Question about Acer AL1916W 19" LCD Monitor
AL1916W displays for a second and turns black
My monitor displays for a second at the change or on turn of/on and then turns black. So it shows starting bios, then for a second starting windows, once windoiws starts i can turn on and of and have it displayed for a second. Monitor is about 2 years old and it happened suddenly.
    President:
  • 2,992 Answers
This is because the backlight is going out, and without it you can't see the image on the display. (If you look closely you can sometimes still make out faintly what's on the screen.)
The trouble is frequently because of capacitors in the monitor which fail. Often these parts (cylinder shaped, usually a couple of inches tall and an inch or so in diameter) have visible problems such as tops that have bulged or split, or brown leakage at the bottom on the circuit board. If you're adventurous, you can take the back off the monitor and check.
If you find any capacitors that look questionable, you can get replacements at Radio Shack or from online parts sellers. Capacitors have markings on them for their value in microfarads (abbreviated as mF or uF), a voltage rating, and a polarity. Some caps have the positive terminal marked and some the negative. Just note which goes where on the circuit board. Get replacements that have the same capacitance value, but a slightly higher voltage rating. They will be a little larger physically but should still fit, and under-rating is what usually causes the failure in the first place. Observe the polarity when installing the new parts.
This all sounds a little scary perhaps, but it's really not a difficult repair. If you're not comfortable with the idea of trying it yourself and you don't know any technically-inclined types who are willing, a TV or stereo service shop could do it. But with labor and their markup on parts, you might spend over half the cost of a new monitor.
Posted on Feb 22, 2009
Having this problem myself, (the monitor in question being little over a month old when it started) I've found a workaround.
Pressing the 'e' button at the bottom of the screen presents you with a few preset options. Scrolling back and forth between them a few times will keep the screen displaying 99% of the time.
Don't forget picking a preset you actually like. ;)
Posted on Mar 01, 2009
Screen turns off seconds after image is displayed
are using dvi cable is yoour out put on the cpu ok video out video card ect u test antehr screen on it test this one on differnt one if it bad its bad u cant usally get parts for these priotory
Feb 04, 2008 | Acer AL1916W 19" LCD Monitor
Acer AL1916W about 2 years old. Turned on this
Bad caps in the power supply, common problems with 2-year old monitors, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | Acer AL1916W 19" LCD Monitor
My acer al1916w displays the image for 3 seconds then goes black
Sounds like your video card. Check to make sure it's connected properly. If so, check to make sure it's properly seated to *********** board. The possible issue could be the card is connected enough to display the picture, but not enough to communicate with the monitor to stay on because it has an active feed. Best of luck fixing it
Oct 14, 2009 | Acer AL1916W 19" LCD Monitor
Monitor keeps blacking out, I need to do a power drain but can't remember how to do it!
i have the same problem i think. like, if i dont use it for a long time, it'll display a nice perfect image, but then it goes black. everytime i turn it on after that its only about 3 seconds then it goes black. i have 2 monitors right now and i know its not my pc.
Oct 09, 2009 | Acer AL1916W 19" LCD Monitor
ACER Al1916W goes blank in 3 seconds. It shows ACER splash screen for a sec., the desk top for .5 sec, then goes black. There is a very high pitch squeel each time there is any display. Power switch turns...
Yes, The inverter is the problem on your monitor. We have a step by step guide to dis-assemble and repair your monitor posted on our web site at:
www.ccl-la.com/monitor_repair.htm Your model is the same as the westinghouse L1875NW. We have a parts kit for $12.00 if you need it, it can be purchased on the guide page. If you don't want to do the repair yourself we can do it for $35 + shipping. This is a common problem with that series of monitors but the repair will get you back going.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1916W pluged into lap top but can't get both to run.
Have you used the Fn button on your laptop and changed the video display Icon on the Blue Function keys. You need to change the display wait a few seconds for it to take affect. There are several modes try them all so you know how to use them.
Mar 20, 2009 | Acer AL1916W 19" LCD Monitor
Moniter turns on for 2 seconds turns off
hi guys, first run the system in safe mode, and with vga mode, see if it is the same problem ?? let me know
Dec 30, 2007 | Acer AL1916W 19" LCD Monitor
Graphics Make Screen go black
Yess...Go DISPLAY PROPERTIES - SETTINGS - ADVANCED CHECK GENERAL AND MONITOR!
Also go to your bios and make sure that PLUG ANG PLAY IS ON ( YESS )
Oct 14, 2007 | Acer AL1916W 19" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
254 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
