Question about Maytag Washing Machines
Spin cycle in regular mode causes severe vibrations
    Genius:
  • 1,239 Answers
Hi
its common belt problem,,,,,,,,check the belt if necessary change it..
thank u,,,,,,,
Posted on Feb 19, 2009
What causes my frigidaire top load washer to vibrate and make rattling noise during spin cycle
There are springs and bumpers/shocks in the machine that hold the tub. When they break or come loose, the tub wobbles.
Jan 03, 2016 | Frigidaire FAHE4044MW Affinity High...
Why doesn't my Maytag washer go into spin cycle?
I would start with the timer module. The spin cycle requires a lot of current (amps) to move the mechanism and load. That current can cause contacts inside the timer to become carboned due to current arching. Try this: wash using a different cycle (permanent press for example). If the spin cycle works in that mode, then there is a 99.999% chance that the contacts are worn out on the regular cycle (if that's what you're using). Lacking a model number, I assume you are using one that has the mechanical timer. Try that and come back.
Dec 16, 2013 | Washing Machines
Maytag LAT8426AAM agitator only works in delicate cycle
Best guess is a timer contact problem, usually caused by advancing the timer by hand without pushing the dial in to stop the machine first.This causes burnt contacts.
Aug 27, 2017 | Maytag LAT2301AAE
LG WM3987HW Washer Spining very wild
I've just uploaded a service manual.
relevant info pasted below: --
Regulate a specific spin speed that generates excessive vibration and noise as follows:
1) Put an unbalance part (rubber) inside of the drum.
(this is a special weight that service people use. It clips into the drum. If you don't have it, throw in about 4 to 6lbs of damp laundry.)
2) Start the QC test mode (Refer to section 7-2).
7-2 says turn the washer off, then press 'spin speed' and 'soil level' at the exact same time. Then, while holding both buttons, press power to start "QC test mode"
3) Press Delay Wash button, then ' tst ' is displayed on lcd
4) Press the Spin Speed button repeatedly to select Extra High.
5) Press the Quick Cycle button, the spin speed is displayed.
6) Press the Start/Pause button.
7) Press the Beeper button repeatedly to set spin speed (600, 800, 1000, 1200 rpm) and check if there is vibration
and noise.
8) If there is no vibration and noise, increase the spin speed by pressing Beeper button.
9) If there is vibration and noise, rotate the Cycle selector knob clockwise to reduce the Spin Speed (reduce by 50
and 100 rpm). In case of 600 rpm, it can not reduce the spin speed.
10) If vibration and noise are reduced, press the Quick Cycle button to store (2 beep sounds).
* If you want to return to factory default spin speed setting, repeat above steps except step 9)
Jan 10, 2012 | LG WM3987HW Front Load Washer / Dryer
I have a Maytag LA 211 washer and during the spin cycle it vibrates excessively. I tested the spin cycle without clothes and water and it still vibrates excessively. how can this problem be fixed? Ron
To fix this problem you will need to replace the damper pads, this will require several hours of your time, you can read several articles on how to complete this repair yourself at the link below, let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Washing Machines
We just had a new top-load Maytag Washer delivered. When the man finished installing it, he started a wash cycle and left. When it got to the spin cycle there was a lot of vibration. It doesn't...
NO. Have you checked if he installed an anti vibration pads. This is because the high frequency vibrations caused by the spin cycle can cause annoying noise and very serious long term structural damage to you home.
Jan 12, 2011 | Maytag Bravos MTW6600T Top Load Washer
Wash machine vibrates moving several feet on fast spin cycle
If the suspension is still flexible, any unbalanced load will cause this. If it is accompanied by the tub striking the inside of the stationary tub, one of the suspension points may have failed.
I would remove the lower rear panel and watch the movement (with a good light) of the outer tub while a helper pushes the inner tub to its extremes to see if one of the points is 'unhinged.'
Jan 29, 2010 | Kenmore Washing Machines
Kenmore Elite H3E Washer Drain/Spin Problem
hi
it is the belt problem
check it///thank u
please rate it
Jul 04, 2009 | Washing Machines
Severe vibration during spin cycle
reduce the amount of cloth and make sure the cloth don't fix in one corner
Mar 23, 2009 | LG WM-2277HW Front Load Washer
Washer is "walking" during the spin cycle
I have the same Duet that vibrates heavily during spin cycle. Leveled the unit with no success (our unit is mounted on the high base). Long story short, I went to Lowes and purchased a package of 4"X5" self stick foam rubber pads called Grippers by Wasman Consumer Group and paid a low price of $3.50. Since the washer walked forward, I cut one of the two Pads in the package in half, removed the sticky side paper protector and centered a half, sticky side to washer pad, to each front washer pad. The problem was solved.
I made sure the round floor pads of the washer were tight and the unit was level before attaching the Grippers. Hope this helps.
Jan 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
