Question about Yahoo Messenger
I am not able to sign in the messenger. tried to uninstall it, did not work, tried to delete the folder, no success
  • 3 more comments
  • rozebud4u200 Feb 19, 2009
    I downloaded yahoo messenger9 and it wont let me sign in. I unistalled it and re installed it again and still the same. going grazy here can anyone help..
    Thanks Suzy
  • setrakiann Feb 20, 2009
    to Kyrpton: yes when i try to sign in i get an error, a box appears as "change user"- "change password" - "try again"
    so i try several times and still cannot sign in. i even changed passwords and so on. problem persists. but i can use my yahoo email account, even the web messenger pretty normally.
    p.s. i tried to remove the program, but i cannot see it when i go to add/remove...
  • nmsurf73 May 11, 2010
    how can i get my password of yahoo messenger
  • Kyrpton
    Kyrpton May 11, 2010
    Have you tried reinstalling without uninstalling the Yahoo! Messenger that current exists (that you cannot find) ?
  • Kyrpton
    What happens when you try to sign in? Do you get an error, or does it just do nothing? If you get an error, what does it say? Thanks.
How my yahoo mesenger can work to my pc?
Posted on Feb 20, 2009
Hello ! My name is Cristi and i have a problem with my yahoo ID and e-mail account. From almoust 3 months...
First, try signing in with your Yahoo! ID here: https://imo.im/
You should be able to log in there. To fix error 81003002, you will need to do a complete removal and reinstallation of Yahoo! Messenger. I will give you 2 of the best ways to go about this:
The first way is to use Revo Uninstaller. (Recommended, requires a program installation)
( found here: http://www.revouninstaller.com/start_freeware_download.html )
You can use Revo to uninstall Yahoo! Messenger, making sure that you do at least a moderate level scan of your system using Revo. Delete everything that Revo asks you to. This will make sure that all files and keys related to Yahoo! Messenger are also erased from the system.
The second way to uninstall is to do it manually. (NOT Recommended, no installations)
Open your start menu, then click Control Panel. Navigate to "Add/Remove Programs". Find Yahoo! Messenger in the list, then uninstall it. Reboot if prompted. After it successfully uninstalls (reboot if prompted), go to "C:Program FilesYahoo", or if it is not there, "C:Program Files(x86)Yahoo". If you see a folder called "Messenger", delete it.
Reboot your computer, then reinstall the latest version of Yahoo! Messenger. You should be able to login now. If you are unable to log in, and you uninstalled Yahoo! Messenger using the second method, then you will have to use the first method.
Mar 30, 2011 | Yahoo Messenger
Don't send error when i click sign in i tried to reinstall it. don't works.
Try to do this...
First Uninstall Yahoo Messenger.
Run RegEdit then back up your registry. right-click on the computer icon and click export to back-up your registry, save it anywhere you want.
Then go to HKEY_CURRENT_USER\Software\ find the yahoo folder then delete it. and go to HKEY_LOCAL_MACHINE\Software\ find the yahoo folder then delete it.
Run search>>>All files and folders Type YAHOO in "all or part of the file name:" lock in your local hardrive>>choose more advance option check the search for hidden files. Delete all files of yahoo.
uninstall your internet explorer. go to RegEdit >>> HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\ then delete the zone folder. Then go to HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Internet Settings\ then delete the zone folder.
Download Registry Cleaner to clean up your registry. Restart your computer.
Download and install internet explorer after download go to>>> internet option>>>Security>>> Reset all zone to default value or enable your activeX
Download and install Yahoo Messenger.
Run and Good Luck.
Nov 13, 2010 | Yahoo Messenger
Cannot download ym it shows check firewall setting
You can disable your firewall setting when its hard trying to download Yahoo Messenger.
How to do that? Try this:
1. On your windows, click Start.
2. Click Control Panel
3. Double click Windows Firewall
4.On the General tab, select OFF(not recommended) and click OK
That's it! Your firewall setting is disabled and you can download yahoo messenger without being stopped by a message error.
If you have successfully download Yahoo messenger by disabling windows firewall and still cannot sign-in, you will be needing some tips on how to solve connection issues for Yahoo Messenger. Check this helpful tips http://www.fixya.com/support/r5025589-easiest_way_solve_yahoo_messenger
Please comeback and give me some ratings if this one help you.
Thank You for using Fixya!
Jun 06, 2010 | Yahoo Messenger
Why can't I install yahoo messenger 10.0 successfully? after attempting to install, an error will prompt which says ''yahoo messenger did not install properly; this may be due to an open application or...
You need the following OS to support Messenger
Windows 2000/XP/2003/Vista/XP64/Vista64
If that is not an issue read on.
The problem may be due to a mal-function of the uninstall software.
Close all programs when uninstalling / downloading and uploading.
If you tried to uninstall from the Control Panel and failed to back it up with a visit to the C drive, you may have old software conflicting with the incoming software trying to share the same folder.
If you have Vista the whole Messenger folder should have been removed during the uninstall.
Check
Start > Computer >> Local drive (C) >> Program Files >> Yahoo >> Messenger. - The Messenger folder should have been deleted and not seen. If the Messenger folder is still visible - delete it.
