Question about Thermador C272 Electric Double Oven
I need to self- clean my Thermador convection oven
I need to self- clean my Thermador convection thermal oven. Do you know the steps to follow. Thanks
  • Anonymous Mar 27, 2014
    Thermador scd302t hums loudly when you open the door while the oven is on.
  • Anonymous Mar 31, 2014
    when self-cleaning on
  • 544 Answers
here is the manual for your oven try to follow them and make them as your guide enjoy..
click on this site..
http://specs.retaildeck.com/CACHE/FILE2202.PDF
thank you,
please don't forget to rate our answers.
Posted on Feb 19, 2009
Trying to use self clean feature on my 2009 themador wall oven and E106 code appears?
Are you sure of the error code number? A list that I found only goes from E1 to E15 and F0 thru F9 & also a Fd code. Double check the code and respond back to me and I will see if I can help you further.
Aug 01, 2014 | Thermador Masterpiece MEDMCW71JS 27"...
I self-cleaned the convection oven on my sc302tw, and now it does not heat on any settings, convection, bake or broil. It is 14 years old.
Looks like the sensor has tripped... on my Bosch oven, I opened the back. Connected to the thermostat is a switch with a little button which pops out to prevent the oven from overheating... push in the button to reset it and it should work
Nov 06, 2013 | Thermador Ovens
What does E 2 on a thermador convection thermal double oven mean
depending on the model, could be run away cook/clean temps.
Oct 15, 2012 | Thermador Ovens
I have a Whirlpool Gold self-cleaning oven w/convection. Following a self-cleaning cycle the oven will not heat up. Is there a certain amount of down time that has to go by before it will function again...
The self-clean cycle has blown a fuse in the rear of the oven. That thermal fuse must be replaced. Go to www.appliancepartspros.com and enter your model number. Find the thermal fuse on the diagram and then you can orfer the fuse from them.
Aug 27, 2011 | Whirlpool Ovens
Thermador oven will not self clean.The blower fan does not turn on, and the word HEAT never appears when LOCK stops blinking. In other words, after following steps 1,2 and 3 fan and heat never happens.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 23, 2010 | Thermador Ovens
I bought a used 27" Thermadore double oven off Craigslist. (Loves me some Craigslist.) SS, convection, electric. Sticker on side indicates it was manufactured in 2001. I can't find the tag with model...
If Thermador kept the tag information in the same place, look at the bottom of or just below the control panel (front left hand side of the control panel (when facing the oven) where the cabinet curves).
The oven cleaners can damage the finish and parts of the self-clean oven. The damage may cause the oven to fail sooner than it would otherwise.
If you have a small spill that you want to clean without using the self-clean cycle, on a painted surface, use soapy water or Fantastick or Formula 409 applied to a clean sponge or paper towel and then wipe clean. If the spill is on a porcelain surface, wait until the oven is cool and use Bon-Ami or Soft Scrub on a clean sponge. Then rinse clean. For stubborn dirt, use a soap filled pad.
I hope this helps.
(Thermador has manuals on their website: http://www.thermador.com/SupportCenter/DocumentDisplay.aspx?menu_id=27&menulevel=0302&cat_id=687 )
Aug 05, 2010 | Ovens
Thermador wall oven doesnt heat up after being self cleaned
This may be the thermal fuse mounted on the back panel or you may have a failed control. We rebuild Thermador control boards at www.fixyourboard.com
Jun 02, 2010 | Thermador C302U Electric Double Oven
Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Jan 30, 2009 | Thermador Ovens
Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Feb 03, 2008 | Thermador SC302T Electric Double Oven
Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Jan 30, 2008 | Thermador SC302T Electric Double Oven
Thermador C272 Electric Double Oven Logo
3,078 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
