Question about Gigabyte Computers & Internet
Computer loses power and won't start
I have 2 custome built computers that some one give me because they upgraded. they are both the same. they both have gigabyte boards 3 gig processors 120 gig hard drives. some times they will power up and sometimes they will not.while i have running they will just stop seems for no reason just shut down. they was used in a small business on a network. i got one to stay on long enough to format and load new operating system, but it still does the same thing.
any ideas thanks john
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 82 Answers
I would check the power supply on both units. If you have a spare power supply swap it out and see if that works first.
I hope this helps.
Posted on Feb 19, 2009
  • Gigabyte Master
  • 4,806 Answers
Hi there.
Its possible that the machines are overheating, take off the side panel and clean the CPU fans and heat syncs.
Get a can of compressed air and clean the dust out of the cases, if you have no compressed air, get a clean, dry, soft paintbrush and a powerful hairdryer, set it to cold air and gently brush the dust away and blow it out with the hair dryer.
I also recommend you take out the system memory and clean the contacts on that too.
Good luck and thanks for using Fixya!!!
Black screen
If you know your monitor works then the likely culprit is the on-board video could be bad. If you can give me the model # of your computer or if it's a custom computer, the model # of your motherboard, I can let you know what kind of video card your computer takes and what brands to stay away from.
Good luck and hope this helps. If it does, please vote! Thanks!
Dec 01, 2013 | HP PAVILION M8200N PC Desktop
I am upgrading my windows server 2003 r2, service pack 2 standard edition to 2008 r2 standard and I received this message;
This is informational: Upgrade is done within Windows, though it will reboot. Booting with installation disc is a clean install. Both look very similar.
Make sure to backup data just in case. Good Luck
Sep 19, 2012 | Dell PowerEdge 2970 Server ( 160GB/2GB)...
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
Parking lights start blinking...won t stop until you disconnect battary or start and shut it off and that last for a little while can any one help with my problem.....thanks
This sounds like an Alarm issue. If you had an alarm added to the vehicle after it was purchased you need to deactivate that by removing the power wire or fuse in the power wire. if that vehicle has the alarm built into the PCM, the vehicle computer, it may just need to be flashed. If neither of those turn out to be the problem the next place to look is the light switch itself or if you have added a device that was wired into the fuse panel for power double check the fuse panel for a lose wire making contact on occasion.
Jul 03, 2011 | 1997 Dodge Caravan
I have dell ax210 -2 speakers....I dont have the driver cd....i want the software...
Your speakers don't require any special drivers. All they do is take the analog sound signal from the computer, amplify it and play it for you. If the sound hardware is working, all you need to do is plug in the speakers. The green signal plug goes into the output jack on the computer, and you need to connect the USB plug to an open port for power. Your computer needs driver software for its sound hardware, though, and if you're trying to solve a "no sound" problem, this may be the cause.
You don't give a make and model of your computer or sound card, so I can't give you a specific link. But you can get the drivers from the computer manufacturer's site. If you have a custom-built computer or are using a separate sound card, you'll need to get the sound drivers from the motherboard manufacturer (if it's integrated sound) or sound card manufacturer.
Dec 16, 2010 | Dell AX210 2 Speakers
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Janome customiser 11000
When you backed up you probably only backed up documents. The executable files that make the program work are in program files and folks seldom back up program files. It was pre-installed on your pc? How weird. I believe the only thing you can do now is to go buy Customizer 11000. Check ebay and the yahoogroup sewitsforsale to see if there are any used copies. It's not an expensive program, and frankly, you don't NEED it if you have Embird, which does all Customizer does plus more.
HTH
May 25, 2008 | Janome Memory Craft 10000
Computers & Internet Logo
37 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
