Question about Microsoft Windows XP Professional
Virus ineedsolution for two problems 1.after shuting down the system again it is restarting 2.solution for folder virus it is creatin the different folders with existing folder name
    Sergeant:
  • 219 Answers
I can solve your virus problem and the other issue might be resolved in the process.
First run a scan with this online scanner (Use internet explorer to start the scanner):
http://safety.live.com
After that scan finishes and has cleaned anything found, run this online scanner (Use internet explorer to start the scanner):
http://www.eset.com/onlinescan/
After that scan finishes and cleaned anything found download and install the free trial of ESET NOD32 antivirus. Yes, you just scanned with that utility, however the downloadable version has a startup scan that checks any files that start with the system. If any malicious ones are located they are quarantined awaiting your decision to restore them or remove them.
http://www.eset.com/products/nod32.php
After you install the scanner restart your computer! Regardless if it asks you to or not, restart your computer, then update the security definitions of scanner, then perform and in-depth scan on all hard-drives. After the scan finishes and has removed any malicious files, download and install the free version of Ad-Aware:
http://www.lavasoft.com/products/ad_aware_free.php
Once again, after you install it restart your computer. After the restart update the security definitions then perform a Full Scan. After the scan is complete and has removed any intrusions download and install Spybot Search & Destroy. NOTE: Do NOT install TeaTimer(.exe)! You will be asked if you want it during the installation of Spybot. This utility will cause a possibly fatal conflict with NOD32 and can cause complications with your system! So please DO NOT install TeaTimer.
http://www.download.com/Spybot-Search-amp-Destroy/3000-8022_4-10122137.html?tag=mncol
After you install Spybot, restart your computer. After the restart update the security definitions of spybot and run a scan. After the scan completes remove any entries found then download and install AVG Anti-Rootkit Free:
http://www.softpedia.com/get/Antivirus/AVG-Anti-Rootkit.shtml
After installation restart your computer. After the restart perform an in-depth scan of all your hard-drives. After the scan download and install CCleaner.
http://www.ccleaner.com
After installing CCleaner you do not have to restart your computer. Simply start the application and run the cleaner. This will clean out the temporary directories of web browsers and popular applications where viruses will sometimes nest themselves waiting to strike. Cleaning out these directories often helps keep your system clean. After the cleaning finishes click on the, "registry" tab. Now scan for any issues. If anything is found select to fix the issues. When prompted, make a backup of the files and save this file to a location you can remember! If for any reason removing these registry entries causes abnormalities you will double-click the file that you just saved and it will restore everything that was just erased. This is your computer's life-line if for some reason a critical system registry entry was erased. On the bright side, removing these issues from the registry might fix your shut-down issue.
I hope you get this virus removed. Let me know if I can assist you further.
Posted on Feb 19, 2009
My computer was virus
1. Go to Start --> Control Panel --> Add/Remove Programs.
2. Scroll down to your Norton program
3. Click Change --> Remove All.
You will be asked to restart your PC. Do so.
4. Now go to Start --> My Computer --> Program Files. Right click on each Symantec folder and select Delete.
5. While you are in Program Files go to the Common Files folder at or near the top of the Program Files window. Delete every Symantec folder there. And, again, restart your PC.
6. Go to Start --> Search --> All Files and Folders --> More Advanced Options. Check each option except for "Case sensitive"
Now type in Norton and delete each Norton folder from the search results (Again, right click, choose "Delete"). One more time, restart your PC.
7. Repeat step 5 except type Symantec in the "Search" box.
Nov 16, 2010 | Symantec Norton AntiVirus 2008: Windows
Tip
Removing virus from "System Volume Information" folder
Quite often antivirus scanner locate a virus, quarantine it than you find that the next day it's back again. What happened is that windows have included the viruses into the system restore point when it creates one. The folder that contains the restore point information is the "System volume information" folder this is a protected folder.
You may be able to see the folder at all. There are two methods of ridding yourself of the virus if the scanner is incapable. Both require you to be logged on as an administrator.
