Question about Kenmore Elite HE4 Electric Dryer
Kenmore elite dryer. Have to hold start button in order for it to run
  • 547 Answers
Replace the button there is a catch in there that is most likly broken thank you for using fixya
Posted on Feb 19, 2009
Dryer will not stay running
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Apr 21, 2010 | Kenmore 63942 Dryer
Kenmore Elite electric dryer, no heat, runs if holding start ****
with this combination of problems it sounds like a power problem on the control board being you have more than one problem,it sounds as though you arn't getting a latch voltage at the relay energizing coils that latch the relays to power the motor and element
Apr 16, 2010 | Dryers
My kenmore elite he4 dryer wont start
kenore elite oasis dryer won't start, when start button is held down it flashes F, book says call service center
Jun 30, 2009 | Kenmore Dryers
Kenmore Elite Gas Dryer. Cycle wont start
This sounds like one of two things in order of most likely:
- the centrifugal switch in the motor is not functioning (burned, stuck, broken)
- or the run winding in the motor is bad
Need more info, let me know...
May 08, 2009 | Kenmore Dryers
Dryer turns on, but does not run
Try to turn the drum inside with no clothes in it, does it turn freely both ways?
Then as someone is holding the start button, hold the door switch button, then try to turn the drum counter-clock wise, and see if it will start turning on its own.
If it does start turning, then the motor is more than likely the problem.
If it dosen't then the timer is more than likely the problem.
Feb 05, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite Dryer only runs if hold Start Switch
sound more like a control board failure // if it has one,, maybe the belt, starting switch
Dec 07, 2008 | Kenmore Elite 45986 Front Load Washer
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 73954 : Only runs when the START button is continuously pressed
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Aug 22, 2008 | Kenmore 63942 Dryer
Electric kenmore dryer
replace the motor it is stuck in the start winding and can cnot get up to the run winding as long as you are holding in the start button the start winding is working in a second it should through the motor switch shift the voltage to the run winding
bad motor switch
replace switch if available or change motor
Apr 29, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
54 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
