Question about Sony CDP-XE500 CD Player
My Power Button is pushed all the way in, can I repair it myself?
Sony Compact Disc Player CDP-XE500 Power Button is pushed way back in and I was hoping to try and fix it myself. Is that possible?
  • 10,594 Answers
Below is an exploded view of Power Switch and board section and I hope will help you to fix power button issue.
My Power Button is pushed all the way in, can I re - 2e010a8.jpg.
Power switch board has one screw to open it and you will remount power button and put back in power board in unit.
Posted on Feb 19, 2009
Sony CDP CX205 200 CD compact disc player does everything except play CDs. .
sound like you need to clean the laser reader inside get you self a lense cleaning disc.
Dec 14, 2016 | Sony Televison & Video
Compact Disc Player CDP-CX300 not reading discs
Probably have to get the laser replaced as long as all the mechanics are working to load the disc.
Jan 02, 2013 | Sony CDP-CX300 CD Player
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
My cdp-455x is showing a loading error after the lazer being cleaned
The laser eimission might have stopped. The laser pickup unit [optical pickup unit] should be replaced.
Apr 17, 2012 | Sony CDP-D11 1U professional compact disc...
My Sony CDP-C910 cycles through CDs, never playing
when its cycled thru them .,does it stop?does it show them on the screen with a lit circle?are they normal cds.can you select one cd to play?hold the eject button in for about 5 seconds,see if that resets it
Jul 11, 2010 | Sony CDP-C910 10-Disc CD Changer
Disc(s) jammed in sony 5-disc player--eject won't work
There are 6 or 7 phillips head screws that keep the top on; remove them and pop the top. This will give you access to all CD's. Remove them all, then plug the unit back in and press the open close button and check for normal operation. If it still wont open, it's broken a gear and needs to be serviced. You may consider replacement of the unit if inoperative, the replacement model is priced at $129.00 and a repair would probably cost the same if not more. If you need further help, post a comment and I can help you further.
Dec 22, 2009 | Sony CDP-CA70ES 5-Disc CD Changer
Sony CDP-XE500 CD Player Logo
466 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