First method:
The first method is to remove all the restore points. Unless you are 100% sure you will never need to restore to a previous point then by all means do it.
1. Right click on my computer then click on system restore tab. Place a check mark alongside "Turnoff system restore on all drives" click Ok and close the dialog boxes.
2. Run your antivirus scanner again to make sure the virus is gone. You can choose to perform the task you can do only in the folder where virus is detected. In this case “System Volume information” Folder.
3. Once your are happy return to System Restore tab and uncheck the mark while you are there highlighted the drives, click Settings and slide the slider to the left to around 2%. This will release a significant amount of hard drive space. Windows default setting is to reserve 12% and on a 150 gig drive that can total 18 gigabytes. 2% will still give you enough room for an ample number of restore points. Click OK and close the dialog boxes.
4. Next, Create a new restore point. With any name you want.
on May 08, 2010 | Computers & Internet
Tip
How to effectivelly do a Virus Scan
To Effectivelly scan for viruses in your PC, you should turn off the System Restore, for the following two reasons.
1) It may have the backup image and settings for the virus effects on the computer and may get back those after a successful virus removal, and you will again be effected with the same virus.
2) The folder where system restore data is saved is System Volume Information, this folder is no accessible by Antivirus for scanning as they are blocked by the O/s. When you disable the System Restore, you can help your Antivirus to scan on those folders also, where virus can be hidden.
A good virus never comes to the front to infect your computer, it stays in the back and send its ddeployments to infect and harm your computer.
on Dec 05, 2009 | Computers & Internet
My laptop keeps shutting down on me.
1. Try this
Press F8 when you start your pc.
A screen will appear.
Select Safe Mode. Let the pc load until you see your desktop.
Then click My Computer, select C:
In C: , select Windows folder
In Windows folder, open system32 folder
Now, double click rstrui to do System Restore to the time before your PC was ok
After system restore, you pc will restart and your files will be restored. Your PC will be ok again.
2. Check for viruses or trojans as well Scan your PC in Safe Mode. Trojans are known to cause PC to shut down as well.
Hope your PC will become well again!
Nov 11, 2010 | Computers & Internet
Prolblem with folder option when unhiding the folder that is hidden the virus resets back to hide again the hidden folder.. the virus is created to hide a folders and replicate the folder and make it...
DOWNLOAD MALWAREBYTES ANTIMALWARE. Rename it to Something.exe install it. Run it in safe mode and do a full scan . it should pick up the virus and delete it and quarintine it. Restart your PC when required.
Jun 08, 2010 | Microsoft Windows XP Home Edition Service...
How do I delete or repair the threat to my Laptop system that has
HOW TO REMOVE RAILA ODINGA VIRUS IN 2 MINUTES
How to remove raila odinga virus is a very easy process. Firstly, Raila odinga is a worm that attacks Microsoft word files, but it looks like a JPG file and mostly found on the desktop.
Raila odinga has some common characteristics
1. If you delete the picture file it will delete and return to where it was.
2. It runs from the driver folder in system 32 folder
3. it auto runs at system startup
4. It makes the computer boot slowly
5. It makes your computer to hang.
6. It creates new folder.exe folders in your computer
How to remove raila odinga virus, open my computer, double click drive C: open WINDOWS folder, double click on system 32 folder, open driver folder,
locate the word file in the folder, note the name. Right click on the task bar, open task manager, click on the process tab locate the name of the word file you saw in the drive folder, right click on the name of the file, click end process, to terminate the running process
Open the driver folder of system 32 where the file is, delete all the ms word files on that folder, then close the folder locate the raila odinga picture file usually on the desktop or somewhere in your computer, delete the picture file. Please do not double click on the picture file only delete it, finally empty your recycle bin and restart your computer. That way odinga is off your machine.
Mar 25, 2010 | Computers & Internet
Unable to activate show hidden folders
You are right that this is because of a virus attack. The virus has changed somethign in the registry. Follow the below methods:
Method 1:Go to registry editor by running regedit in the run box.
