Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
My Magnavox DVD Recorder with VCR Cassette Recorder MWR20V6 does not take the local DTV Channels only takes the remaining analog channels. Some advice please
Thank you for your email inquiry.
I solved the problem by hooking up a converterbox to the VCR
V Strubel
Posted on Feb 20, 2009
I have a Magnavox ZV427MG9 DVD Recorder VCR Combo. Do I need a separate tuner? If so what kind? Thanks
Hello
Ofcourse you need an external tuner to receive any RF signals. Your Magnavox is not equipped with internal tuner with it. OK.
Apr 21, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have...
I have a phillips magnavox Problem with the Philips Magnavox MWR20V6 DVD Recorder / VCR Combo I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have cleaned the lens with a disc cleaner and still didnt help,same thing is happening. i am also using the same type of disc that I have been since day 1. Can you help??
Mar 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can'y find where to put in channel
First check that when channels were stored that whatever channel you are trying to record is actually stored on the machine. If all other channels are there and the one you want is not I would re scan and re store
Feb 12, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How do I RECORD FROM A CAMCORDER TO THE DVD SIDE OF THE UNIT
  1. Connect the camcorders yellow, red, and white (Audio/ Video) to the input on the back of the combo called AV1 or Video 1.
  2. Then turn the channel on the DVD recorder to AV1 or Video 1. (A couple channels down from channel 2)
  3. Make sure camera is in VCR mode and hit play on camera
  4. You should see your camera video on your TV and rewind to the place you want to start recording and hit stop.
  5. Put an empty DVD in recorder and hit Rec. Button (usually red)
  6. Then hit play on your camcorder until you would like to stop
  7. Then hit stop on your DVD recorder and each section like this will be another chapter.
Good Luck
Oct 09, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Vcr tape plays for a few seconds then powers off
remove cassette mechanisum and clean all the sensor's
Sep 28, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Electronic ILLITERATE!!! - nothing recorded from cable tv channel
okay, if you have a cable box (cable out plug to dvd/vcr in), then from the dvd/vcr (cable out plug to tv/monitor). make sure tv/monitor and dvd/vcr are set to ch #3. you swith channels with the cable box ,you are not going to be able to record HBO on dvd (but you can with the vcr), any other cable ch(tnt, history, tbs,we, oxygen and more) is recordable w/ both dvd/vcr
no cable box. take cable wire plug to dvd/vcr in, than other wire is connected to tv/monitor
now go to dvd/vcr with remote, menu, set to catv, scan channels. now when you wish to look at tv the dvd/vcr must be on at all times. again you will not be able to record Premium ch like HBO
hope this help............pls feel free to rate
May 14, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dont know how to finalize dvd after recording on magnavox vcr/dvd
You can find a copy of the manual on the web link provided here:http://tv.manualsonline.com/manuals/mfg/magnavox/mwr20v6_1.html Print a pdf copy for yourself. If you need more help the customer care for you dvd/vcr player is at this telephone number. 1-800-605-8453 give them the model number of your dvd/vcr unit and they will be able to help you. I hope this information helps you with your problem.
May 10, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Channel selection
L1 and L2 are just line inputs. This unit does not have a tuner so there are no channels to select.
It requires you to be connected to a TV broadcast via a cable or satellite tuner box... and then would only record what ever channel you were viewing. The DVD is a player only.
It sounds like you should have purchased a DVD Recorder or a DVD/VCR Recorder. The players normally do not have a tuner. A Recorder should have an built-in digital tuner. Some also have the old NTSC tuner and may also have a QAM tuner.
Nov 12, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
My vcr won't play back
I have a Magnavox zv457mg9 DVD&VCR combo ,and the vcr records for a short period(10minutes) and then cuts off. This happens each time I try to record on the VCR. Any suggestions??
Feb 26, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Finding a code
Look under Funai with dish network.
Nov 19, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
