Question about Sony XDCAM HD PDW-F330 DV Digital Camcorder
Unable to access the menu on the Sony pdw-f330
Hi, I have a sony pdw-f330, and I can´t seem to get into the menu .
I press down on the nob, but it's not responding.
The camara is working perfectly, but for some reason, (I may be doing something wrong) I can't access the menu and all the information that seems crucial to have control over..
Thank you very much!
SOURCE: Sony CCD-TRV66 Problem
Posted on May 04, 2008
  • 10594 Answers
SOURCE: Sony Handycam DCR-TRV140 direct video stream image to Vaio laptop
Where is software CD, came with camera?
Posted on Jul 30, 2008
  • 10594 Answers
SOURCE: no image in either viewfinder or lcd
CCD Imager in your camera id bad and needs to be replaced. Follow the Sony web link for details.
Sony offers various models repair with CCD Imager issue free of cost but I couldn't find your model in that list. Contact nearest Sony Service Center for guide lines.
  • 4 Answers
SOURCE: cant import video from my sony dcr-trv350 to my
use video capture usb connection like WINVAR 950
connect one side to the camera and the usb to the mac
Posted on Nov 11, 2009
SOURCE: I am unable to take
The wire loop of PHOTO button is broken. SONY Partnumber: 1-480-607-12 SWITCH BLOCK, CONTROL (PH27500). Order with official service center or browse online parts sellers. Price: $30-50
Posted on Jan 19, 2011
Pdw u1
This indicates the hard drive has errors from bad sectors to file corruption, the hardware should be tested, maybe possible to repair.
May 08, 2012 | Sony PDW-U1 XDCAM Drive Unit PDW-U1 USB...
Sony np-f330 battery...
Laptop batteries, like all rechargeable battery packs, lose their charging capacity over time. Because new Laptop batteries are expensive, replacing the individual cells inside the battery casing can save a lot of money. However, rebuilding a battery sometimes does not work as expected, so it’s important to be willing to purchase a new laptop battery if the procedure fails.
HP Pavilion DV1100 Battery 12 cells
1、Allow the laptop battery to run down completely. Turn off your laptop, then remove the battery. Write down the model number located on your battery to help identify the type of Li-ion replacement cells you need to purchase.
2、Split open a small section of the laptop battery pack (at the seam) with a screwdriver or craft knife. Continue to pry the plastic case loose moving around the outer edge until the entire top is free. This may take a bit of force.
3、Note the number of cells inside the case (usually four to eight). Write down the part number and voltage information printed on the cell casings. Draw a diagram showing the arrangement of the cells and how they are connected, or take a few photos to help with reassembly.
4、Purchase the correct number and type replacement batteries from online shop such as, based on your battery model and cell specifications. Six Li-ion cells typically cost around $30 to $40.
5、Carefully remove each cell using a craft knife and wire cutters as necessary. Each battery pack is different, but the cells are usually wrapped in a plastic casing with metal contacts attached to one end. Lay the metal contacts, wires and casing material aside.
6、Use double-sided tape or a solder gun (only if necessary) to attach the metal contacts to the cells and circuit board. When finished, the old cells should be completely stripped (naked) and the new cells should look like the old ones as much as possible.
7、Place the new cells inside the case, referring to your diagram or photos if necessary. Glue the battery(Compaq DV6000 Battery) pack top back on. Charge the new battery for at least 24 hours before using it.
Tips & Warnings
Keep an eye on the new battery while it charges for the first time. If the contacts are not connected properly, the battery could overheat and cause damage to the laptop.
on Oct 19, 2010 | Computers & Internet
Need instruction book for sony np-f330
NP-F330 is a Sony battery. If you really want the datasheet on it, you may download it here.
If you're asking about a manual for a camcorder that uses the NP-F330 battery, please reply to this post and give the camcorder model.
Mar 07, 2012 | Video Cameras
Hi when i put the XDcam DLA 50 GB disc in my Sony PDW 510 XDCam recorde geve code 03 - 354 error. i dont know about dat. do You can help me ? Thank
03: optical drive two-axis (FCS, TRK)
-354: No signal from disc required for OP focus servo can be detected. Disc is not rotating
I would try another disc and if you get the same error call Sony's service center.
Sep 21, 2011 | Sony PDW-510 Camcorder
Error message 03-354 on Sony PDW-510. What is it?
You may be using a disc that isn't compatible with the camera. This message appears if you put a 50 GB disc in a camera that can only use 23 GB discs. The error will not clear until you put the right disc in.
Apr 11, 2011 | Sony PDW-510 Camcorder
Error 03-454 on pdw1500 deck
What is error03-354 on my Sony XDCAM PDW-F350L?
Thank you. HELP! email:
Jan 18, 2011 | Sony PDW-510 Camcorder
Why does the model and serial number keep popping up on my sony monitor?
Try this:
Under the menu options, there's Menu Lock. Switch it to "On". It worked for me.
My menu button wasn't working, so to access the menu, I had to hold down the arrow up button and push the arrow down button till I got to the Menu Lock Option.
Oct 18, 2009 | Sony SDM-HS75 17" LCD Monitor
Batteries for Sony DSC-F55 or DSC-F505?
No, those are 'M' series batterys and the F55 and F505 take 'S' series batterys.
Sep 08, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Sep 08, 2005 | Sony Cyber-Shot DSC-F505 Digital Camera
Sony XDCAM HD PDW-F330 DV Digital Camcorder Logo
69 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
