Question about Hotpoint HSS25GFP Side by Side Refrigerator
Hotpoint Hss22IFMC WW water not dispensing or making ice
I bought this used and it has a filter. Does the filter have to be hooked up to supply line and water valve for the ice maker and water dispenser to work? I had to install a new water valve and did not route the filter through it. Any help would be appreciated. Thanks
Mike
Master_Tech
  • 770 Answers
SOURCE: hotpoint refrigerator water dispenser not working, while ice maker, works slower
Check or replace the water filter
Posted on Jan 26, 2008
  • 26 Answers
SOURCE: Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Posted on Mar 18, 2008
SOURCE: Hotpoint CSX22GR water dispenser not working
Sounds like to me your filter needs replaced...how long ago have you changed them?
Posted on Aug 23, 2008
larryyb
  • 291 Answers
SOURCE: GE gss25ifrf ww Ice maker
you will need to replace the dispensor board part number WR55X10444
Posted on Dec 04, 2008
wheelshot
  • 102 Answers
SOURCE: water dispenser doesn't work on ge hotpoint freezer
Here recently I have run into 2 of these units that do this and have found that the dispenser line is frozen in the freezer door. The way to test this is to remove the kick plate under the doors (It is easiest to open both doors to do this) Disconnect the union in the water line leading to the door by pushing in on the waterline and pulling in on the end of the fitting. When the line is apart, close the doors and push in on the paddle as to fill a cup with water. If you get water out of the line under the door then your line in your door is frozen and you will either need to replace your door or let the unit thaw for 24 hours with the doors open. Cheaper to thaw. If no water comes out under the door when paddle is pressed then you will need to replace the water valve as long as you have 120 volts at the valve when actuated.
Posted on Apr 11, 2009
Ice maker not filling door not dispensing water
Make sure the temps in the fridge aren't cold enough to freeze the filter... Water valves rarely fail at both solenoids at the same time, so be sure the water supply is turned on and that the water line is not kinked (bent in half) behind the machine... Hotpoint Refrigerator Water Filter MWFP , Hotpoint Refrigerator Water Inlet Valve WR57X10032
Aug 02, 2016 | Hotpoint HSS25GFP Side by Side...
I would really like some help with hooking up the ice maker. The line is there bit no ice or cold water, water is warm. Can you hep?
The routing of the water line is
house water supply into built i filter on refrig,
out of the filter into the water inlet valve on back of ref,
larger dimeter tube from valve into water tank behind crispers in ref,chills water,out to door,
smaller diameter tube from valve into icemaker
seeing where you said all lines are in place i believe the issue is that the refrig isn't properly cooling? the first to affected when not cooling is icemaker/water dispenser
Hope this helps
Gene
Jul 29, 2011 | Hotpoint HSS25GFP Side by Side...
My hotpoint fridge dispenses ice, but not water. The filter has been changed. Model #HSS25GFPE WW
Set up a shop light, one of those Halogen type lights. And have it shining right on it at the highest setting. The water in the line has frozen. After about 30 minutes to an hour it should start working again. You could also use a blow dryer but I'd rather not stand in front of the fridge that long. Remember if you got kids in the house to warn them not to touch the light!
Mar 13, 2010 | Hotpoint HSS25GFP Side by Side...
Hotpoint ice/water dispenser will dispense ice but not water
You may have a blocked filter. Has this even been changed since you have hook-up the water line, or did you recently just install a new filter. If so it may not be in right correctly. try removing it and reinstalling it.
Refrigerator makes ice and dispenses ice, but does
could be valve, it is located underneath on back. it also could be the mother board. Check valve with ohms metter. Also make sure water resevior or water lines are not frozen inside refrig section. Also water feed line going up through door bottom hinge on freezer is not frozen. Disconnect at couplin at left bottom front and blow through line
Mar 04, 2010 | Hotpoint HSS25GFP Side by Side...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Icemaker on Hotpoint Model HSS25GFPAWW Refrigerator not working
try turning the temperature for the freezer down a little bit. it has to at least be around 17 degrees before the older ice makers start to work.
Jan 20, 2009 | Hotpoint HSS25GFP Side by Side...
I have a Hotpoint hss25gfpe ww fridge with ice and water in the door. The ice works, but I am unable to get water. Why can I not get any water? The serial # is tf261776 if this is needed.
Most water dispensing fridges have a tank in the fridge to keep the water cold. If the fridge temp is too low it might freeze the tank and stop the water from dispensing. Also check the water filter to make sure it is not frozen. Water filters should be replaced every 6-12 months, if it's been longer than that it might be too full of dirt to allow water past. It also might be the water inlet valve is not opening.
Jul 20, 2008 | Hotpoint Refrigerators
Water does not dispense
You probably have a defective water inlet valve. This is a dual solenoid vavle that your supply line connects to. One solenoid supplies the icemaker and the other supplies the water dispenser. Replace this dual valve and it should take care of your problem.
Feb 15, 2008 | Hotpoint HSM25GFRSA
Hotpoint HSS25GFP Side by Side Refrigerator Logo
79 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
