Question about IOGear GPSU21 Print Server
IoGEAR printserver GPSU21 with VISTA
The IOGEAR support told me that this product works with VISTA. I'm trying all that they said to me (disable firewall, turn DHCP ON, keep pressing reset button for 10 seconds, ...) but it never works !!!!
  • Anonymous Apr 14, 2009
    The first and big problem is that the MFP Utility doesn't work in VISTA !!!!! Nothing is detected when run the software.
  • 2,923 Answers
Yes, the GPSU21 is tested to work with Vista 32 and 64-bit Operating System. The things you need to do is listed below:
1. There's no need for you to install the CD that came with it, if the MFP Utility is already installed in another computer.
2. Get the IP Address of the GPSU21 from the computer that has the MFP Utility installed.
- Open the MFP Utility > locate TCP/IP at the lower portion of this window and click the plus (+) sign. > get the IP Address.
3. After getting the IP Address of it, go to your Windows Vista computer and ping the IP Address (just to make sure that Vista is seeing the Print Server).
- To ping, follow the steps below:
- Click the start menu and open the MS DOS Command Promt.
- On the black screen, type this "ping (type the IP Address of the print server): just like this
- C:WINDOWS\Desktop\Scott>ping 192.168.x.x and then hit enter.
4. Once you get ping statistics 4 packet sent; 0% loss. Then the Print Serve is communicating with Vista.
5. On you Windows Vista computer, make sure that the printer is working when directly connected to it. Because there could be a possibility that the printer driver is not properly installed that's why the server is not working.
6. On Vista, go to the Control Panel > Printers > Locate the printer icon (the one that is set as you default printer)
7. Right-click on the printer icon and then select properties > go to Ports tab.
8. Click on Add port button > select Standard TCP/IP > click on "New Port" (beside Cancel)
9. Hit next > type the IP Address of the print server. > Next
10. Click on Custom > Settings button
11. For Protocol: select LPR
12. For the Queue Name: type L1 > Click on OK > Finish.
13. Then under the printer properties, you will see the Standard TCP/IP is selected
14. Hit Apply so that the printer name would appear right next to that port > OK
15. Try printing a test page.
NOTE: After following the steps, you should be able to print using your Vista computer. I configured this print server with Vista several times and it does work with Vista.
Posted on Apr 07, 2009
IOGear GPSU21 doesn't work wirelessly with ip4500. Laptop running vista home 64
First, you have to make sure that the printer can print directly connected to the computer.
Second, make sure that you can "ping" the print server while it's connected to the router.
If the printer works when connected to the computer and you can ping the print server, then you just need to change the port in the print server utility. It should be set to LP1 and not LPT. The queue name should be set to L1.
Check also the printer port, and be sure that it's set to USB001 or USB002 Virtual Printer Port.
If same problem occur, try to uninstall and re-install the server utility. Use the link below to download the utility for Vista 64-bit OS:
You may refer to the user manual of GPSU21 or call IOGEAR through 866-946-4327.
Thank you and good luck!
May 24, 2010 | IOGear GPSU21 Print Server
I am using A Iogear gpsu21 with a Kodak esp5 printer. I am able to print with no problem from a Acer AS1410 laptop running win 7 32 bit.I am using a Sony Vaio E series laptop with a win 7 64 bit system i...
First, make sure that the Kodak printer driver is properly installed in your Sony Vaio. Make sure that you can print while the Kodak is directly connected to Sony Vaio.
If you can print directly connected to it, try to reinstall the GPSU21 Utility.
Apr 13, 2010 | IOGear GPSU21 Print Server
Print server Iogear GPSU21 + HP Deskjet F4180 do not print!
The print server is Vista compatible. However, the Deskjet F4180 is not listed as a supported printer.Look at this list: . This print server is not the right one for your printer. You can either try a different print server, a supported printer or directly connect the printer to a computer and make that computer a print server for the rest of your network. The last option will take a bit more work. In Windows, the directly connected computer will need to allow sharing for the printer and the firewall software will need to trust the other machines in the network connect to it. The other computers will only be able to print and not use the other multi-function features. You may need to get additional software drivers to make this work (particularly if one computer uses a 64-bit OS and another has a 32-bit OS).
I hope this helps.
Jan 26, 2010 | IOGear GPSU21 Print Server
I need a vista compatible driver for an IOgear gbu311 bluetooth wireless adapter
GBU311 does not have a Vista driver. Because it could only support the Win 2000, Win ME, 98SE, and XP. It does not support Win Vista and later versions.
If you wish to have a Bluetooth adapter that is compatible with Vista and Windows 7, you need to have the GBU421 Bluetooth 2.1 USB Micro Adapter. Here, check the link:
Sep 28, 2009 | IOGear GBU311 Bluetooth Wireless Adapter
The software supplied on the disc doesn't run on Vista 64
Here is a direct link to the software download page.
Sep 09, 2009 | IOGear GPSU21 Print Server
Getting IOGEAR GPSU01 to work on Vista 64
If you know the IP address of the print server you can create a TCP/Ip print port. IOGear offers direction on how to create this type of port and here is a link.
Jul 29, 2009 | IOGear GPSU21 Print Server
What's the problem if the printer power's up but cannoyt print?
Have you installed the correct drivers on the PC? What OS are you running (XP, Vista, Linux)?
Jun 10, 2009 | IOGear GPSU21 Print Server
Does IOGEAR GPSU21 work with Vista?
before running the PS Wizard in Vista, right-click on the icon for PS Wizard and select "run as administrator". This will clear the bind errors and wrong segment errors many times - this only applies to vista.
May 09, 2008 | IOGear GPSU21 Print Server
IOGear multi-function USB print server
The direction of the GMFPSU01C will never tell you that you need to create another printer driver. Because, once you install the MFP Utility of this print server, you will have an automatic Copy1 icon of your printer once you successfully, detected the print server and once you successfully connected to the Printer.
Since, the computer is not detected the printer on the network, here are the things that you may do:
1. Make sure that the printer driver is properly installed in the computer. and make sure that the printer is working when directly connected to the computer.
2. If you can't detect the printer, disable your FireWall or any anti-virus program that's running in your computer.
3. Uninstall/reinstall the MFP Utility. If the CD is not working correctly, use the driver from the Website. Here's the link:
Nov 13, 2007 | IOGear GPSU21 Print Server
IOGear GPSU21 Print Server Logo
1,678 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
