Question about Roper RAS8445KQ Top Load Washer
How do you take off the back?
Making a whining noise during all cycles e-cept fill up- How do I remove the back cover?
  • 188 Answers
Don't remove the back cover!
Lift the console by removing the 2 screws which hold it down to the cabinet. Once the console is out of the way you will see 2 brass clips which hold everything together. Remove these by inserting a screwdriver from the top and pop them out. Unhook the wiring to the lid switch, open the lid. Tilt the whole cabinet forward and it should all come out as one piece. Trust me this is much easier then trying to figure out where all the screws go if you go from the back.
Now with the cabinet off, you can see and access whatever you need.
Posted on Feb 19, 2009
Washer is making different noises during wash and rinse cycle
could have been the motor,you might also smell like a shellac kind of smell,when the motor overheats,also how old is it and what's the brand name and model number.you can feel the motor,if it's hot then it is cutting out for some reason.
Dec 20, 2017 | Washing Machines
Maytag MVAT346AWW
Remove the back lower left access panel. You will find the drain pump there. 95% of these problems that you have described is from the drain pump bearing going out. If possible, run the washer with this panel opened and listen to the pump. If the noise you hear is coming from there replace the pump with the new designed pump. Here is the pump to order. To replace the pump, tilt the washer back and remove the belt, then remove the two hoses from the pump and then the three screws that hold the pump on. If the pump is not the problem, post back to me.
Nov 16, 2012 | Washing Machines
Spin Cycle "Whines" and keeps spinning after cycle is complete
need make & model # to correctly solve problem, it could be timer shorted or the drive motor has gone bad.
Oct 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Washing machine making whining noise during spin only
Its a bearing on its way out. the seal is also probably worn.
May 06, 2009 | Amana Washing Machines
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Dishwasher makes a whineing or squealing noise during wash cycle. No noise during filling and draining.
Motor has something in it ( dirt,dust etc..)If it gets worse replace the motor.
May 25, 2008 | Kenmore Dishwashers
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
Noise
Eileen, If the screeching is only happening on the fill and not during agitation or spin, I think we are safe to rule out the belt, pulley and bearing. Remove the fill hoses from the back of the washer and check to see if you have sand or gunk caught in the screens of the valve itself. If they are clear sounds like the water passing through the valve is making the noise. Another thing to check is the water pressure in the house. It should be around 55 psi., 75 psi max. I have seen it as high as 120psi with a bad regulator. This will cause noise and all kinds of problems. The part number for the fill valve is 131389300, according to the model posted....Catriver...post back.
Aug 27, 2006 | Frigidaire FWS833A Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
74 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
