Abnormal shutdown frequent abnormal shutdow  to my desktop..i changed my UPS and ''SMPS'' but still abnormal shutdowns..now wt to do????
    Problem Solver:
  • 12 Answers
Ok, we are presenting a corrupted window and you reformat your Pc.
Back up you software and any other applicaiton.
1 Put you windows disk in and just after the logo appear depress f9 and answer yes to boot from cd. Follow the onscreen instructions to format hard disk and install windows/
Posted on Jul 26, 2009
No power to hp envy
I suggest you step by step follow check it your Desktop issue.
A> All power plug proper connect or not, if possible change another port.
B> Have your ups get power or not, If ups on then nest step follow.
C> Check it SMPS on or off position. If your power ok and come to smps or smps not start then you SMPS damage position, you check it smps ok conduction or not..
Checking method:
SMPS more wire available you see it one more bulk wire available and black wire and green wire cross check, if not start smps then damge. But my friend if you smps ok or your are wrong wire attach then may be your smps damage. So better contact good Computer Hardware Technician.
Thanks.
Computer Support
Feb 19, 2014 | HP ENVY 23-d065 TouchSmart All-in-One...
My desktop PC with Intel DH61WW mother board, Intel i 3 processor, 4 GB DDR3 RAM, Windows 7 OS Intel HD Graphic S/W has auto restart problem while shutdown is attempted. The UPS power is to be switched...
Disconnect all peripherals, except keyboard, mouse and monitor. Try to start the machine in safe mode and if it comes up okay, then try to restart it into normal windows. If the problem continues, remove all but one stick of ram, and try again. if it happens again, change out the stick of ram with one of the other ones. IF this fails, and the problem still exists, try to boot from a usb drive. If it boots normally then you may have a problem in windows, and that may need a re-install.
Sep 29, 2013 | Computers & Internet
Powering down
your not very clear but here is what I'm assuming your saying.
Pins 5 & 6 - Any-Mode Shutdown
1. Pin 6 of the 9-pin communication connector is used for "Any-Mode Shutdown"
of the UPS output. This control input may be used in special applications
to disable the UPS output power-both Inverter and Bypass.
2. The Options tab allows the behavior of the Any-Mode Shutdown feature to
be modified. When the program opens, or the REFRESH button is pressed,
the UPS setting is read by the configuration program and displayed.
Auto-Enable Output
Pin 6 Logic
If version 1.6 (or later) is used with an earlier Liebert GXT2U model (with an
earlier UPS firmware version), the Any-Mode Shutdown features cannot be
changed.
If the configuration program is used with an earlier UPS model (with an
earlier UPS firmware version) that does not support the modification of these
settings, the Options tab will display a reminder of the factory default
settings. These cannot be changed.
! WARNING
Note that when this option is selected and the UPS output is
disabled using Pin 6, the UPS output can turn on automatically
and without warning if the Pin 6 connection is changed.
! WARNING
DO NOT CHANGE THIS OPTION from the factory default
setting unless you are ready to install a normally-closed
connection between Pins 5 & 6. This connection must be
maintained to use the UPS or to use the configuration program
again, including the ability to change the UPS setting back to the
default setting using the configuration
Sep 05, 2011 | Liebert GXT2-10000R230 (GXT2-10000R230)...
Computer suddenly shut down and won't restart
This type of shutdown problem occurs mainly due to following few reasons, 1) SMPS problem 2) RAM failure 3) Over heated mother board chip(s) or seldom over heated CPU 4) Virus or worm problem or OS problem. 5) Over heated power cords
Do the following steps one by one (to detect the exact source of problem) First replace the CMOS battery, change SMPS, check power cord, run the PC directly (without UPS), remove the data cable from hdd. if it runs well then set the data cable with hdd, if it does not work then definitely there is mother board/cpu problem. And if it creates same problem after fitting the data cable - change the hdd or format hdd and reinstall os. your problem would be solved.
Jun 05, 2010 | Gateway GT5465E Refurbished Intel Desktop...
Compaq presario v5000 wont turn on
first of all you take a tester and then pullout the wire in S.M.P.S and turn on the U.P.S then put tester on the pin, if the tester glows then the power is coming to SMPS but then the problem could be in SMPS or your motherboard
if the tester does not glows then the problem could be in your UPS surely
Mar 26, 2010 | Compaq Computers & Internet
Sudden Shutdown of PC
This can be on your operating system or either the fan of the processor is bad. You just need to check both of that out.
May 25, 2009 | E-Machines (T2824) PC Desktop
Cannot shutdow
press the reset button to shut it down
after restarting the computer defragment the disk.
Mar 26, 2009 | Intel Computers & Internet
Desktop computer continously shutdown byitself
Am guessing it could be soemthing to do with the SMPS. how is that ? Is it working well ?
Feb 17, 2009 | NEC Versa VX Notebook
Computers & Internet Logo
David Payne
David Payne
