Question about Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Rangemaster 110 gas grill flame
My 10 year old Rangmaster natural gas 110 grill performance has deteriorated over several weeks although it will still ignite, as it becomes hotter it also becomes increasingly noisy (popping/spluttering), eventually making a loud popping noise before extinguishes itself altogether. Have noted this problem (Rangemaster 110 grill flame) was raised by (bvincent1) and answered (as2871910) and given a fix status, unfortunately of the two solutions offered no indication as to which one proved to be the answer was given. I have however carried out the test suggested for possible problem with the regulator and only a very small reduction flame size was noted (should there be none at all ?). Too much air would seem to fit the symptoms better and would greatly appreciate more detail on how to achieve the reduction suggested .
  • royen May 02, 2009
    how do you remove the grill burner rangemaster110 ng
  • mark_moloney May 11, 2010
    How do you clean it
    Problem Solver:
  • 10 Answers
Your burners are not burning good because they need to be cleaned and the loud popping noise is the gas burning in the ventury until it burns it self out its a very common thing
Posted on Feb 20, 2009
Rangemaster 110 on lpg wish to convert to natural gas
You must get a tradesman or technician who is qualified to convert a gas appliance, your local gas fitter or plumber should be able to help with this. the regulator needs to be changed the jets also need to be swapped out for the type of gas to be used. normally from lpg to Natural gas the jet size needs to be increased by installing new jets or by drilling out the old ones
Hope that helped
Oct 22, 2013 | Rangemaster 110 (Gas) Kitchen Range
The gas flames on the hob don't come on fully - they seem very low
Hi what gas are you using? is the appliance suited to the gas, it seems as tho the appliance is jetted for LP gas & you are trying to run it on Natural gas
Oct 21, 2013 | Rangemaster 110 (Dual Fuel) Dual Fuel...
I have a Rangemaster Leisure 110 the left hand oven lights up, but the flame is very low and will not go to maximum.
common problem, there is a device in the oven called a solenoid/ff device these are safety devices and fail after a few years. replacements can be obtained from main stockist Gas On spares on 0121-585-7799
Apr 04, 2011 | Rangemaster 110 (Gas) Kitchen Range
I have a leisure rangemaster 110 double gas oven the left oven stays low i have tried cleaning jets but this has no effect can you suggest a cause
the flame safety device need replacing (FFD)... this lets the full gas through when flame is sensed... safety 1st as a gas engineer will be required..
Dec 18, 2009 | Rangemaster 110 (Gas) Kitchen Range
Grill Element Blown Rangemaster Classic 110
I have the same problem. The installation and service guide details how to change the grill element but does anyone know what the part number is for the grill element?
Apr 01, 2009 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster gas grill - little or no gas pressure
you can phone rangemaster helpline on 08707 895 107 spare parts or tech team.
Feb 26, 2009 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110 grill flame.
to find out if the regulator is good or bad, turn any of the burners that do not have the problem, one at a time but take a close look at the flame and see if the flame goes lower and lower as you turn a second burner and a third and the fourth one, if the flame goes lower and lower the regulator is bad. but if the problem is with just the grill one , it has to much air, you can turned down the air where the burner meets the valve that supplies gas to it the burner has a vent, it needs to be close a little bit, you can close it little by little and testing the burner on the on position until the splutter goes away.
Dec 11, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Gas oven
Its the flame failure device faulty (FFD)
Nov 30, 2008 | Rangemaster 110 (Gas) Kitchen Range
Left hand oven not getting hot!!
some older ovens did use one side just as a "bread warmer"...only way to tell for sure is to check if there is a burner below the left side
Jun 02, 2007 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
1,067 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
