Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
96, polaris 600 xlt # 3 no fire
Runs on 2, seems like #3 is blowing back, lots of compression, lots of spark
The problem was contaminated pump/fuel. Disassembled carbs and pump, inspected and cleaned, engine runs like new. Thank you
Posted on Feb 20, 2009
I have a 2016 Polaris sportsman 570 she's got a fuel pump tries starting her she will keep winding over but won't start any help would be nice
Make sure the kill switch is in the run position.
AN engine need three things to run:
Compression
Timed spark
Fuel
now.....
1*. Check the spark plug to make sure it is firing.. remove the spark plug.. make sure you have metal to metal contact and then turn the engine over.. (this might be a two man job).. the spark plug should have a nice big blue white spark,,(some electronic's will have a weak orange and still fire fine!)
2. Make sure you have gas in the tank and (going into the carb/FI)... (have to ask-actually have had 3 bikes in my career come in complaining -won't start...!! Add gas and they ran.. WOW!.. never charged any of them....the embarrassment on their face was payment enough!)
3*. While the spark plug is out... place your finger over the spark plug hole firmly .. keep the spark plug cap away from your hand..turn the engine over and see if it will blow your finger off..(it should blow it off the hole easily).
If any one of these three are not nearly perfect.. you have an issue!!
Check these and repost with the results...
Dec 17, 2016 | Polaris ATV
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Jan 04, 2016 | Cars & Trucks
I have a 1995 polaris 600 triple it fires but does not want to keep running seems like not getting gas it will fire on full choke off it wont even fire
CHECK THE COMPRESSION OF THE ENGINE, IF IT IS AT ABOUT 120PSI AND DOES NOT HAVE A DIFFERENCE BETWEEN CYLINDERS OF 15% THAN CHECK YOUR FUEL PUMP. YOU DO THIS BY REMOVING THE SPARK PLUGS AND FUEL LINES TO YOUR CARBS AND PULLING IT OVER. IF FUEL COMES OUT OF YOUR LINES THAN THE FUEL PUMP IS GOOD. THAN I WOULD CHECK YOUR CRANK SEALS FOR LEAKING
Dec 24, 2010 | Polaris New Genuine Polaris Snowmobile...
Polaris xlt 1994 hey i start up me sled let it warm up then i push on the gas and it wants to die out solution??
I have a 1996 polaris xlt 600. I changed the coils, spark plugs, cdi box, put fresh gas, and did a compression check on motor witch read 98 across the board. I also rebuilt the carbs and they were tuned. My problem with this sled is when it gets warmed up the motor dogs out. could it be the water pump making this happen?
Nov 26, 2010 | Sport & Outdoor - Others
96 Xlt Polaris Blew two pistons on pto side
I would richen the sled up one or two jet sizes.
Feb 05, 2010 | Polaris New Genuine Polaris Snowmobile...
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
803 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
Bill Boyd
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
