Question about Boston Acoustics MicroMedia Computer Speakers
Digital BA 735 speakers don't give sound on my new computer.
Original BA 735 speakers came with my old Gateway computer. Are they compatible with anything else? Can you direct me so they will work with something other than a Gateway coomputer?
  • John Heilmann Mar 29, 2009
    got a new computer and the old speakers hum with it.
I have old Boston BA735 digital speakers that I am trying to get to work with a new HP PC. Do I need drivers? There are 6 places to plug in speaker cables on the back of the PC. Which ones do I use?
Many of the new sound cards and especially sound cards on OEM do not support digital speakers without buying additional connectors. (Not sure why. I have these same great speakers for years and they are wonderful.
- Check if your sound card ha an SPDIF connection option. - Check the speakers in the device manager to see if you can toggle the "digital" option. - I also have read that some versions of the BA 735 have an analog option on the back of the subwoofer if you need to bypass digital. (mine don't, so I don't know if this is accurate)
Aug 12, 2011 | Boston Acoustics BA735 Computer Speakers
Can i use my boston 5.1 speakers with a powered sub with my new computer system.it used soundblaster software?
The speakers themselves don't care what you have them connected to. They just take an audio input from the computer, which is a function of the computer's sound card and drivers. As long as the computer hardware is working properly, the speakers will too.
There is one possible problem, though. If these speakers came with your computer as part of a Gateway system package several years ago, they may be a digital-input version only. Gateway supplied these speakers and a Creative Soundblaster card that had a digital output was installed in the computer. The way to tell on your speakers is to look at the plug on the end of the cable. Which of the two below looks like yours?
If it's the one on the left, you can use the speakers with any analog sound source (computer, iPod, etc.). But if looks like the one on the right (a mono plug), you have the digital speakers. Unless the sound card in your new computer has digital output available, the speakers won't work. In the past, I was able to put the original sound card and drivers into someone's new computer and it worked, but the original software is not compatible with Vista or Windows 7.
Hope this helps you get it figured out. Thanks for using Fixya!
Dec 02, 2010 | Boston Acoustics BA7500 Computer Speakers
How can i get the boston digital ba735 to work on my computer?
if now your computer not support this speakers,you must buy new soundcard support this speaker then build in to your computer hardware.good luck
Apr 28, 2010 | Boston Acoustics BA735 Computer Speakers
Had a old Gateway computer with Boston Digital BA735 speakers using XP. Upgrade computer to a N68PV-GS motherboard and have analog output for the speakers. How to I get the old speakers to work?
You can't, at least not with the integrated sound. The speakers only take digital input, and the Gateway had a digital sound card installed. That new board of yours has PCI slots available. You might be able to use the old Gateway sound card. I've never tried it, but XP might recognize the card and have native drivers. If not, you might be able to find XP drivers at Gateway's site. Otherwise all you'll be able to do is buy a new set of analog speakers.
Feb 21, 2010 | Boston Acoustics BA735 Computer Speakers
No sound coming out of speakers green light on speakers is on
The BA 735 Speakers I have are purely digital and will only work if your soundcard has a digital output, will not work through the normal analogue green socket .
Jun 19, 2009 | Boston Acoustics BA735 Computer Speakers
The BA 735 speakers that came with the old Gateway I have does not work with the new iMAC
The BA 735 Speakers I have are purely digital and will only work if your soundcard has a digital output, will not work through analogue connection.
May 05, 2009 | Boston Acoustics BA735 Computer Speakers
My speakers will not play on my computer
Those speakers were originally supplied with Gateway computer system that had sound cards with digital outputs. While some versions had analog and digital sound inputs, most often the speakers had digital input only. The on-board sound in the eMachines is analog output only, so the speakers are most likely not compatible with your computer. If you want to use those speakers, you will need to locate a PCI sound card with digital output.
Mar 08, 2009 | Boston Acoustics BA735 Computer Speakers
Speakers not working
do i need a disk to dwnload these to work on my computer
Aug 09, 2008 | Boston Acoustics BA735 Computer Speakers
735 speakers
Use the "Analog In" jack on the sub-woofer and NOT the " Digital In". That's when they start working.
sumother set of these SAME speakers DOES NOT have an "Analog In" jack. So give them to a local thrift shop.
note: Boston makes 2 different speaker sets with the same name,
BA 735: one with and one without the "Analog In" jack.
Jul 04, 2008 | Boston Acoustics MicroMedia Computer...
No sound
Open the sound settings from your control panel. click & open all possible icons & options & change it & remember it what you done and try by combination. one of the option like boost/ line area may be deseabled so the problem occur.
Feb 11, 2008 | Boston Acoustics BA735 Computer Speakers
Boston Acoustics MicroMedia Computer Speakers Logo
457 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
