Question about Acer Aspire 5315 Notebook
The core temperature is85c to90c how to cool or is it safe
  • Anonymous Mar 14, 2009
    My Acer Aspire 5315 has started to run really hot and shutoff in the middle of use since i installed an upgraded version of vista. it shuts off mostly when plugged in and sometimes on battery.
  • Anonymous May 14, 2009
    I recently downloaded a freeware called 'SpeedFan'
    and this softwares shows my Core temperature up from 79 min to 85 max.
    could any one help, i have already added 4 80mm (8cm) fans all round the pc in the case and seems cool enough, but the core temp seems to be uncontrollable.
    please help, thanks
  • 23 Answers
That is NOT safe, way too hot. Your fans are broken probably.
Posted on Feb 24, 2009
Laptop cooling fan running at very high speed
Try loading and using a program called speedfan to control your fan speed if that is appropriate. This can also show you your CPU temperature (if you can figure it out). Core Temp can show you temperature of modern CPUs, amongst others.
Otherwise try cleaning you CPU of dust - search the internet as to how to this safely.
18.April.2014
Feb 05, 2014 | MSI pr600 fan
Fan control
18.April.2014
Jan 29, 2014 | Computers & Internet
Water leaking out of overflow from heater core.
If coolant is leaking from the heater core into the interior or through a weep hole out of the car your heater core has sprung a leak.
Most vehicles have easily accessible heater cores, only requiring removal of a panel under the dash or hood to gain access. On the '97 Skylark it's accessible under the dash.
  • Disconnect the negative battery cable.
  • Drain and recycle the engine coolant.
  • Raise and safely support the front of the vehicle.
  • Detach the drain tube, then disconnect the heater hoses from the core tubes.
  • Carefully lower the vehicle.
  • Remove the console if equipped.
  • Unfasten and remove the sound insulators, console extensions and/or steering column filler, as required.
  • Remove the floor or console outlet ductwork and hoses.
  • Remove the heater core access cover.
  • Unfasten the heater core mounting clamps/bolts, then extract the heater core from the vehicle.
To install:
  • Install the heater core, then secure using the clamps/bolts.
  • Fasten the heater core cover.
  • Connect the outlet hoses and ducts.
  • Install the sound insulators, console extensions and/or steering column filler.
  • Raise and safely support the vehicle.
  • Install the drain tube and connect the heater hoses to the core tubes.
  • Connect the negative battery cable.
  • Fill cooling system and check for leaks. Start the engine and allow to come to normal operating temperature. Recheck for leaks and check coolant level. Add if necessary.
Feb 28, 2011 | 1997 Buick Skylark
I put a brand new heater core, radiator, water pump an thermastat but it still takes forever to blow heat out an then it doesn't get that hot.. what's the problem? my vehicle is a 1995 jeep wrangler 2.5 4...
Could be the heater bypass valve is stuck or the heater core is blocked.
I'd check the heater core first.You may have trapped air in the cooling system or the heater core may be partially plugged up. Engine coolant is delivered to the heater core through two heater hoses. With the engine idling at normal operating temperature, set the temperature control knob in the full hot position, the mode control switch knob in the floor heat position, and the blower motor switch knob in the highest speed position. Using a test thermometer, check the temperature of the air being discharged at the HVAC housing floor outlets.
Temperature Reference
Ambient Air Temperature 15.5° C (60° F) 21.1° C (70° F) 26.6° C (80° F) 32.2° C (90° F)
Minimum Air Temperature at Floor Outlet 52.2° C (126° F) 56.1° C (133° F) 59.4° C (139° F) 62.2° C (144° F)
If the floor outlet air temperature is too low, Both of the heater hoses should be hot to the touch. The coolant return heater hose should be slightly cooler than the coolant supply heater hose. If the return hose is much cooler than the supply hose, locate and repair the engine coolant flow obstruction in the cooling system.
OBSTRUCTED COOLANT FLOW
Possible locations or causes of obstructed coolant flow: Pinched or kinked heater hoses. Improper heater hose routing. Plugged heater hoses or supply and return ports at the cooling system connections. A plugged heater core. If proper coolant flow through the cooling system is verified, and heater outlet air temperature is still low, a mechanical problem may exist.
MECHANICAL PROBLEMS
Possible locations or causes of insufficient heat: An obstructed cowl air intake. Obstructed heater system outlets. A blend door not functioning properly.
TEMPERATURE CONTROL
If the heater outlet air temperature cannot be adjusted with the temperature control knob on the A/C Heater control panel, the following could require service: The A/C Heater control. The blend door actuator.
