Question about Teac Office Equipment & Supplies
Teac p-55 shuts down and restarts after loading disc
Teac P55 with Verity Copy Disc Platinum and True Net software.
After sending a graphic from the truenet software the verity loads the disc onto the tray of the teac, the teac door closes and about 5 seconds later, it makes a sound likes it's rebooting the system and then the screen says, "warming up" and then "ready."
you can view a video of the problem at;
http://www.greenroomprod.com/teac/teac.wmv
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Based on your description of the problem, I am tempted to suspect a power supply issue, specifically an intermittent undervoltage. This could be brought about by fluctuating mains or a leaky capacitor in the internal power supply unit. I doubt if the printer engine or any of its component is faulty or if it could be a driver/software issue. If it were, then the error light would be lit. Additionally, the symptoms indicate that the unit performed a soft reboot and therefore started to perform a 'warming up' mode again.
Initially, you can try:
  • ensuring both the exhaust and intake fans are ventilating the Teac unit,
  • the intake filter is clean;
  • and/or power/plug the Teach through a suitable voltage regulator and/or UPS rather than straight to the mains.
Being a mission critical equipment in your production, I would not suggest component level repair but rather a full replacement of the power supply should that be deemed faulty. A way to check the power supply is to monitor the output voltages using DVMs. If the voltage drops prior to the fault, then you have just confirmed the undervoltage condition. A service manual would be to your advantage or at the very least a schematic diagram with voltage readings.
Good luck and thank you for using FixYa.
Posted on Feb 19, 2009
    Brigadier General:
  • 3,614 Answers
is there any error message appear, or any error code display.
thanks
  • micromaster
    micromaster Feb 19, 2009
    i see the video, have you try to use or do a disc cleaning on the unit..?
    better restart again the machine.
TEAC pdv575 not picking up dvd discs. if disc is inserted, runs fir a while showing "loading" on screen, but then stops, and shows "no disc"
Check and replace its laser pickup unit. It is weak. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Feb 12, 2017 | Teac Televison & Video
I own the TEAC FD-05PUB. I am using it with a intel imac software version 10.6.6 I have been unable to get my drive to load any floppy disc. I would appreciate your assistance. Thank you, Mark
Stupid question: are you trying to use a PC floppy drive to read PC floppy disks on a Mac? I don't think this kind of operation would have a positive outcome....
Feb 07, 2011 | Teac FD-05PUB External Floppy Drive
My Teac 1x1 dvd/d11A/kit burner/Dvw/D11A: will not copy Dvd, keep getting the message: "target drive not ready". Unit copies cd's alright.
whatever software you are using to burn dvd;s, make sure the right burner drive is selected. if it is selected properly and still having an issue. that means the dvd writer is busted and can't detect a blank disc place into it. in that case, have it replaced.
Nov 06, 2009 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
Teac PD-1200 Compact Multi Disc Player
This is a faulty loading motor. you will need to replace the entire optical lens assembly in this case. the motor is part of the assembly.
May 29, 2009 | Teac CD-P1120 CD Player
TEAC DW 552g DVD/CD rom combo drive, CD works, DVDs dont
I have your solution, but you are NOT gonna like it, so I hope you will rate it FAIRLY, even though its relatively BAD NEWS.
TAKE A LOOK AT THIS:
Teac (DW552G/KIT/USB2) CD-RW/DVD-ROM (Combo) Burner The Teac (DW552G/KIT/USB2) CD-RW/DVD-ROM (Combo) Burner deliver unbeatable CD speeds of 52X write to CD-R, 32X re-write to CD-RW media and 52X read as well as 16X DVD playback speeds and the drive features an advanced buffer underrun prevention technology. This disc-saving feature suspends the recording process until the buffer is refilled. No more bad discs even when you’re multitasking. It also supports EasyWrite (Mount Rainier), a new disc formatting feature that makes it easier and saves time preparing CD-RW discs for recording. Teac W552G (cdw552g/kit/b) CD-RW Burner Newbie The Teac W552G (cdw552g/kit/b) CD-RW Burner operates with: Microsoft Windows XP, Microsoft Windows...
YOUR DRIVE DOES NOT BURN DVDs, only CDS!!!
Apr 23, 2009 | Dell Latitude D520 - Celeron Intel Celeron...
Teac dvd player
U LASER NEEDS REPLACEMENT
Dec 07, 2008 | Audio Players & Recorders
Teac dvd player
how old is your machine? if old enough isuggest you change the lens and try if it can load faster than before
Aug 01, 2007 | Teac DV-3500 DVD Player
Top Teac Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Teac Office Equipment and Supply Expert? Answer questions, earn points and help others
