Question about Kodak EasyShare Z650 Digital Camera
My lens is stuck!!!
The lens on my camera is stuck!!! When I turn off my camera the lens doesn't go back in its home. And vise versa.!!!!
  • Anonymous Mar 29, 2009
    the telescoping lens is stuck out and won't go back in...this makes my camera unable to even take pictures anymore, it just makes noise when I turn it on and then turns itself back off...):
    Problem Solver:
  • 8 Answers
Your lens frame - that which moves out when the camera opens is probable bent. Looking down at it from the top and sides, does it look bent? By grasping is firmly but not hard try softly to bend the lens frame in the opposite direction, carefully.
Posted on Feb 19, 2009
Hi. my problem with my camera is that my niece play with it and she pushed the lens mechanism while the camera is on. now, the lens was stuck and doesn't comes out anymore. when i'm turning on
Force it out like it was forced in. Try to rotate the lens. Remember it has to be off. As soon as the lens is half way out, turn the camara on and the lens will go to its position. If not, while the lens is out turn it left or right until it's back to its position.
Good luck.
Aug 24, 2012 | Sony Cyber-shot DSC-W55 Digital Camera
Some how my Samsung SL820 digital camera's shutter door got stuck and it is not closing how many ever times I try to switch the camera off and on. Because of this the camera doesn't work. I've...
Did you happen to drop it accidentally? Or accidentally applied force into your camera? If yes, then there is big chance you will gonna have to replace the whole lens! If not, then it might just be dirt stuck inside your lens mechanism. To fix it, hold your camera with the lens facing the ground. Then, tap your camera repeatedly. Start with light tapping to moderate. If that doesn't work, spray condensed air directly into the lens part of your camera.
Sep 21, 2011 | Samsung SL820 Digital Camera
Driver side window gets stuck
Most likely you need a window regulator/motor assembly. Depending on when it gets stuck, you may have a faulty window switch also. If the window goes down ok, but then doesn't want to come back up, or vise-versa, I would suspect the switch rather than the motor.
Aug 17, 2011 | 2000 Pontiac Grand Prix
My sony DSC H4 lens is stuck outside and it doesn go in .. the lens moves back and forth and is stuck ... the lens is also unable to focus.
Hi, Have you dropped your camera on the lens since I've seen that cause it before. If not then it's possible that the motor in the lens has gone. Either way it would be a costly repair which there's a 50/50 chance it would actually work again. Your best bet would be to get a new camera.
Jun 18, 2011 | Cameras
Lens is stuck and camera will not turn on.
there is a problum in your lenze block (optical assy) this problum is not remove at home so please go to your nearst sony service centre & repair the lenze block because no the child parts are avalable
Feb 12, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
My lens is stuck!
Sometimes this can happen if the battery cover was accidentally opened while the lens was moving. Try something simple. Turn the camera off. Open the battery cover and remove the batteries for 5 minutes. replace the batteries and secure the cover. Turn on the camera. The lens should go to it's home position. Let me know if this helps. And thanks for coming to FixYa. Don't forget to rate my answer!
Rob
Feb 08, 2009 | Polaroid T831 Digital Camera
Nikon 18-55mm lens is stuck , even when not on camera how can i fix it
By "stuck", I'm guessing you mean the focus. Flip the switch on the lens from 'A' to 'M' if it is.
If the lens won't zoom, hand it over to your local camera lab for repair.
Jul 27, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Kodak Easy Share Z1275 stuck lens
I have a Kodak 1275. Green light would go on the off and lens was stuck open. Now for solution that worked for me. Get a can of compressed air, like what you use for computer keyboards. Blow the compressed air all around your stuck open lens, not to fast and switch directions of where you blow air around stuck opened lens. Make sure batteries are fresh and fully charged. Tap your camera against the palm of your hand twice, not to hard or you may damage instead of jarring lens lose. Next lay your camera on a table lens facing up, push power button on so camera will try to auto focus and lens should reseat itself and lens should move freely. It doesn`t have to look dirty or dusty, little tiny particles can cause the lens to get stuck and shut off fast because it is a safety feature. If this does not work try plugging your camera into computer so the lcd screen does not try to go on , thus giving even more power to get your lens moving . Do not try to force it closed by pushing or twisting with your hand or you may cause damage that will cost as much as the camera to fix.
Jun 05, 2008 | Kodak EasyShare Z1275 Digital Camera
Camera lens stuck out and wont turn on
I purchased my Canon SD 1000 a couple months ago and as soon as I owned it one month I had lens problems. Stuck shut stuck open and now its still stuck open. I take care of my camera and carry it in a case all the time. This is my second rodeo and there wont be a 3rd,
CANON IS DONE GETTING MY MONEY
Jan 20, 2008 | Nikon COOLPIX L2 Digital Camera
Lens not stopping down
sometime it may happen, put the camera body without lens put it on the speed of b see when you klick the camera the shutter will go up and also mirror then the body is ok , put the lens sapratley you will see one small part is over the mount when you rotate it the lens appurture is opened and close u can put the f2.8 the ere is closure of appurture when you move the knob like wise u change the app and vise versa
Feb 09, 2007 | Hasselblad 80mm f/2.8 CFE Lens
Kodak EasyShare Z650 Digital Camera Logo
275 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
