerShot SX110 IS Digital Camera
How do I remove the back from my Canon SX110IS? I have removed the 2 screws on the back above the lcd, one each on L and R of case, 2 below screen, one 1ach in A/V and battery compartments, but the back...
There are TWO screws on the right side, one is hiding under the cover for the USB connection!
Now you should be able to pop it off and... I'm guessing here... replace your cracked LCD screen. Good luck, hope this helps.
Thomas Drayton
Owner www.darntoothysam.com
Affordable Digital Camera Repair
Aug 03, 2011 | Canon Powershot SX110 IS Digital Camera...
Looking for manual / or instructions for PowerShot SX110 IS
Click Canon Support to download user manual copy for SX110 IS camera.
Hope this will help you.
Thanks.
Apr 04, 2010 | Canon PowerShot A75 Digital Camera
I have lost my manual for my Canon Powershot SX110 IS. Until I replace the manual, can you tell me how to delete pictures from the camera after I have uploaded them? Thank you!
Sure. The fast way is to format the memory card. As soon as you are SURE all your pics are downloaded, disconnect the camera and do a format. Fast and painless. Its good to format a camera occasionally anyway. No error checking. Even Locked photos are erased!!
Nov 08, 2009 | Canon Powershot SX110 IS Digital Camera...
Connection of Canon Powershot SX110 IS to computer
Blame Microsoft updates. Try using a card reader to download your pics to a folder you create on your desktop.
Oct 23, 2009 | Canon Powershot SX110 IS Digital Camera...
My fiancee's a650is lcd is cracked and cam wont work
If you do a Google search for 'digital camera parts' the first listing is a website that can help you. The LCD repair package is $72 with return shipping of the camera to you.
The website name is: Darntoothysam com, then search by "A650" and you will see it.
How do I know this? I own the business, that's how. We specialize in LCD and lens repair for affordable prices. If we can help please let us know.
Thomas D.
Owner, Darntoothysam com
May 29, 2009 | Canon PowerShot A650 IS Digital Camera
I crushed the screen of my Canon Powershot SD450 camera. Pls. estimate cost of screen repair. Is it on the screen thats cracked cozi can still take photos but cant see them.
Many screen breaks happen to ruin the LCD from visibly displaying a picture. On some cameras, the screen is attached to the back plate of the camera and are very easy to replace with a new one. Some screens are attached to a video pc board and may ruin the board from displaying anything. Your best bet is to have it repaired professionally by one of our top repair providers and get an estimate first. I have repaired many good digital cameras with a LCD replacement, but I also had to purchase a broken used one for parts because new parts became to expensive to repair the one with a broken LCD. BTW: all digital cameras contain many PC boards and if you can still take pictures means the boards that control your lens, motors, CCD, and I/O boards are still intact and functional. Hope this helps - fotobean
Feb 20, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
My a590 digital camera has lines on the lcd display after it banged on the counter
Hi There, If your screen still lights up, the LCD panel is probably cracked. Take to shop for estimate: Around $120.00 for repair.
Thanks, mr cicmo
Dec 26, 2008 | Canon PowerShot A590 IS Digital Camera
Cracked lcd
Well, there is a Powershot A520 on eBay right now that has a good LCD screen but does not work. It would be a good deal since a new part may be fairly expensive. Item number: 160196261124. You will need a good cross point screwdriver and tweezers to make this repair
Jan 13, 2008 | Canon PowerShot A520 Digital Camera
Nothing displays in LCD screen, canon powershot S400 digital ELPH
Sounds like your LCD might have gone bad. The LCD might cost more than the camera costs, but there are a few places on eBay that you can buy a repair and replacement service from for pretty cheap.
Nov 01, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Canon PowerShot SD1100 IS Digital Camera Logo
891 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
