Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
No water getting to the ice tray - Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
  • 1,239 Answers
i think ice clotted in the try to defrost and check again........
thank u
Posted on Feb 19, 2009
Why does the ice tray in my side by side American fidge freezer not re-fill with water?
You either have a bad ice maker or your water valve in the lower back of the unit is bad.
Jul 27, 2015 | Refrigerators
On my VISB542SS the ice maker , water leaks into the drawer when ice is being made, Ihave removed the unit to check for leaks bot find none.
The ice tray releases the ice because the mechanism twists the tray during the end of the cycle. Sediment builds up in the ice try over time and the smooth Teflon surface is no longer smooth, and the ice can get a "grip" on the tray. Then when the tray is twisted, a few cubes remain in the tray. When the measured amount of water then flows into the tray on the next cycle, it is too much. It freezes over the top of the tray, and the next time the tray is twisted, no ice falls out. When water is injected after this, it just runs off the top of the tray into the bin, freezing the ice in the bin. Replace the ice tray every 3-4 years with a new ice tray, and the problem disappears.
Do get back to us for any further query and do not forget to accept it.
Thanks for contacting
Oct 15, 2010 | Viking Refrigerators
Ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Aug 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
2003 whirlpool ice maker doesn't work
May be an issue with the cam that operates the ice maker. U can pick up a new ice maker for about 40 bucks on ebay.
Lots of things could be bogus. If the solenoid does not open, no water in tray - no ice. If tray does not get warm for fingers, fingers cannot push ice out - no ice. If freezer is not at least 10 degrees, no ice making at all. If cam motor for maker is bogus, anything could be out of whack.
Make sure that the ice maker is in "on" mode.
May 03, 2017 | Refrigerators
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
Ice tray sometimes stuck when dumping off ice
Your icemaker tray has an update for the water flowing over the tray.  You will need to call a qualified LG technician to get it replaced.  Also, the tray is twisted because it binds itself against the hinge pin on the left side.  To stop this, spray some cooking spray oil in the left hinge pin and it should unbind itself and return to normal.
Mar 24, 2008 | LG LSC26905TT Side by Side Refrigerator
LG LRSC 26923TT Side by Side Refrigerator Problem with ice maker
We have the same problem with the ice cube tray. Repairman said the tray must be replaced every year as continual bending warps it out of shape. Replace every year and your problem is solved.
Jan 28, 2008 | LG LRSC-26922 Side by Side Refrigerator
Ice Maker Freezing Up and Ice not dispensing
Check your ice cube tray to see if it is warped. Mine was. I took the tray off and dipped it into boiling water and remoulded it to the original shape and re-installed it. So far no problems. The tray gets warped because of the ice cube release mechanism. The tray is rotated around until it meets a block on one corner which creates the twisting motion we used to do on manual trays. Over time it tends to warp the tray. Good luck
Nov 26, 2007 | LG LRSC26925 Side by Side Refrigerator
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
57 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
