Question about HP Deskjet 3915 InkJet Printer
How do I install the HP Deskjet 3915 Ink Cartridge?
This is only the second time I've installed an ink cartridge and I know it's a simple thing, but still can't seem to figure it out because the cartridge comes set in a plastic piece in the back of it. I don't see how it will fit in. Thank you.
  • 544 Answers
just click o this site and it wil help you how to install the printer enjoy..
http://h10025.www1.hp.com/ewfrf/wc/setupCategory?lc=en&cc=ca&dlc=en&product=1139325
thanks,
please don't forget to rate our answer.
Posted on Feb 19, 2009
Can I print on my hp 6122 deskjet with only a black ink cartridge? I have no color ink.
Yes, all HP Deskjet printer models feature a 'single cartridge print mode'. Just remove the cartridge you don't wish to print with; the printer will automatically revert into either greyscale printing (if color cartridge remains installed) or black only printing (if the black cartridge remains installed). However, if the installed ink cartridge is electrically damaged/defective the printer will display an alert message; it will need to be replaced with a new cartridge.
For more information on the use of refilled ink cartridges or advanced HP printer problem diagnosis please visit Inkjet411:
http://www.inkjet411.com
Sep 03, 2013 | HP Office Equipment & Supplies
My printer is connected to my mac airport and i refilled the black ink cartridge and when i try to print it either prints too light or not at all it's an hp deskjet 3915
The refilled cartridge could be bad. It may have run to low on ink and the nozzles may have melted Make sure the contacts on the cartridge and printer are clean. Wipe them with alcohol or Windex and let the dry.
Thanks for using FixYa
Aug 06, 2011 | HP Deskjet 3915 InkJet Printer
I have an hp deskjet 940c. I don't know if this is the same model as deskjet inkjet. Anyway what light is on or off on the front when a new ink cartridge(s) is needed?
For the HP 940c, there is only one light to indicate a possible low ink cartridge. The LED above the cartridge symbol (the only one without a button) will flash. (Note: this LED is the second from the left.) When you see the error code, open the printer's top cover. If the error is a low ink issue, the LED will stop blinking.
With the cover open, the cartridge carrier will move until the yellow arrow lines up with an icon on the printer itself. These five icons are in order from left to right (as you look at the cartridges) : tri-color ink cartridge problem, black ink cartridge problem, tri-color ink low, black ink low and cartridges OK. If both cartridges are low, replace the one indicated by the arrow. Then the cartridge carrier will move to indicate the other cartridge is low. (If only one has a problem, after you replace it, the carrier will move to the cartridge OK symbol.)
If HP offers the full-feature software for your OS, then install the software. Use the HP Deskjet Toolbox to get exactly which cartridge needs to be replaced without needing to be ready to replace both (or to monitor your ink level (approximate ink level)).
The manual for the Deskjet 940c is available as a PDF from HP: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=125&prodTypeId=18972&prodSeriesId=35985 .
I hope this helps.
Apr 11, 2011 | HP DeskJet 940c InkJet Printer
The printer's black ink cartridge won't print without the Tri-color print cartridge
Most of the HP printers are designed to allow printing onlywhen all cartridges are installed and
have ink.
Install a new tri-color ink cartridge and printing will continue as usual.
My printer, which is HP, does the same thing as yours, until I replace the empty cartridge,
printing stops.
Feb 22, 2011 | HP DeskJet 3745 Printer
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
Just installed refilled black ink cartridge on hp
By using refilled cartridges you will always have this problem. Each cartridge has a chip that lets the printer know when it is full or empty. By pressing the ok button you may be able to clear this message. However, most of the time you can still be able to print and ignore the message.
May 28, 2010 | HP Deskjet D4260 Printer
My Deskjet 3915 has gone over half a year without use and will not print. The paper is fed through and the ink cartridge moves back and forth, but no ink comes out. Any ideas?
You have committed the cardinal sin of inkjet printers, lack of use. The printer responds by letting the ink dry up in the feeder tubes and the printhead nozzels.
While it is possible to repair, time and dollars and cents (sense) say "Hey, it's time to buy a new printer!
Next time, if possible, print at least 1 page a couple of times a month. A pain, but it works.
Aug 03, 2009 | HP Deskjet 3915 InkJet Printer
Empty cartridge
HP Deskjet 3915 Inkjet Printer.
Empty cartidge status is related to the refilled catridges.
Please do not use any refilled cartriges in the above printer.
There is a chance of leakage of ink as a result the entire printer will not work properly.
Buy genuine HP Catridges and install the same in the printer.
If the problem still persits, please lodge a complaint with local HP office and get the cartidge is replaced with a new and genuine one.
Try to make user of Annual Maintence serice contract with local authorized ho Vendor for regular servicing of this printer.
Jul 16, 2009 | HP Deskjet 3915 InkJet Printer
HP Deskjet 3915 InkJet Printer Logo
42 people viewed this question
Seeker5211
Seeker5211
