Question about Explorer Appliances DA9666 Stainless Steel Gas Kitchen Range
Burnt Broiler element on a Explorer wall oven
This wall oven was purchased in San Francisco about 4 years ago. We were told it was manufactured in Italy!?! The broiler element has burnt and nobody seams to have a replacement or know where these explorer ovens are coming from. Hereare some specifics: serial # 348190319; 140 volts, 60 hz frequency, 2675 watts, 16 Amps.
Any help or direction would be much appreciated.
Thank you.
Gilbert
    Sergeant:
  • 326 Answers
Http://www.applianceaid.com/image/component1.JPG
for how to check the heating element(magnetron) of the oven click the link.
they are easy to replace. Usually you remove a few screws and them there are two wires you have to disconnect.
The element has a width (W) of 12 in. A length (L) of 16 in. a depth (D) of 1-1/2 in. and a terminal spread of 1-1/4 in.
Posted on Feb 19, 2009
    Brigadier General:
  • 5,158 Answers
  • 265 Answers
I think they have gone bust matey.
    Top Expert:
  • Explorer App... Master
  • 77,544 Answers
These elements have universal or generic replacements, remove your element, 2 screws for the wires and take it to any local appliance parts retailer, they are all over, they will match it up and supply a comparable part.
Broiler element does not heat on ge jkp15bow2bb
ck the element and witing to control / then go to the control . elements are very common .. mm
Jul 14, 2010 | GE JKP15 Electric Single Oven
I have a model MER5755QAS. Oven/broiler not working right.
Sounds like you may be getting only 110v to unit. After unplugging, Check for any burnt wires around terminal block or around elements. Also first check if breaker may have half way tripped. Cut breaker for stove all the way off and then back on. The bake element may have partially tripped the 220v breaker thus only sending 110v to unit.
Oct 31, 2017 | Maytag MER5775Q Electric Kitchen Range
I have a 4 yr old kenmore glasstop electric range. Problem exists with the broiler as it comes on when I set the oven to bake.
this is normal
about 8 years ago manufactures started to include the broil element in the preheat cycle to heat the oven faster
it should cycle down once the set temp is reached
Sep 27, 2009 | Kenmore Kitchen Ranges
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Whirlpool electric wall oven rbs305 oven is on, control panel shows on, 350, etc, but elements don't heat. Same for broiler element. Auto clean was run last week and the oven hasn't been used...
you have a thermal fuse open it is called a "T.O.D" it is located on the back of the unit or up in the top. the self clean very often pops these especially on the whirlpool units made 4-5 years ago very cheap part like $20 you can find it with the wiring diagram easy fix good luck
Apr 22, 2008 | Kitchen Ranges
General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Nov 21, 2007 | KitchenAid Architect Series KEBC107KSS...
Explorer Appliances DA9666 Stainless Steel Gas Kitchen Range Logo
19 people viewed this question
Top Explorer Appliances Kitchen Ranges Experts
Vernon Taylor
Are you an Explorer Appliances Kitchen Range Expert? Answer questions, earn points and help others
