Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Kerosene heater won't stay lit
I have an old Sears model 583409130 85,000 btu heater that starts just fine runs for a few seconds and trips the reset switch.
  • 181 Answers
Check to see if the photo cell is check it open the side compartment and look for the blue and white wire comming from photo cell,on the reset switch there is a white wire and a blue wire.hook these two wires to gether at the switch and try to refire the unit.if the unit keeps running the photo cell is bad and NEEDS to be changed.if the unit shuts off the safety switch is bad.
Posted on Feb 25, 2009
I have a reddy 55,000 btu kerosene heater i bought used and it worked fine the first day it stayed on as long as i wanted it to now it only runs for like a minute and i don't know why it has plent of...
It could be a pressure problem, old fuel, clogged nozzle, etc. If you can furnish me with the correct model number, I will be able to help you further. Reply by using the Leave a Comment link.
Mar 24, 2011 | Reddy Heater-30-55,000 BTU Variable
Spark plug fired,( Sears -30,000 BTU) starts and runs for approx. 30 seconds, then cuts off. The reset button does not reset for restart for about another 20 - 30 seconds. Then the unit will restart...
check and see if the heater has a high temperature limit switch. if it does it will shut the machine off until it cools down.. just replace it with a new one.
Jan 31, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Heater will not run
You don't say, but I am assuming that the motor is running and there is combustion in the combustion chamber and the heater is running fine, then the reset trips. Is this correct? If so, chances are the Safety Control (reset) is defective. Part number HA3003. The photocell could also be at fault. Check for a dirty lense on the photocell.
But---If there is no combustion in the chamber, then the photocell detects a no-flame condition and then it trips the reset.
Troubleshooting tips for a Spark Plug type heater
Nov 15, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater turns on for a few seconds then goes out
Absolutely K1 or diesel can get old in a hurry, the ultra-low Sulphur diesel has been tinkered with so much that it turns to book varnish much faster than before 2010. Most of those heaters spray fuel past the igniters using a siphon much like a spray paint gun, the suction tube may have dry rot or a small air leak and it it takes but a tiny air leak to kill the siphon effect. Check the tube from the nozzle all the way down to the fuel tank or replace it if you're not certain it is not compromised or dry rotted.
Oct 12, 2017 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dayton kerosene heater 3E219B will not turn on
I have a Dayton Model # 3e219b 150,000 BTU potable heater and it runs fine with the top cover off.But if I put the cover on it will go out is less than a minute and trip the reset.
Jan 31, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater won't start properly
Remove the nozzle from heater and clean, be carefull around the ignitor.
Dec 31, 2008 | Desa International Reddy Heater R40 40,000...
Wont stay lit
when unit lights only runs 10 sec then shuts off
Oct 27, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
1,461 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
