Question about RCA RT2300 System
Grinding Cooling Fan
My RCA receiver, model # RT2870, Has a grinding cooling fan. When I turn the unit on it makes this noise for about 20 mins then will slowly go away. It is very annoying so I'd appreciate if I could get some help mayb with how to fully clean or oil, or where I could buy a replacement fan. Thanks
    Scholar:
  • 85 Answers
I would remove top cover and see how easily accessible the fan is it shouldnt be too hard. Once removed check out the specifications on it as far as current and DC voltages and most likely you can find one at roadioshack website and order one for under 10 dollars. You cannot oil these. You spray oil on it then when fan turns on it will spray intire inside of you receiver with oil not a good idea. I hope this helps. Good luck
Posted on Feb 19, 2009
Why is my VIP 612D receiver is making a grinding noise
Most likely the cooling fan bearings are going out meaning that you need a new box. Dish should send you one at no charge unless it was a purchased box from a 3 party.
Sep 16, 2014 | DISH Network Televison & Video
Grinding nosie driver side front tire
Can my anything.
Check the bearings, this makes often such a noise especially in certain curves while driving.
Mar 16, 2014 | TYC 02-05 03 04 Kia Sedona 3.5l V6 Cooling...
The system makes a loud buzzing sound that sounds like a motor spinning rapidly inside the unit. sometimes sounds faster than others. noticed more frequent if system or even room temp is cold. is this...
I have a same exact problem in my RT2870. This is probably one of the cooling fans going bad. Does anyone know where to get the replacement fan and/or how hard would it be to replace it?
Feb 13, 2011 | RCA RT2870 Theater System
Bulb went out for the 2nd time in less than a year on Mitsubishi WD52327. Also making a loud grinding noise. What is my problem?
the grinding noise is from the cooling fan that cools the bulb. It needs to cleaned or replaced. You will need to take the back cover off the set to get at it. If the cooling fan is not doing its job that would cause the short bulb life and the noise
Jan 03, 2011 | Mitsubishi WD-52327 52" Rear Projection...
When i use it it makes a wierd grinding sound
Take the computer to a qualified technician, for professional trouble-shooting (failing bearings in a cooling-fan, or a disk-drive about to die).
Apr 05, 2010 | Compaq Presario Notebook
My Hp DV6174CL laptop makes a fan grinding noise near the power button. this happened after a repair from Micromedics
The DV6000 units have a cooling fan located on the bottom of the case top left side.
If you hear a grinding noise, please do not use the unit.
Bring it back for repair. The blower is on-top of the CPU and if it does not recv. the correct cooling, it will take out the processor.
Sep 26, 2009 | HP Pavilion dv6174cl (RG362UA#ABA) PC...
Grinding Noise
sounds like you have a problem with the cooling fan
Dec 31, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
My fridge quit cooling...lights are still on but no cooling action. was making a bad grinding noise that I thought was happening when it was making ice but now I'm not so sure. It's only one year...
may be your unit is not defrosting and the grinding noise could have been the fan tuching on the build up of frost, you need to check your timer or defrost thermostat
Dec 11, 2008 | Refrigerators
After Recording
Unit sounds like it has a small cooling fan at the rear. A bad fan bearing will produce a noise when dried-out. Replace the cooling fan.
Jun 23, 2007 | LG DR-4912 DVD Recorder
RCA RT2300 System Logo
583 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
