Question about Microsoft Zune JS8-00001 Digital Media Player
How to turn it back on like is there a code or something??
  • discichick Mar 09, 2009
    I have the same problem. Have tried all of above. Nothing happens at all. Did the hold back and up. Did the move to bigger usb. Nothing is happening. My computer does nothing when I plug it in to it. The screen is black. Please tell me there is a way to fix it. Thank you in advance.
  • http://forums.zune.net/default.aspx http://zunescene.com
    oh boy, more info pleez!!
    Black screen and no response?
    Did you leave it charging for a full 3 hours?
    What is on the screen when you plug the Zune in?
    Did you try pushing the Lock button On, then Off?
    Press and hold the Play/Pause button until the Zune logo appears?
    Did it ever work for you at all?
  • 38 Answers
Discichick. Neat nickname...
.. Well, the reset trick (back & up) won't work if there is no response **at all** on your Zune. I'd suggest you take a look at this article and try the steps listed there. Also, if you have a friend who has a Zune, borrow their sync cord to try & charge it up (buy a new one @ $20 +/-??). Or try charging it on a different computer.
.. Is the warranty still in effect? Then maybe get a Repair Order opened online or call Zune support to get it done (1-877-438-9863).
.. I think it may be the sync cord primarily, since your computer should detect the Zune whether it has a charge or not.
.. It also may be that the connector tab is broken (somehow) and thus nothing is gonna work right. Take a look inside the connector slot and see if the tab looks odd. Which is a dumb thing to say since I can't define "odd" in any way logical. Look see if it is not straight and aligned, I guess would be best.
Posted on Mar 10, 2009
I have a 1992 Toyota pickup 4x4 4 cylinder. The computer set code 21 which is the oxygen sensor. I replaced the oxygen sensor and disconnected the battery to clear the code. I reconnected the battery...
The code shows oxy. Sensor , this means there is something tripping the sensor . Could be fuel delivery , catalyitic converter , or something else . .....
Jun 11, 2017 | 1992 Toyota Pickup
How to unlock a scotsman ice machine code L board lock
Turn off machine. turn back on. what other code is it giving something is locking the board out.
Oct 02, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Transformer blew at our office yesterday, now calling for a service call, error code SC542???
sc542 is a fuser temperature error code, which could either be something simple (a bad sensor reading) or something serious (a blown thermostat). Either way you'll need to have your service technician come take a look at it and reset the code. (Unfortunately, turning the printer off and back on won't help.)
Sep 14, 2010 | Gestetner C7526dn Laser Printer
2002 town and country...how do i find the trouble codes
Cycle the key three times. (turn from off to on)
Basically, it goes like this.
Insert key into ignition.
Turn forward to the 'on' position, the one just before cranking.
Turn back to off.
Turn forward to on again, and then back off.
Forward once more, and leave it there.
You should get a DTC (Diagnostic trouble code) that displays on the odometer.
If all is well, (or deemed well by the computer) you'll receive a message of 'done' instead of a PXXX (xxx=numbers) Code.
If you relay the code to me, I can help you further!
Nov 30, 2009 | 2002 Chrysler Town & Country
The brake and ABS comes on while driving for awhile then turns off then comes back on...the code reading from general code reader says, "low oxygen
Low oxygen has nothing to do with the ABS. That is something to do with the PCM. You will need to take it to the dealer with the correct scan tool to read the stored ABS codes.
May 31, 2009 | 2002 Chevrolet Avalanche
Airbag light stays on, fuses ok.
The airbag light will come on and stay on as long as there is an active code in the system. It will go off when the code goes to stored. Active means, something is malfunctioning right now so we will turn the light on. Stored means, something malfunctioned but is working now so we'll store the code in memory and turn the light back off. You really need to have the codes checked for an accurate diagnosis.
May 03, 2009 | 2002 Jeep Grand Cherokee
I want a solution for a Sharp AR - 287 Digital Image problem
H-4 is an error code for the fixing assemblyand needs to be reset thru a simulation code, sometimes a power flucuation can cause this error and therefore may not need parts.
press #
press *
press clear
press *
when it is done properly the display will go blank
then enter 14
then press the start key, turn the machie off and then back on.
If the code comes back you'll need something for the fixing assembly
Good luck
Bob
Apr 27, 2009 | Sharp Office Equipment & Supplies
Changed nam on phone that changed lock code,need unlock code
when phone turns on it probably says something in the way of needs initial set up or something simular? at that screen just hit clear button which will take you rt back to default screen then hit center menu button go to settings and then to phone settings,nam and chaNGE back to nam1,hit ok . phone will restart and come back on with everything normal again,let me know if different happens!
Mar 11, 2009 | Samsung SCH-u550 Cellular Phone
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Microsoft Zune JS8-00001 Digital Media Player Logo
51 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
