Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Control lire have a kenmore quiet pak 2 h e 3 control lite is on unable to use the unit can u help
  • 15,935 Answers
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
Kenmore quiet pak 1 heavy duty king size front loading dryer is not heating up, but is tumbling fine. Desperately seeking manual.
Go to www.repairclinic.com and enter the model. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Kenmore video showing disassembly.
Nov 24, 2017 | Washing Machines
Can wash my clothes washer is giving a f1 announcement and stops.is a kenmore elite oasis model 110.27032602 quiet pak 2.thanks
The F1 error code means that the control board has a detected a problem within the control itself and the control board would need to be replaced.
The part number for that control board is W10189966 it could be picked up at your local appliance parts store or online at;
searspartsdirect.com
apwagner.com
partselect.com
apdepot.com
repairclinic.com
GENE
Oct 12, 2011 | Kenmore Oasis HE 27082 Top Load Washer
I have a Kenmore Elite Heavy Duty King Size Capacity quiet pak 1 that is not heating up what could the problem be?
Jan 13, 2011 | Kenmore Dryers
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Mcu and ccu
MCU = Motor Control Unit. A control board that is located in the rear of the washer at the bottom adjacent to the drive motor. Remove the back panel for access.
CCU = Central Control Unit. A control board that is located directly behind the wash tub. This is the main "brain" of the washer. You can access by removing the washer top panel.
Jun 30, 2009 | Washing Machines
I have a Kenmore Elite Quiet Pak 4 HE3T Washer. The door is locked with clothes in it. The displays is saying F dL. What has happened and how can we open the door.
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes / Procedure
• Door lock mechanism is broken or removed from door.
• Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Apr 12, 2009 | Washing Machines
How do I remove the bottom panel from the Kenmore Elite Quiet Pak II dryer? I need to vent the dryer from the bottom rather than from the back of the unit.
hi. thanks for the question . 2 screws on the bottom of the front panel .remove these screws . pull on panel, lift from bottom . thanks the appliance doc. please rate this answer. thanks the appliance doc
Oct 01, 2008 | Kenmore Dryers
Kenmore HE 9t quiet pak
Sounds to me like the Main Computer has failed. F11 means it is not communicating with the Motor control Board. It has nothing to do with the door locks. Remove to lid of the machine to axcess Main control. Sometimes a tap or two on the board makes them work again for a short time. Leave unit powered down for a few mins to reset board.
Nov 24, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
183 people viewed this question
Sal De
fordexpert
Robert Rankin
