Question about Frigidaire ATF6000ES Front Load Washer
My Frigidaire front loading washer is displaying "DO".
What does this mean? It started to wash but when it came to draining the water it stop and displayed "DO". Please advise.
  • gttcbts Feb 22, 2009
    mine stops and gives three beeps error code which states "drum overfilled." Following manufacturers solution instructions did not help. Does anyone have a working solution?
Drain assembly was clogged
Posted on Feb 22, 2009
Front loader washing machine EWF1087 stopped half way and did not drain, E50 was displayed. Emergency emptying out the water was done and try to restart. Could not start, still displaying E50. What to do?
the error code E50 indicates that the motor has become overheated, you should give it an hour to cool then try running the washing machine again. I'm also including a link to pdf below with the common error codes for your brand of washer in case you have any other problems
Jun 17, 2011 | Electrolux Washing Machines
The washer displays "E10" on the screen. What does this mean and how much does it cost to repair?
Hi, the E10 is a problems with water drain during washing
-Drain hose kinked, filter blocked, drain pump, water distributor, wiring , main PCB, pressure switches
Usually due to debris trapped in the drain pump (pebbles/coins/hairgrips etc) jamming it. Clean it all out including all pipes.
Take care
May 13, 2010 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire washer will not drain. It work
check all the drain hoses for something caught in the line to the drain from the tub thru the pump to the stand pipe at the drain,you may have a plugged line and machine pump wont start due to this restriction
Mar 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Wash starts, then stops postin E10 and now soap does not dispense
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Aug 02, 2009 | Frigidaire GLTF2940F Front Load Washer
My GLTF1040AS0 front load washer has stopped advancing after the wash cycle.
Does the unit stop and display any error code(s)? Is it noisy in Spin? If yes to either your pump drain screen is likely cloged/restricted and the pump itself could be damaged.
Drain hose is pushed to far down into drain stack. This can cause a syphon effect were water drains while the unit is filling.
Jul 18, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Won't wash
press the pause and stop button at the same time it will give u a code
Mar 20, 2009 | Frigidaire Affinity ATF7000E Front Load...
Doesnot stop filling water
To javed_iqb904, does the drum actually fill or does it seem like that water is draining out as it's filling?
To neonllama19, if it fills with the tap on and the machine off, it sounds like a defective water valve. If it never stopped filling it sounds like a defective pressure switch or hose to the pressure switch is loose or diconnected.
Jan 08, 2009 | Frigidaire GLTF1670A Front Load Washer
Frigidaire front load washer (LTF600ES1) Error E20
Your washer is not draining properly. You need to check if the drain hose is kinked and also whether the household drain is running smoothly.
Aug 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
Timer Stalling
I would check the water hoses for twisting, make sure the water faucets are turned on all the way, and check the filters at the washer end of the hoses to make sure they are clean. I would also check the drain system to make sure it is clean and the machine is draining well.
Jul 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
52 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