Go to this key:
HKEY_CURRENT_USER\Software\Microsoft\
Windows\CurrentVersion\Explorer\Advanced
In the right hand area, double click hidden and change the value to 1.
Now you’re all set to go. Check it in your tools menu if the changes have taken effect.
Method 2:1. Click “Start” -> “Run…” (or press Windows key + R)
2. Type “regedit” and click “Ok”.
3. Find the key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\
Advanced\Folder\Hidden\SHOWALL
4. Look at the “CheckedValue” key… This should be a DWORD key. If it isn’t, delete the key.
5. Create a new key called “CheckedValue” as a DWORD (hexadecimal) with a value of 1.
6. The “Show hidden files & folders” check box should now work normally. Enjoy!
Mar 29, 2009 | Microsoft Windows XP Home Edition
Surabaya in my birthday
If you are getting message like" Surabaya in my birthday, Don't kill me, I'm just send message from your computer", then it obvious that your computer is infected with Surabaya Virus
Symptoms of Virus
1) All folders get disappear.
2) Folder options not work.
3) Machine Restarts on running command like msconfig , regedit.
4) You are unable to install many antivirus.
5) Folders name appear with scr extension ( Actually not folders)
Reasons of infection
1) Infection from removable drives e.g. pendrive, hard disk,
2) Reading cards using card reader
3) From CD or DVD
4) From others computer
5) From internet
Remedies:
1) Using free software:
Download the "Autorun Eater" from internet ( 1.5mb)
Download from:
http://oldmcdonald.wordpress.com/
http://www.softpedia.com/get/Security/Secure-cleaning/Autorun-Eater.shtml
a) Install "Autorun eater" ( some Antivirus detect it as a virus but it is safe) and run it. It appears at taskbar ( lower right corner)
b) Right click on it and follow following path
Registry fix>>fix folder option.
(This will repair folder option and it will appear in tool menu)
Now you can see hidden folders
But Surabaya virus change your folder attribute to system folder. So to see your folders you have to untcheck option " hide protected system files and folder" which appears
Right "below the show hidden files and folder" option
Path:
Open my computer>>tools>>folder option>>view>>uncheck show hidden files.. and hide protected system files and folder
How to change folder attributes to normal
You can use command prompt to change the folder attributes
A) Start MS-DOS command prompt (start>>program files>>accessories>>command prompt
B) Type drive letter and attrib command
D:\Attrib *. * -S -H -R /D /S ( Put space between /D and /S switches.)
This will change your all folder option to normal
1)Manual:
a) type "regedit" at command prompt..STRAT>>run>>regedit
b) Search word 'surabaya' in registry...Edit>>find>>Surabaya
c) Delete two entries appeared in search as " LegalNotice Caption and LegalNoticeText"
d) Now using left option tree navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\showfile
check value 0 to 1
Autorun Eater software:
Autorun Eater software helps to protect and remove autorun virus which generally infects from external storage device and internet. This small software is very helpful in conjunction with any antivirus software even it alone can protect your computer from autorun virus(but not complete solution).
(C)infoall , legal: Use above information on your own risk
Mar 21, 2009 | Microsoft Computers & Internet
Good day. When i save files or create new folder or add some softwares to my computer and i restart my computer i want to delete all that files, created new folder, or softwares that i added so that it...
1. try scan all you HDD by anti virus with many type free edition anti virus may be you pc effect by virus.
2. can you remember last time you do what like install any special program try uninstall this program the restart pc see will be ok???
3.if solution 1.virus is too effected you os better format,if after scan no anything virus found i think is you OS got problem better you do format & reinstall you OS AGAIN
Jan 18, 2009 | Computers & Internet
Computer viruses
Download and run avast free anti-virus software. They give a 60 day demo or you can register on the website before you download and they will Email you an unlock code, schedule a boot time scan and let it run its course. after the first virus is detected choose option 2 to delete all (automatically).
LINK
Jul 21, 2008 | E-Machines eMachines Desktop PC
Microsoft Windows XP Professional Logo
97 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