If you have a pre-Vista OS, the Messenger folder remains, and inside, only one sub-folder should be seen. This is the 'Profile' folder and contains all the message history. All other software should have been deleted.
Manually delete any other folders and files before moving on
Download 'ccleaner' and run it through a couple of times.
http://www.filehippo.com/download_ccleaner/
Re-start your computer and download Yahoo Messenger from here.
http://www.filehippo.com/download_yahoo_messenger/
Nov 20, 2009 | Yahoo Messenger
Cannot download new version of yahoo messenger
first of all uninstall the old one completely and then try again
Sep 29, 2009 | Yahoo Messenger
I can not download yahoo 9.0
check the firewall settings of your server/administrator. the application download has been blocked for security and other purposes.
if they won't allow you to, try to download it with other servers that have no restrictions.
Aug 11, 2009 | Yahoo Messenger
All my contacts are missing from my contact list
This is what MS told me to do..but did not work. Finally they told me to use 8.5. Try if it helps you.
Messenger Connectivity Log & Contacts Log
A. Delete the old log files.
Right-click the Start button and then click Explore. In the window that opens, click Folder Options on the Tools menu. Click the View tab, and then make sure that Show Hidden files and folders option is selected.
1. Click Start, click Run, type %userprofile%\Local Settings\, and then click OK.
2. Double-click the Application Data folder, double-click Microsoft, and then double-click Messenger.
3. In the Messenger folder, look for the MsnMsgr.txt file and delete it.
Note: If you get an error stating that you cannot delete MsnMsgr, please make sure that Windows Live Messenger is not running on the background. To check this, open the Task Manager window and check whether the msnmsgr.exe is running on Processes. If it is, select the application and click End Process. If you are prompted, click Yes.
To open the Task Manager: Click Start and then Run. Type taskmgr.exe and click OK.
4. If you don't see the MsnMsgr.txt file, please proceed to step B to enable the connection logging.
B. Turn on connection logging if the feature is not yet enabled.
1. Start Windows Live Messenger but do not sign in.
2. On the Tools menu, click Options.
3. In the left navigation bar, click Connection.
4. Click Advanced Settings.
5. Under Connection Logging, make sure that the Save a log of my server connections to help troubleshoot connection problems check box is selected.
6. Click OK.
C. Try to sign in to Windows Live Messenger again to replicate the error or issue being encountered with the service. A new connectivity log file, MSNMsgr.txt, is created the moment a sign in attempt to the service is made. When errors or issues are encountered, the connection logging feature will capture their logs.
D. Access the newly generated MsnMSgr.txt by following the steps in step A. Please look also for the ContactsLog.txt file. Please attach the files on your e-mail response to us.
Copy of the Windows Live Contacts folder
The Windows Live Contacts folder can be accessed on this path:
C:\Documents and Settings\ Your Windows logon name \Local Settings\Application Data\Microsoft\Windows Live Contacts
Note: Windows Logon name is the logon name that you use to sign in to Windows.
Right-click the Windows Live Contacts, select Send To, and then select Compressed (zipped) Folder. A compressed file is created in the same folder. Please upload the file to Windows Live SkyDrive and we will retrieve the file from there.
To access Windows Live SkyDrive, please do these:
  1. Open your Internet browser and visit http://skydrive.live.com.
  2. Sign in using your Messenger ID and password.
  3. Click on the Public folder.
  4. Click Add files and locate the zipped Windows Live Contacts folder. Upload it.
  5. Once the file is successfully uploaded, please send us the URL or link on your e-mail response so we can download it.
While we are working on this issue, we suggest that you temporarily use the earlier version of Windows Live Messenger (v8.5) so you can continue to communicate with your friends. Please note that to be able to install the previous version, you need to uninstall all the Windows Live Essentials programs (i.e. version 2009 of Messenger, Mail, Photo Gallery, etc.).
1. Exit Windows Live Messenger.
2. Click Start, click Run, type appwiz.cpl and press Enter
3. On the Add or Remove Programs window, click on Windows Live Essentials, and then click Uninstall/Change
4. Select Uninstall, click Continue.
5. Under Select the programs you want to uninstall, check all the Windows Live programs shown and then click Continue.
Windows Live Messenger 8.5 can be downloaded from:
http://www.microsoft.com/downloads/details.aspx?FamilyID=7a1aae73-48cc-4f7a-b445-0487bd5e84ef&displaylang=en
Apr 29, 2009 | Microsoft Windows Live Messanger
Signing on to yahoo messenger 900-2034.
try uninstall again the yahoo messenger select complete uninstall, remove also backup data if system ask and after uninstall complete go to C:\Program Files\Yahoo! folder and delete Messenger folder, remove also in recycle bin, restart your computer and install yahoo messenger again. I suggest to install the Yahoo Messenger Full Standalone Installer, you find this at google search.
Nov 18, 2008 | Yahoo Messenger
PROBLEM SIGNING IN YAHOO MESSENGER
uninstall yahoo messenger from your computer
restart computer.
defrag drive,
delete temp files in temp folder:
start>run>%temp%...delete
start>run>temp...delete
start>run>prefetch...dlete
now try reinstalling YM. download the installer from majorgeeks.com
dont do the online install. this will work now
Mar 25, 2008 | Yahoo YHT-630 System
Yahoo Messenger Logo
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
