Question about Simple Shoes Daisy 4x Bb Gun Air Rifle Scope Simple Cross Hairs
Rear sight on my daisy 853 air rile has a malfunction to where on the elevation has a small bolt fell off and a ball bearing dropped out. I do not know where the ball bearing goes back into. Please help! Gary Pearson email: gppearson@puhsd.org or phone 951 443-2371 x 0 Thank you!
    Problem Solver:
  • 14 Answers
Gary:
If no one else has helped you with this problem, and if you can, please email me as many pix as you can of the rear sight. I'm a gunsmith, and I might be able to help you get it fixed. If you've already found a cure, then have a great day anyway!
Posted on Aug 07, 2009
I need info on model 99 bb gun age and price
In 1959, Daisy introduced its first specialized BB gun designed to support the shooter education program, the Model 99. Daisy continued to produce the Model 99 in different configurations until 1980 when the Model 499 was introduced.
http://www.daisy.com/breeze/avanti499
$75.00 to $150 depending on condition.
http://www.gunbroker.com/All/BI.aspx?Keywords=daisy+%2B+99
model 99 bb gun Google Search
Jan 26, 2017 | Optics
Where can i purchase the threaded part that goes into the gun and punctures the co2 this is my second request
Direct, eBay possibly or direct from Daisy.
  • Daisy Outdoor Products - Official Site www.daisy.com CO2; Optics; Accessories; Collectibles; Info. ... Winchester Air Rifles ' Where to Buy ... © 2013 Daisy® Outdoor Products ...
  • daisy bb gun parts ' eBay www.ebay.ca > Search > daisy bb gun parts Find great deals on eBay for daisy bb gun parts and daisy ... Vintage Daisy Powerline Model 44 Co2 Innertube Nut BB Gun ... New listing DAISY AIR RIFLES AND BB GUNS ...
  • Air Gun Replacement Parts - AirGun Warehouse www.airgunwarehouseinc.com/repa.html Air Guns. Air Rifles; Air Pistols; BB Guns; ... Whether you are looking for Daisy BB gun parts or you ... we carry a wide range of air gun replacement parts that let ...
  • Apr 01, 2016 | Daisy BB Gun Pistol CO2 BB Gun Repeater...
    How Do I adjust the sights on my savage 64 LR its shooting High and its brand new
    The rear sight has an elevation adjustment that looks like a stepped wedge. To lower the point of impact, you must lower the rear sight. If you have additional steps on the low end of the elevator, make the adjustment by slightly springing the sight up and sliding the elevator to a lower step. If you're on the bottom step, you can get a taller blade for the front sight (preferred) or file the notch deeper into the wedge. Try different types of ammo before making permanent changes. Guns can be picky about their diet.
    Dec 12, 2014 | Optics
    Daisy powerline 35
    Look around the stock for a retaining bolt under the cheek guard.
    Jun 12, 2013 | Daisy Powerline 880 Air Rifle 177......
    Where can i find a sight elevator for a Daisy powerline 880 airgun? need asap! please help!
    Contact the Daisy customer service at 1(800)713-2479 and tell them you lost the rear sight then they will ask for your address to ship the new part to you. It will take 7 - 10 business days.
    Apr 12, 2013 | Daisy Powerline 880 Air Rifle 177......
    Procedure for replacing rear whl brgs on a 2003 escape awd
    4-Wheel Drive
    1. Before servicing the vehicle, refer to the Precautions Section.
    2. Remove or disconnect the following:
      • Negative battery cable
      • Rear wheel
      • Rear brake shoes
      • Rear halfshaft nut and loosen the halfshaft from the hub
      • Wheel hub and place it in a vise
      • Inner wheel bearing race from the hub
      • Antilock Brake System (ABS) sensor bracket and move the sensor aside, if equipped
      • Parking brake cable from the steering knuckle
      • Brake line from the wheel cylinder and support the knuckle
      • Lower shock absorber nut
      • Lower ball joint by holding the ball joint stud
      • Upper ball joint
      • Coil spring while noting the location of the insulator
      • Steering knuckle cam
      • Steering knuckle
      • Snapring and press out the outer wheel bearing race from the knuckle
        Rear hub and bearing
        Click to Enlarge
    To install:
    1. Install or connect the following:
      • New wheel bearing into the steering knuckle
      • Snapring to the knuckle
      • Wheel hub
      • Steering knuckle cam and hand tighten the bolt
      • Coil spring
      • Shock absorber lower nut. Torque the nut to 85 ft. lbs. (115 Nm) for 2002-04 models; 129 ft. lbs. (175 Nm).
      • Upper ball joint. Torque the nut to 76 ft. lbs. (103 Nm).
      • Lower ball joint. Torque the nut to 76 ft. lbs. (103 Nm). Align the steering knuckle cam and torque the bolt to 85 ft. lbs. (115 Nm).
      • Brake line to the wheel cylinder. Torque the brake line bracket bolt to 15 ft. lbs. (20 Nm) and the brake line fastener to 11 ft. lbs. (15 Nm).
      • Parking brake cable to the backing plate. Torque the bolt to 16 ft. lbs. (22 Nm).
      • ABS sensor bracket. Torque the bolt to 80 inch lbs. (9 Nm), if equipped
      • Halfshaft nut. Torque the nut to 214 ft. lbs. (290 Nm).
      • Brake shoes
      • Rear wheel
    2. Fill and bleed the brake system.
    3. Check and adjust the wheel alignment as needed.
    2-Wheel Drive
      • Rear wheel
      • Rear brake drum
      • Wheel hub nut
      • Wheel hub
      • Snapring
      • Wheel bearing outer race from the knuckle
        Rear hub removal
        Inner wheel bearing removal-rear hub/bearing
        Rear wheel bearing removal-2wd
        Rear wheel bearing removal-4wd
    To install:
    • Wheel bearing in to the knuckle
    • Snapring
    • Wheel hub into the wheel bearing
    • Wheel hub nut. Torque the nut to 214 ft. lbs. (290 Nm).
    • Brake drum
    • Rear wheel
      Rear wheel bearing installation
      hope this helps if so send testimonial comment or even any other questions you have
    Jan 16, 2011 | Ford Escape Cars & Trucks
    I REPLACED THE REAR DRUMS ON MY 97 NEON AND WHEN I PUT THE BLEEDER SCREW BACK IT DOESN'T SEAL
    You have lost the little steel ball that actually seals the bleed hole. The screw itself does not seal. When screwed tight, the bleed screw pushes on a little ball (looks like a ball bearing) that blocks and seals the hole. This ball is very small, and it likely fell out when you removed the screw. Hope this helps.
    Nov 29, 2010 | 1997 Plymouth Neon
    I have Ionic Breeze SI730. Won't turn on.
    You could try some appliance repair shops. If you are able to solder the loosen wire , do so. but the ball-baering coming offf indicates a serious problem within the motor. Look in your yellow-pages for electric motor service. They could help replacing the baearing. But do not be surprised if you didn't get the bearing replaced. Those small appliances are meant for "disposable" use.
    Oct 20, 2009 | Sharper Image Ionic Breeze 3.0 Air...
    Simple Shoes Daisy 4x Bb Gun Air Rifle Scope Simple Cross Hairs Logo
    376 people viewed this question
    Top Simple Shoes Optics Experts
    Joe Lalumia aka...
    Joe Lalumia aka...
    Mark Campeau
    Level 1 Expert
    Are you a Simple Shoes Optic Expert? Answer questions, earn points and help others
