Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Hum when attached to an external amp.
I've hooked by jukebox to the cd input of an external amp to play over my house speakers. It works but there is a loud hum. I believe the manual mentioned this situation and indicated a part I could get to eliminate the hum. Is this correct? Where can I get the part??
The simple soloution is to buy a "buzzstop" .Its a box with an input and output and eliminates hums, I bought it from a company in Ireland www.bluered.ie or you could try powering the jukebox and the amplifier from the same socket to see if its an earth hum
Posted on Feb 24, 2009
Hook up ex. speakes
The external speakers come off the tabs on the left of the amp marked Ext Speakers. 8ohm 40 watts.
Dec 21, 2015 | Wurlitzer Jukebox 1015 One More Time...
I have a Rowe AMI 100 CD jukebox. It plays about 3 song and then right upper speaker goes out. Is this a speaker problem or something else?
You could have connector problems on the speaker crossover network located inside the amplifier compartment on the opposite wall from the amplifier. Typically the solder joints go bad where the connectors are soldered to the board. Usually a simple resoldering can fix it. There could also be problems with the connectors at that particular speaker itself.
May 01, 2014 | Wurlitzer Jukebox CD Player
Static sound from one channel after playing for a while--time it starts varies.
You don't say what a 1055 is and it is hard to know what you are asking with a lack of ID on the equipment at fault. Sounds like a source selection problem maybe a switch or if electronics a CD4066 IC.
Mar 25, 2013 | Audio Players & Recorders
I have a pair of JM lab Electra 905 speakers, running through a DNM amp and power amps. When powered up, the left speaker makes a very loud humming noise. This has happened recently. I haven't changed...
Hello
Switch on your amp, keep its volue down to extreme low, and listen if there is still hum through the left channel or not. If still there is hum, the left side power amplifier section inside the amp;ifier is faulty. If htere is no hum at this state, hum enters thorugh the audio input terminal, and the input wires must be checked for open sheild connection. OK.
Apr 10, 2011 | Jmlab Electra 905 Speaker
Earth hum
You need an earthing isolation unit. I'm not sure how it works but that's what you need.
Dave F.
Jun 22, 2009 | Wurlitzer Jukebox 1015 One More Time...
Pioneer indash stereo/cd player DEH-7500MP,no internal amp output
some cars have internal amps for the speakers try connecting the remote wire it's the blue wire with a little white on it worked in my moms van.. if that does not work try testing it with a speaker from your house
Mar 31, 2009 | Pioneer DEH-P7500MP CD Player
Sunfire Amplifier hum
If it works fine with other inputs then it simply cannot be your sunfire. Next time it happens try reversing the power plug on one of the pieces of equipment hooked up to it and see what happens.
Mar 11, 2017 | Audio Players & Recorders
No sound on 2710 Wurlitzer
Find the input to the amp from the tone arm. Play a record and while it is playing unplug the tone arm input. Stick a paperclip in the input of the amp...if it doesn't go HUMMMMMMMMM.....you have a dead amp....or the speakers arent plugged in.
Dave F.
Dec 08, 2008 | Wurlitzer Jukebox 1015 One More Time...
Ipod Connection through RCA Cable
Actually, what I think gbaity is doing is utilizing his IP(Interactive Pioneer)-Bus port in the back of the DEH-P3000, which is an input port designed to allow the deck to use an external multi-disk CD changer. All you need is the CD changer, then change the input source from your deck to "M-CD". There are folks on eBay and other places that sell a cable that pluggs into that very same port. They are designed to allow the unit to accept input through the IP-Bus from an ipod or just about any low-level input that you can pass through the RCA jacks. I have the same deck, and also just purchased an ipod cable for the IP-Bus, and it also does not work. I have been told that I need to switch the "M-CD" input source to "AUX" as the input, but I do not know how to do that. pressing the input source button only displays "CD", "M-CD", and "FM/AM". Does anyone know how to add "AUX" to the choices or otherwise show us how to make these cables work? Thanks - TomR
Aug 23, 2007 | Pioneer DEH-P3000 CD Player
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
183 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
