Question about Garden
Honda hr2160 starts but cutts out
Engine starts but cutts out it also cutts out when i engage the rotary blade
3 Suggested Answers
  • 645 Answers
SOURCE: swisher 44" mower starts and runs but engine bogs
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit?
I would like to hear how this works out for you. Best of luck.
Posted on Jun 14, 2011
  • 97 Answers
SOURCE: oil for honda hr2160
call the lawnmower store, some take 30w some take 10w40
Posted on Aug 21, 2012
Need to sharpen the rotary blade
Top 5 Ways to Sharpen a Rotary Cutter Blade ' eBay
www.ebay.com > ... > Quilting > Quilting Tools & Equipment
Since the 1970s, rotary cutters have provided a reliable and efficient method for quilters, garment-makers, and other workers of fabric to create symmetrical and ...
Sharpening and Maintaining Your Rotary Blade from Scrap ...
? 5:54
https://www.youtube.com/watch?v=Kdd3JiWnmtE
Mar 13, 2012 - Uploaded by Craftsy
Sharpening and Maintaining Your Rotary Blade from Scrap Quilting with ... My online Craftsy class, Scrap Quilting: Waste Not, Want Not, will ...
Penny's Hands: How to Sharpen Your Rotary Cutter Blade
pennyshands.blogspot.com/.../how-to-sharpen-your-rotary-cutter-blade....
Mar 5, 2011 - And what has the aluminium foil to do with sharpening rotary cutter ...Thanks for that tip Penny, I have lots of blunt blades I can sharpen now.
Jan 27, 2016 | Food Processors
Engine switching off when you engage into drive, break, or switch on lights
engine stalls with any added load, even DRIVE ,
you have engine issues, if it stalls, for any reason.
stalls are complex. (like juggling bowling pins.)
the ECU tries very hard to stop all stalls, and failed
that means the engine power is very very weak.
(misfiring or fuel starvation)
ever give it a full 60k mile tune up this decade? bingo?
(we have a list of 50 causes) forget that
we have 5 tests. that work. (and good fresh fuel)
ill list just 1
key on, is CEL lamp (engine check light) is on?
you start engine, does the lamp go out.? same lamp.
i'd bet not. bingo? that means scan it , with any scan tool.
then post the DTC errors.
in USA some auto stores let you barrow one, Axxx-zoned.
ok 2: check all fuses. really that is #1,....
1: all fuses, both boxes. checked good.
3: tuneup (a full 60k) the one never to miss.
3: CEL indications running.
Jan 14, 2014 | 1998 Toyota Caldina G
The blades begin to engage when i try to start the engine and the clutch is off!! The engine wont start as a result! please help!
your engine probably sheared the flywheel key replace it but the blades engageing on there on is a big problem check blade clutch make sure its not stuck in the on position engaged
Jul 09, 2013 | Garden
Oil for honda hr2160
Aug 19, 2012 | Honda Garden
Honda harmony 215 sx blades will not engage
Tighten blade nut. Shaft maybe bad, bad motor.
May 06, 2012 | Honda Garden
My countax C300H starts OK but when I engage the cutters it immediately cuts out. If I let the engine run for 10 minutes then engage the cutters they usually work ok but this is pretty annoying. Is there...
Just got one of these mowers myself - accidentally got a large stone caught in the blades which caused the same problem. It looked to me that there's a sensor on the flywheel that cuts the motor if the blades aren't rotating freely. You might find either that the sensor is broken (check it by pulling off the connectors and connecting them together) or that the blades aren't rotating for some reason.
Mar 26, 2011 | Honda Garden
99 intrepid hard to start and or cutts out, what is my solution
n most 90's and up Dodge/Chrysler vehicles, you can try to pull codes from the car's computer as long as you still have a charged battery. Put your key in the ignition, and turn it forward, but not far enough to engage the starter. Turn the key back to the Off position, then forward, back and forward again. In early 90s vehicles, the Check Engine light is going to flash a number of times. Often, code 55 means it is completed.
In mid and late 90s vehicles, you will often get a 4 digit code that may help you diagnose problems starting, mostly checking the eletrical, ignition and sensor systems.
Jul 03, 2009 | 1999 Dodge Intrepid
Garden Logo
772 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
