Question about Acer Aspire 5100 Notebook
CD/DVD Drive doesn't work.
My Acer Apsire 5100's CD/DVD drive won't read any disks.
I've tryed restoring/reinstalling Windows, editing the registry, and uninstalling and reinstalling the drivers.
  • 1 more comment
  • nlake93 Feb 19, 2009
    Ived tryed that also.
    I'ved tryed that also.
    HOw would I go about replacing it?
    President:
  • 2,110 Answers
Your cd drive lens needs to be cleaned by a lens cleaner..
Posted on Feb 19, 2009
  • Sibananda Jena
    Sibananda Jena Feb 19, 2009
    In that case your lens needs to be replaced...
  • Sibananda Jena
    you have to contact nearest service center for replacing Lens...
Optiarc 7580s dvd does not recognize any disk
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Mar 04, 2012 | Sony Optiarc Computers & Internet
I have an acer aspire 5100-4720 notebook. The DVD Drive will not appear in my computer. It shows up sometimes and work perfectly well. But most times, it is missing and does not function. I check the...
Go into system and roll back driver. If this doesn't work, go into hardware and remove it. Restart pc. It should try to reinstall. It may ask for driver. Have it ready.
Apr 24, 2011 | Acer Aspire 5100 4720 Notebook
DVD/CD-ROM drive missing
Problem with missing dvd-drive with Acer 5101 solved.
Problem was that depending on boot, even bios couldn?t detect dvd-drive. I
opened my laptop and found out that there were one small screw that wasn?t
connected to anywhere. I opened the screw that locks dvd-drive in to 2.5? slot. In the back of the
dvd-drive is L- shaped peace of metal. One of it?s screws were already dropped
and 2 that were left were loose. I tightened those screws, but drive back and
got my laptop working fine.
http://www.vapaakoodarit.fi/~puontis/cd-drive.jpg
Please feel free to post this solution to other forums as
well.
Jul 12, 2009 | Acer Aspire 5100 Notebook
E:\ is not accessible. Incorrect Function.
Also make sure your software is FINALIZING or CLOSING the disc when burning. Otherwise all you are doing is writing temp files for windows to read but no other player will.
Jun 13, 2009 | Acer Computers & Internet
My Acer Asprire 5100-5674 no longer recognizes the cd/dvd drive.
hi, cd drives do wear out or just break, most time it is software related. but they can just stop working.hope this helps. good luck
Feb 26, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 5100 no longer "sees" its cd/dvd drive- anywhere.
You can check the BIOS to see if the drive is recognized and even attempt to boot from the drive using a bootable CD to verify it is functional (if using the Windows disc - just verify it reads - DO NOT REINSTALL)
If the drive works use the following to get the drive back in Windows:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
Dec 21, 2008 | Acer Aspire 5100 Notebook
Acer 5100 cd/dvd drive no longer appears as a device - anywhere
try a disk cleaner it might be dirty inside and they are very sensative
Acer 5100 lost dvd/cd drive
Is the DVD drive listed in device manager under CD/DVD drives at all? If so, remove it and reboot. Windows might be able to re-detect and reinstall the drivers for it, but odds are the drive is bad. You can try removing the drive from the computer, and use compressed air to blow out the area where it connects to the laptop. Also check the connection on the DVD drive to make sure there isn't any physical damage, bent pins, etc.
Hope this helps - remember to rate!
Sep 30, 2008 | Acer Aspire 5100 Notebook
Pioneer dvd rw-dvr- k16RS ATA drive can't read any cds
Uninstall You DVD/CD Rom Driver From Device manger in Control Panel and then Something Should Come Back Saying Installing Drivers For Your Device Wait Till Finishes Or If It Cannot locate driver browse for location and put C:/Windows If C Drive Is your windows drive put it But The Windows Folder Is Compulsory .
It Should Install The Drivers But Still If It Doesnt Work I Think You Just Have to Download Firmware For The Exact Model Of Your Drive Try Google or the Web Of The Manufacturer .
If It Still Doesnt Work I Hope You Have A Limited Warranty
Just Return It Or Give It to Test....
Good Day.
Jan 12, 2008 | Pioneer Slim 4x ATAPI (DVRK12RA)...
Acer Aspire 5100 Notebook Logo
137 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
