Question about Sharp SF 2020 Copier
MY COPIES COME OUT WITH A DARK BLACK THICK LINE ON THE PAPER SHARP SF-7320
  • Sharp Expert
  • 257 Answers
Check the heat roller and clean or replace.
Posted on Dec 01, 2009
  • 148 Answers
More then likely you need to have the drum cleaning blade and/or the drum replaced on this copier. Not a real easy thing to do and may need to have a tech do it for you.
Hope that helps...
Lbcoaster
Posted on Feb 19, 2009
Sharp SF-7370 copier, with a dark line going from top to bottom
check the drum cleaning blade maybe the blade is worn out
Jan 04, 2010 | Sharp Office Equipment & Supplies
Thick black line in all copies on sharp arm 162e
Dear,
when drum clean blade is weak then strongly can not clean toner,so thick black line in all copies.
Solve: Replace clean blade or service.If your copier drum life is zero,you can change it.
Nov 16, 2009 | Sharp AR-M162 All-In-One Laser Printer
After changing toner on my sharp, SF-2022 copy machine, the copies are coming out with black smudge marks across the paper? how/where should i clean?
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
Nov 13, 2009 | Sharp Office Equipment & Supplies
Sharp SF-7320 produces grainy copies
Clean the drum unit seal blade thats leaking or replace it.
Nov 11, 2009 | Office Equipment & Supplies
Copy machin SHARP SF-7320
Check the copy lamp and its thermal fuse if they are okay, then clean optics, check drum and blade and clean or replace and finally clean or replace fuser rollers. If the above is ok and still black copies, check the copy lamp wire harness for continuity or the copy control board located underneath the display panel and check for bad component like triac and replace. If OK replace the main control board.
Sep 21, 2009 | Sharp SF 2020 Copier
Full black
Check copy lamp if its lighting during copying if not Switch off and remove socket outlet and check lamp and thermal fuse . Clean optics.
SHARP SF-7320 doesn't start
Also adjust your front door which acts as a switch.
Apr 02, 2009 | Sharp SF 2020 Copier
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Oct 25, 2008 | Sharp AL 1215 Black and White Copier
Lanier 7320 - Makes only all black copies
Was the toner bottle removed before you moved the machine?
Jun 09, 2008 | Office Equipment & Supplies
No bottons are working
This means the developer unit is not installed . Check and instal.
May 16, 2008 | Sharp SF 2020 Copier
226 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
