Question about Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC)
Connecting a usb wireless adapter wusb54gc to a imac 10.4.11
How do I connect a usb wireless adapter wusb54gc to a imac 10.4.11?
I have already installed a linksys router in another mac and need to connect a secind mac to this one wirelessly.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my understanding, a LinkSys WUSB54GC does not have a native kext/dmg from the LinkSys site. Therefore an external source would be required. Further, the WUSB54GC device uses the same chipset as that of a Ralink RT2501U and thereby would work using the same kext/dmg. This has been verified by others to work. Pls reference the pages here, here, and/or here for download and instructions.
Good luck and thank you for using FixYa.
Posted on Feb 19, 2009
  • 741 Answers
At what stage are you at? Once the disk driver is installed and the USB Wireless Adapter is plugged in and working. Then go to Networking on the Imac and it should automatically show the wireless signal named aftet the SSID name you gave the router. Once connected you'll need to type in the WEP or WPA password and that's it....let me know if you have any questions.
    Genius:
  • 1,550 Answers
1) Open up System Preferences, click on Network.
2) On the side-pane listing your network connections, click the "+" (plus sign) at the bottom. This opens the create new connection dialogue.
3) Under the "interface" drop-down, there will be 1 or 2 "ethernets" depending on your system. I have 2 because of the forcedeth drivers. In my case, the first "Ethernet" was the correct connection. Give it any name you like. Click "Create".
3a) The new connection should come up in the side-pane; if it says "No IP address", proceed to step 4. If it says "Not connected", proceed to step 3b.
3b) This was probably not the correct "Ethernet" interface. No matter; Simply delete what you just created, make a new one, and select the "Ethernet" you did NOT select the first time. Give it any name you like. Click "Create".
4) It says "No IP address"? GOOD! On the right side, use the "Configure" drop-down menu. Select "Using DHCP with manual address".
5) Type in an IP address that your computer would normally have (example, on my network, my computer is assigned the IP 192.168.0.101, so that's what I used).
6) Click "Apply".
7) It should automatically fill in Subnet Mask, Router, DNS Server, and Search Domains.
Source:http://www.insanelymac.com
    President:
  • 2,110 Answers
  • 265 Answers
You need to pair it with your router.
You need your WEP code on the bottom of your routher and put this into the wireless network on your system.
Then press 1 on the routher to put it into pairing mode then press ok on the system
hope this helps
    Top Expert:
  • Linksys Master
  • 77,186 Answers
Just plug it in, the MAC should automatically recognize the device and install the software.
I tried to access my network by the adapter Linksys WUSB54GC Wireless-G USB on windows 7 but I can't. the driver with adapter for windows xp and vista I installed the vista driver, it's don but not...
You have to connect to your network without using wireless then u have to go to the linksys website and download the windows 7 driver. Install that driver then u can connect with wireless. Worked for me! Gl.
Aug 04, 2010 | Linksys WUSB54GC 802.11g/b Wireless...
My friend has a laptop and I just found this wireless adapter as his laptop did not come wireless. I plugged it in but I would have thought it would recognize that there was something in the USB port but...
Yes there's a big chance that the wireless adapter is bad already since there's no light came up when you connected it to the USB port, try to connect it on a different USB port and if still no light on it the adapter is already bad.
Apr 24, 2010 | Linksys WUSB54GC 802.11g/b Wireless...
I use this adapter on 2 computers (obviously not
2 things could of happened. One the USB adapter went bad or you may just need to reboot your router and see if it can get a connection.
Apr 19, 2010 | Linksys WUSB54GC 802.11g/b Wireless...
Cannot aquire ip address from wireless router
Hi, If your newer usb wireless adaptor does not have the same settings as your router this is the problem you have. First make sure you have installed the cd software that came with the usb adaptor without it plugged in. After that is complete make sure the wireless adaptor is seen by the computer it is attached to. Then you need to open the settings of the usb adaptor and set it up same as your router's settings. This includes the WEP security password if you use it. Good Luck.
Sep 19, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Wireless-g usb adapter fails to connect to router
if your wireless router has security enabled, as a first troubleshooting step you can try disabling the security. then see if the USB adapter can connect. IF it still cannot conenct check for the default channel on the router and on the adapter side.
Jun 03, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Linksys WUSB54GC 802.11g/b can find access point but not internet
do one thing remove the prefered networks from the list of prefered network sand after that connect to the network
u will be able to go online after that ....
Nov 15, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
WUSB54GC model wireless adapter won't connect after months of use
Instead of using the passphrase use the wep key 1 that you created on the router page when you generate it using the passphrase.
Then when you try to connect using the linksys wireless monitor just leave the passphrase blank and type in the wep key1 box the key that I mentioned earlier.
May 17, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Linksys wireless g usb adaptor with Mac
correctamundo...you can always check through the linksys icon at this site, though
Mar 23, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC) Logo
476 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
