2005 Dodge Dakota Logo
Posted on Apr 28, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2005 Dodge Dakota AC and Heater both dead but the blower works!
My AC and Heater BOTH suddenly stopped working however the blower still blows ambient air at whatever velocity I choose. On my control panel, the only button/switch that works is the fan velocity. I can make it blow fast or slow but it's only ambient air and it only comes through the face vents. The temperature button/switch does nothing. The selector for which vent (feet, face, defroster) the air comes from does nothing. The snowflake button for the AC does nothing!! I've checked the fuses and relays and couldn't detect a problem so WHAT NOW?! Anyone??
Scott Campbell
Level 3:
  • Dodge Master 916 Answers
  • Posted on Apr 28, 2017
Scott Campbell
Dodge Master
Level 3:
Answers
916
Questions
0
Helped
205592
Points
2366
Could be a diverter door stuck, cable/solenoid broken.
Dan Hooper
Level 3:
  • Dodge Master 4,523 Answers
Dan Hooper
Dodge Master
Level 3:
Answers
4523
Questions
Helped
810578
Points
14313
I would suggest changing the control head. You should be able to source a used unit from a local salvage yard.
4 Related Answers
mike raines
  • 120 Answers
  • Posted on Feb 13, 2009
SOURCE: 2001durango vent only blows air through face vent and defroster.
the vent door is broke in the heater control box under dash
Anonymous
  • 114 Answers
  • Posted on May 04, 2009
SOURCE: ac will not blow thru ac vents, only thru defrost vents.
if vent doors are operated by vacuum check for loose or broken vacuum hoses in the engine compartment , or check the fuse box for any ac/heat fuses if it is a electricaly controoled system
Anonymous
  • 323 Answers
  • Posted on Jun 19, 2009
SOURCE: heating / air conditioning control stuck to front defrost vents
There is a vacuum leak under the hood. Find the vacuum line on the passenger side where it comes through the firewall and follow it to the engine. You system needs vacuum to operate and without it the default setting is on defrost for safety reasons.
moparhart
Steve Hart
  • 246 Answers
  • Posted on Jul 12, 2010
SOURCE: Why does the cold air blow out of my defrost &
you have a stuck blend air door
How do you replace blower motor 97 dodge dakota
The Durango is the same chassis so the instruction at the link on youtube will work. How to Install Replace AC Heater Blower Fan Motor Dodge Durango 04 09...
1helpful
2answers
Where is the heater resistor on a 2005 dodge dakota? Behind glove box?
should be just above the blower motor. You will need to remove the glove box door to gain access.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
2005 dodge durango front heater/ac blower motor doesn't work
Check fuses and relays. On relay just switch with one you no works.
1helpful
87 dodge dakota heater blower stopped workng
The blower resistor will burn and smell without blowing a fuse
Heater blower fan not operating
First, check the fuse. If that is good, chances are the blower motor is in need of replacement.
1helpful
2answers
The blower motor in my 1989 Dodge Dakota suddenly stopped working. Will not blow anything on any speed or on hot or cold!
Have you checked for a blown fuse first. There are two fuse control panels - one under the driver's dash board and one in the engine compartment. The one in the engine compartment should have the blower fuse. If the fuse is good, check the blower relay (this is also in the engine compartment). The cover to the fuse box has a diagram of the fuse locations and descriptions. "BLWR" is usually used for blower.
Blower stopped working.
Heater blower motor resister is bad, or blower motor its self is bad. Run 12 volts from an outside sourse to blower motor, if it runs its resister if not its blower motor.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