The blend door. Improper engine coolant temperature
Dec 04, 2010 | 1995 Jeep Wrangler
Heater hose broken
Bypass - no, it would be like a short for the cooling system, a sure way to overheat the engine. But you can just close it completely by adding another valve on the hose and closing it.
Jul 07, 2010 | Dodge Durango Cars & Trucks
Can not find heater control valve 2000 expedition
what year? for 2000, there are no control valves. It mixes a/c air with heater core air to blend the right temp.
SECTION 412-02: Heating and Ventilation 2000 Expedition/Navigator Workshop Manual
DESCRIPTION AND OPERATION Heating/Defrosting The heating and defrosting system has the following features:
  • Controls the temperature and, during A/C operation, reduces the relative humidity of the air inside the vehicle.
  • Delivers heated or cooled air to maintain the vehicle interior temperature and comfort level.
  • Controls the A/C blower motor speed.
  • Cooling or heating can be adjusted to maintain the desired temperature.
  • Uses a reheat method to provide conditioned air to the passenger compartment.
  • The blower motor draws outside air through the A/C recirculating air duct, except for MAX A/C cooling, when recirculated air is used.
  • All airflow from the blower motor passes through the A/C evaporator core.
  • The temperature is then regulated by reheating a portion of the air and blending it with the remaining cool air to the desired temperature.
  • The temperature blending is controlled by the temperature blend door, which regulates the amount of air that flows through and around the heater core, where it is then mixed and distributed.
Dec 01, 2009 | Ford Expedition Cars & Trucks
Replace heater core in 1994 pontiac grand am
Removal & Installation
  1. Disconnect the negative battery cable.
  2. Drain and recycle the engine coolant.
  3. Raise and safely support the front of the vehicle.
  4. If necessary, remove the rear lateral transaxle strut mount.
  5. Detach the drain tube, then disconnect the heater hoses from the core tubes.
  6. Carefully lower the vehicle.
  7. Remove the console if equipped.
  8. Unfasten and remove the sound insulators, console extensions and/or steering column filler, as required.
Unfasten the sound insulator retaining bolts ...
... then remove the sound insulator
  1. On some models it may be necessary to remove the steering column opening filler.
  2. Remove the floor or console outlet ductwork and hoses.
  3. Remove the heater core access cover.
Unfasten the heater core retaining bolts; most later models are secured with clamps.
Remove the heater core from the vehicle
To install:
  1. Install the heater core, then secure using the clamps/bolts.
  2. Fasten the heater core cover.
  3. Connect the outlet hoses and ducts.
  4. Install the sound insulators, console extensions and/or steering column filler.
  5. Raise and safely support the vehicle.
  6. Install the drain tube and connect the heater hoses to the core tubes.
  7. If removed, install the rear lateral transaxle strut mount, if removed.
  8. Carefully lower the vehicle.
  9. Connect the negative battery cable.
  10. Fill cooling system and check for leaks. Start the engine and allow to come to normal operating temperature. Recheck for leaks and check coolant level. Add if necessary.
Nov 13, 2009 | 1994 Pontiac Grand Am
I need instructions on how to replace a heater core in 1994 Grand am
  9. On some models it may be necessary to remove the steering column opening filler.
  10. Remove the floor or console outlet ductwork and hoses.
  11. Remove the heater core access cover.
  12. Unfasten the heater core mounting clamps/bolts, then extract the heater core from the vehicle
To install:
If your good with tools, this should take about 3 hours to do from start to finish. Good luck and keep me posted.
Nov 04, 2009 | 1994 Pontiac Grand Am
Replacing a heater core in a 1994 olds. achieva.
0900c152800a93fc.jpgFig. 1: Unfasten the sound insulator retaining bolts ... 0900c152800a93fd.jpgFig. 2: ... then remove the sound insulator
0900c152800a93fe.jpgFig. 3: Remove the heater core access cover
  1. Unfasten the heater core mounting clamps/bolts, then extract the heater core from the vehicle.
0900c152800a93ff.jpgFig. 4: Unfasten the heater core retaining bolts; most later models are secured with clamps 0900c152800a9400.jpgFig. 5: Remove the heater core from the vehicleTo install:
  10. Fill cooling system and check for leaks. Start the engine and allow to come to normal operating temperature. Recheck for leaks and check coolant level. Add if necessary.6d0c523.jpg182943c.jpg164cdd5.jpg8032c04.jpg18be863.jpg
Oct 21, 2008 | 1994 Oldsmobile Achieva Special Edition
What is a safe temperature range for my E8400 core2duo
70 degrees is a tad high, I'd suggest buying an aftermarket heatsink or re-seating your current one.
May 11, 2008 | FMI CPU Sensor Alarm Temperature...
Acer Aspire 5315 Notebook Logo
154 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
