Question about Brother LS-2125 Mechanical Sewing Machine
Not threading I was sewing heard a big "knock" and then saw that it wasn't ewing correctly. I removed the material and re-threaded the machine. The bobbin thread was not being pulled up by the needle. How do I fix this?
  • 374 Answers
There are several factors to be consider if the machine was not threading kindly check the upper thread tension should be complied to the fabrics,check also the tension the bobbins thread
theres small adjusting screw on the bobbins,the thread that come out to the bobbins should be on the counter clockwise rotation,set the acquired stitch adjustment,check the needle alignment and then manually turn the handwheel if the needle thread hook up the bobbins thread also it would be helpful if the feed dogs is clean and free from dust and chips fabrics and chips thread.
Posted on Mar 07, 2009
I cannot get the tension correct - big loops on the back with Gutterman all-purpose thread. Have cleaned tension discs and adjusted bobbin tension screw. Checked for correct bobbin and needle thread.
bird nesting ( big loops under material) is from the needle thread tension being too loose
thread the machine as if threading the needle but before threading the needle pull on the thread , there should be resistance to thread feed
if not the tensioner plates are not adjusting properly
Sep 17, 2017 | Sewing Machines
My elna experience 660 is bunching threads in big loops on the back of the fabric and the needle bent and hit the needle plate. It's sounding clunky
Install a brand new needle.
Remove the top thread from the machine (ALWAYS cut the thread at the spool, raise the presser foot, and pull the thread down through the needle eye.)
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
If it still does not sew properly or sounds clunky, take it for service. It could have been knocked out of time or bent something.
Jul 01, 2017 | Elna Sewing Machines
What is normal tension settings on a kenmore model 158.12112
The tension depends on what you are sewing but usually a 4 -5. Also make sure thread and needle are the correct size for the materials you are sewing. and make sure needle and bobbin are threaded correctly and that needle is not, blunt or bent. :)
Mar 21, 2017 | Kenmore Sewing Machines
Fashion Mate 248. The top stitch is fine but will gather too much under the material. Wraps around the bobbin holder and tangle up into the bobbin thread. Does anybody know whats going on?
That is what is referred to as bird nesting or thread nesting. It usually results from mis-threading, the thread not being fully seated in the tension disk, or the tension set too loose. (I have a machine that does this frequently because the thread "jumps" out of the take up lever when sewing fast--instant thread mess.)
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Make sure the thread path is correct. Set the upper tension to the midway point between high & low number. (You will probably need to tweak the upper tension because every machine differs over time, but the midway point is the factory standard setting.)
While you are at it, check to make sure the bobbin is loaded and threaded correctly in the bobbin case.
If you continue to have issues, you may need to take it for service.
Sewing Machine Thread Bunching Up Here Why
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
Dec 10, 2016 | Sewing Machines
Have a Singer 11910000A and the bobber thread bunches up and makes a mess in the feet when sewing
Is it really the bobbin thread that is globbing? Check closely. Usually it is the upper thread accumulating under the fabric.
If it is in fact the bobbin thread, then the bobbin case is not threaded correctly, the bobbin case tension needs adjustment, or it is broken and needs replacement. There are web sites and YouTube videos that show how to adjust the bobbin case tension.
QUICK FIXES: Remove all the thread from the machine. Clean the area around the feed dogs and bobbin area. Oil as instructed in the owner's manual using ONLY fresh, good quality sewing machine oil (only 1-2 drops each spot). Install a brand new needle insuring it is installed correctly. Avoid using fuzzy, old, or bargain bin thread. Rethread: Be sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk--and check to make sure you are threading the machine correctly. Check that the upper tension is set properly (the factory standard is usually the halfway point between the high & low number on the selection). Test on a scrap of the fabric you wish to sew. Adjust the upper tension--either tighten to pull the upper thread toward the top of the fabric, or loosen to pull more upper thread down.
Here are some web sites that may help.
sewing machine birdnesting
https://answers.yahoo.com/question/index?qid=20100303212248AAnRUQA
8 Tips to Fix Birdnesting in Embroidery
http://www.marthastewart.com/1085057/common-sewing-machine-repair-tips
and here's another Hint that may be helpful:
https://www.youtube.com/watch?v=KDERq4I7l-Q
Dec 29, 2015 | Singer Sewing Machines
It wont stitch tee/shirt material it misses stitchs
If machine misses stitches consistently, it can be several things.
Needle not installed correctly, not threaded correctly, Bobbin case not installed correctly, make sure the bobbin itself is inserted correctly and spinning in the correct direction.
Finally, machine may need service the timing is off. All actions of a sewing machine are carefully "timed" to form a stitch while sewing. Sewing things that were too heavy for the machine or you hit the bobbin case while sewing can knock the machine out of adjustment.
Let a professional do the maintenance on your machine. Some may opt to show you how to do more in depth maintenance yourself at home.
Cheers,
Feb 01, 2013 | Sewing Machines
Install bobbin in euro-pro X 464XC
Either your machine was not threaded with the presser foot wasn't up when you threaded the upper thread... or your upper tension isn't tight enough.
Good luck.
Sep 14, 2012 | Euro-Pro Fast and Easy 420 Mechanical...
Machine is not sewing properly
use larger needle, check bobin thread, bobin should go one way, if it bunches up switch dirrection the bobin turns
May 23, 2009 | Bernina Virtuosa 160
Machine jammed wheel will not turn needle will not move
Thread is caught in the hook...Remove the upper thread and bobbin case, turn the hand wheel backwards and forwards by hand and remove the thread remands
May 17, 2009 | Brother CS-8060 Computerized Sewing...
Brother LS-2125 Mechanical Sewing Machine Logo
112 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
