Question about HP Compaq nc6120 Notebook
I have a HP NC 6120 laptop.I have the batt in and the PS plugged in.All that happens is the Charge Light Blinks yellow 6 times then green 1 time,repeats.At the sametime the power light comes on for 6 sec Then whole process repeats.Could this be a bad batt?Won't run on AC alone either.I replaced the CMOS batt and ordered a new Main Batt.
  • 2,653 Answers
It's probably a bad battery BUT I've noticed this problem pretty often from this model. I would check HP's site for a bios upgrade and I'd also check your warranty status because they just updated they're list of computers that they're extending the warranty on that have the same problem.
Posted on Feb 20, 2009
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
I got HP nc 6120, when I connect to the AC battery light constantly blinks (green light), anf the notebook does not start please advice hot to solve the problem
1st please check whether the PC is working only with the battery or not.
If it does then we can be sure that the adapter is at fault
thereby we have to check whether the adapter brick is getting warm or not
if not, then there is no other way than replacing the adapter
but if it is warm, then we might have to change the chord of the adapter
hope that will resolve the issue.
Dec 21, 2010 | HP Compaq nc6120 Notebook
Laptop will not turn on and when you plug in the
You may have a DC Jack issue and needs to be replaced. Common with Acer models using the yellow DC jacks.
And since the battery will not charge, it is most likely a component issue. Shorted MOSFET in the charge section.
May 02, 2010 | Acer Aspire 5500 5570-2609 Laptop
My Dell laptop's battery charging circuit faulty.
try to remove your batt and check if laptop works fine with ac adapter alone.
if yes then put batt in then check how much charge you have if you have about 10% then update the bios immediately.
if fails then have the batt replaced.
Oct 12, 2009 | Dell Latitude D600 Notebook
Toshiba Satellite A15-S127 won't power up
basically this may be the fault of ram or ram slot connectivity problem.
Aug 23, 2009 | Toshiba Satellite A15-S127 Notebook
Power light blinks, lens door won't close
may be it got stuck try to move it by ur finger cuz mine one opens half some times so move it by finger ..... try it it might work for u ....
Aug 14, 2009 | Konica Minolta DiMAGE X1 Digital Camera
I have a HP NC 6120 laptop.I have the batt in and the PS plugged in.All that happens is the Charge Light Blinks yellow 6 times then green 1 time,repeats.At the sametime the power light comes on for 6...
Remove the battery and then press the power button for 45 sec then refix the battery and check that the machine is turning on or not?
If the laptop is not working on AC alone then this is the issue with the converter which is there on the motherboard.
Feb 19, 2009 | Toshiba (K000006610) for Satellite P25...
Not turning on
take the batt out the sys. then put the charger. wait 3 min after that turn your sys on.
without the batt. if it turn on. your batt is damaged. if it dont turn on without the batt and
just the power cord is there. then your power suply node is broken or just no good.
if the sys goes on wait 11 min must 11 min exact. them put the batt on it and take the
power cord off. if sys stays on. your ok.
Dec 30, 2008 | HP Compaq NC6400 Business Notebook
Dell latitude D600 battery charge light flashing
my suggestion is that you allow the batteries to fully recharge(which only happens when the computer is fully off, when the battery is deep discharged.
that will take around 6 to 10 hours each..
Mar 10, 2008 | Dell Inspiron E1505 Notebook
HP Compaq nc6120 Notebook Logo
277 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
