Question about OKI C5200n Laser Printer
Oki c5200 paper jam
I have a paper jam from the bypass tray in my oki c5200 printer. I can see the paper but i have no way of getting it out. Help!
I used tweezers after I took every thing that could come out--out.
Posted on Apr 17, 2009
On Oki 330 have error 380 still showing after paper jam was cleared
Make sure everything is clean. Please refer to your manual for cleaning instructions; or download a new manual at http://www.okidata.com/ .
Below are how to clear a jam instructions:
How to remove jammed paper 28/07/2013
Paper handling is key to Ensure trouble-free printing. However, paper jams sometime Occur.
You can improve feeding and Avoid paper jams in your OKI printer, by following these simple steps:
Loading the Paper: When loading paper, fan the stack of paper before placing it in the tray. This will shake out any paper dust and reduce any static in the paper, two major causes of paper mis-feeds.
- Place the paper in the tray under the tabs.
- Do not fill above the "PAPER FULL" mark.
- Guides Adjust the tray for the correct paper size.
Recommended Media: Use paper specified for the printer
When printing on heavy / thick types of paper, it is best to use the manual feed tray at the front of the printer.This will Provide a straighter paper path to Prevent potential paper jams.
Cleaning: Periodically wipe the rubber rollers inside the area That holds the paper tray with a soft cloth.
dust Paper and simple wear may cause these rubber rollers to slip and not feed the paper properly.
Nov 29, 2013 | OKI C3400n Laser Printer
Problem 391 on OKI C5200 printer but no paper jam was found.
Open the top. Pull on the top of the toner cartridge (don't release the latch, just pull it up). It will come up with the toner drum assembly attached. You will probably see another paper stuck there which can't be seen when the drums are installed. Also, open the back door and look for paper that might be stuck. But usually, when you've checked everywhere else, the remaining paper is flat under the toner drums. Once you get it out, just click the drum/toner assemblies back in place (careful not to let the green drum touch anything while it's out of the printer.
Mar 06, 2012 | OKI C5200n Laser Printer
I get a 391 paper jam on my Oki C5200 printer all the time
Hi
Try turning the printer off and on.
Look through the paper paths and remove any visible stuck papers.
Clear any print queues.
Solved?
Disconnect printer from power for a few minutes and then connect it again.
Feb 27, 2012 | Office Equipment & Supplies
Error oki b6100 e2
This error often comes when there an paper jam or paper tray 1 or paper tray 2 or 3 is empty,make sure that you have enough paper in the trays and secondly make sure that you have there is no paper jam in paper roller, even an tiny particle of paper can cause this error.
Please open all the access of your printer pull out all the paper trays and clean it properly with air blower, this can fix this error.
Sep 02, 2011 | OKI C5400 Laser Printer
Replaced the belt and fuser on a oki c5200, now paper gets jammed and accordians in fuser
This will happen if the belt isn't properly settled, so that the sheet of paper enters at a slight angle and jams. The roller loader will then fold it into an accordion shape.
While I don't understand how the printer let you print (the sensor should have raised an alarm), you could try extracting the belt unit and re-settling it. Verify the blue retainers have been fully rotated (one eighth turn clockwise) and the handle is completely down.
Nov 06, 2009 | OKI C5200n Laser Printer
Oki c5250n paper jam
Unfortunately this may require and engineers visit. If you pull down the MP assembly by using the handle in the middle at the front of the printer you can then see a small "gearbox" at the right hand side of the transfer belt. This is common to feeds from both trays and could be worn. If you remove tray 1 and temporarily tape up the sensor arms to fool the printer into thinking it has a full tray installed, you can the test, by applying a little pressure to the feed roller, to see if it positively moves forward or if you are able to stop it turning. On a brighter note, you may just need new rollers instead of cleaning them.
Apr 14, 2009 | OKI C5250n Printer
Oki b6200 paper jam
Have you checked to see if there is any paper jammed in the sensor, at the back in the 150-sheet feeder assembly, if not the paper could be stuck the 150-sheet assembly
Feb 26, 2009 | OKI B6200 Laser Printer
Oki c5200 printer driver for MAC
I also need a driver for my Oki C5200 laser and Mac with OS X Leopard. HELP.
Apr 17, 2008 | OKI C5200n Laser Printer
Error 391: paper jam
See below for Error 391:
CLEANING THE FEED ROLLER AND THE PAD
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Pad
Apr 04, 2008 | OKI C5200n Laser Printer
OKI B4100 paper output. Frustrating!
If your oki is like the 4300 we use it may be as simple as making sure the extention for the back tray (where the paper is printing to now) is pushed all the way in. This actually selects the tray option. If this tray extention is pulled out at all, your printer will print to the back tray.
Oct 25, 2007 | OKI B4100 Laser Printer
OKI C5200n Laser Printer Logo
311 people viewed this question
Top OKI Office Equipment & Supplies Experts
Soulvisitor
Soulvisitor
WTF Chuck.....
WTF Chuck.....
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
