The remote control with new batteries will not turn on the TV. We try disconnecting the plue, flipping the surger and sometimes it will start somestimes it takes 20 min of trying to get it on. We have 32 inch LCT3201AS J
  • 10,594 Answers
Seems few capacitors are weak i power supply and deflection section of this TV and needs to be replaced.
To replace weak capacitors by yourself, you should have basic electronics knowledge, soldering skills and tools and related schematics of TV or call local TV repair shop for fix.
Posted on Feb 19, 2009
  • 2,326 Answers
If the TV needs to be unplug to work, It could have a defective power supply and that is why it takes longer time to power ON.
How old is your TV?
    President:
  • 2,110 Answers
The power button on the remote might be stuck...try to open the cover of remote and clean the contacts of the button..
My rmt-05 remote is not working after i put in new batteries
have you checked the polarity one the new batteries you installed? (flip the batttery updside down)
Aug 29, 2014 | Westinghouse RMT-05 TV Remote Control for...
I have a Philips 42" LED flat screen about 5 years old, all of a sudden when you turn it on I get the settings menu, when I try to click out it will bring up the picture and then within seconds it...
Tv have a shorted IC that control the manual control board side of the tv itself or the manual control board itself it is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish manual control board.Replace the manual tv control board first to test it out.If u still have the same result the IC that control the board itself is dead,now must take to the shop for repair.
Jun 09, 2011 | Philips Televison & Video
TV flips through channels at 2 channels per second.
It sounds like a button is stuck or bad. I would spray some electrical cleaner on the buttons 1st. If that don't work, the switch is probably bad.
Jul 23, 2010 | RCA F32645 32" TV
We have a 18 month old Panasonic plasma HD tv 46 inches. Without anyone touching anything, the tv will start turning the volume all the way up and then the channels start flipping. We've had the A board...
I know it sounds silly, but try changing the batteries in the remote.
Sometimes when the batteries are going dead they cause the remote to send random commands to the tv.
You may want to do the same thing with other remotes in your house.
If it works great, if not, it only cost a couple of dollars to try...
Good Luck!
Jan 03, 2010 | Televison & Video
Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
Remote won't work
reset the default setting go to menu button and manualy do this.....
Jun 19, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Universal remote-rcr3273
Pop the batteries out and use brand new batteries then try the code again. Sometimes its good to let the remote sit for a few hours with no batteries after locking up the codes.
Apr 30, 2008 | Televison & Video
Tv turns on manually, but auto flips through channels and you can't use remote
Found this in another forum (www.hometheaterspot.com) and it fixed my remote problem:
"...it's possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Sony TV keeps flipping to Memory Stick screen by itself
My sony HD TV started automatically flipping to the memory stick screen by itself. I thought maybe the remote was malfunctioning so I took the batteries out of the tv's remote as well as the cable boxes remote. Still does it. If I hit the memory stick button on the remote to switch off the screen sometimes it goes back to TV screen and sometimes it doesn't. Eventually, it flips back to the memory stick screen. Is this a known problem for this TV? your problem in system control section check aft &tuning ckt &its voltages check for loose contact in above ckt check tuner thanks
Sep 09, 2007 | Sony FD Trinitron KD-34XS955 34" TV
Remotes not working for tv
You have already diagnosed the problem,the remote receiver on the tv is bad,is rare but it happens but before you call for help try unpluging the tv from the wall for 10 minutes and then plug it back in and try it,sometimes this takes care of the problem,if that does not do it you will need the help of a servicer ,your remotes are working but the receiver is not processing the information.If you are familiar with tv service it should be easy to locate the receiver,sometimes is soldered to the chassis and sometimes is part of the push button assembly and conected to the chassis by wires,if is part of the push button is easier to replace,if you are not too familiar with tv service be safe and ask for help.
Oct 11, 2006 | Emerson EWF2703 27" TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
