Question about PfaFF Creative 7570
Presser foot does not raise or lower easily on my Pfaff 7570
I left my Pfaff 7570 in Arizona over the summer and now my presser foot doesn't raise or lower easily.  I have to mannualy push the shaft down.  It will raise by the lever but it feels like there is some resistance now. It doesn't go down all the way even when I push it down.  Can I put any grease on the shaft, if yes what kind.  Other that that it sews just great.  Please HELP!!!!
SOURCE: I need service manual for pfaff 7570
also need this manual
TIA
sarah
Posted on May 01, 2008
  • 27 Answers
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Posted on Jan 14, 2009
SOURCE: 7570 connection
I have Windows Vista; I also had a similar problem; found out that I could only use the usb port on my computer exclusively for sewing as the driver software seems to conflict;
Also, having said that, go to Pfaff.com & download the free driver upgrade and see if that will get you started good luck deb
Posted on Jul 01, 2009
SOURCE: Pfaff 7570 connection to new XP laptop
I bought a 25 pin female RS-232 to USB cable from a computer repair store. It works great. You will have to install the software that comes with it so the computer will know that it is a serial port.
Posted on Jul 03, 2009
  • 22 Answers
SOURCE: How do I remove the face plates on a Pfaff
The plate is not screwed in, it is held tight by a couple of metal springs on each side. Just take a small regular screw driver and gently pry up the face plate. You may have the presser foot lowered by the switch on the right side of the bobbin/shuttle area slide it so the presser feet raise.
Posted on Nov 10, 2009
Pfaff creative 7570 embroidery unit error message 'raise the presser foot lifter' won't clear even though it is raised?
I had this problem, but ignored it, go through the advised listing on the machine's screen, under 'pressure foot lifter' and see if anything can be adjusted.
Dec 08, 2016 | PfaFF Creative 7570
Cant get machine to embroider
there are three positions the presser foot can sit in. Up and down are the same on any machine. The 7570 has an in-between position for embroidery. Lift the presser foot and the lower it slowly while pushing gently. It should stop about half way down. The embroidery foot pushes the foot into the down position with each stitch allowing the fabric to move easily to the next stitch.
Jan 29, 2013 | PfaFF Creative 7570
Presser foot lifter is not lowering the Presser foot
Good day norrishmi!!!
I am giving you an instruction manual.You will find the answer by clicking the link bellow:
http://www.sewingmachinesplus.com/media/products/Janome/sewist500/Sewist500_Instruction.pdf
Aug 15, 2011 | PfaFF Creative 7570
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
Pfaff Creative 7570
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}You need to do a tension assembly test
Tension assembly test. To do this test. Pull the threadthrough the tension assembly and test it to make sure the tension is workingcorrectly.
(To do this test, adjust your tension setting to normal or medium or 5 orsomething in the middle. Raise the presser foot and pull the thread through thetension. It should pull easily!! Lower the presser foot and pull the thread. Itshould pull noticeably harder.)
If it doesn’t work this way then you probably have a pieceof thread or lint stuck inside the tension discs. To remove it, turn thetension to 0 zero and raise the presser foot.Using a small screwdriver, openthe space between the discs and spray with canned or compressed air( a needle will work also). The stuffshould come out. Do the tension test again to make sure you got everything andthen try sewing again.
sewman7
Nov 18, 2008 | PfaFF Creative 7570
Pfaff 6122 Problem
Your machine just needs to be tuned up an the part inside that lower and raises the presser foot needs to be re-lubricated.  Lint, dust, dryness and the machine not being used can cause this issue with most pfaff machines (including my 7570).  A standard tune up from your local PFAFF dealer will remedy this.
Sep 24, 2008 | PfaFF Creative 7570
Threading a pfaff 9020 sewing machine
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Jun 18, 2008 | PfaFF Creative 7570
Sewing Machines Logo
52 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
