Home | Canon | imageRUNNER 2200 Black and White Copier | Error code E00012-002
Canon imageRUNNER 2200 Black and White Copier
Problem for Canon imageRUNNER 2200 Black and White Copier
By schavez on Feb 19, 2009
It displays screen to turn off and back on. Error code E00012-002 is there anything i can do to fix this?
Clarification Request
Posted by dan canonman on Sep 12, 2009
E012 is not a code in the manual are you sure this is correct code?
Posted by millstones on Mar 23, 2009
Strange, can't find any mention of e00012 n the service manual.
Solution #1
posted on May 06, 2009
Not Rated)
joslloyd
Rank: Guru
Rating: 86%, 37 votes
If I recall correctly, e12 is a jam code. Power the unit off and look in user serviceable areas for paper bits. inspect sensors for paper bits. reseat external finisher unit. power back on. you may have a bad paper sensor in the unit.
Was this helpful?
Yes
No
Popular Solutions for Canon imageRUNNER 2200 Black
Questions and Unsolved Problems for Canon imageRUNNER 2200 Black
Do you recommend Canon imageRUNNER 2200 Black and White Copier?
Answer
Answer
how do you lock a canon ir7105 for transit?
Answer
how to remove the MITAC kyocera km 1500 repair and remove or reset the error code c-6 20
Answer
I have a Canon 210s / F139800 that is connected to the local network but I cannot access the printer... (More)
Answer
My Canon imageRUNNER 2200 won't print envelopes. How can I get this function to work?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon imageRUNNER 2200 Black...:
Top Copier Experts
Rank: Guru Guru
Solutions: 1495
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
