Home | Panasonic | DVD-S47 DVD Player | DVD recorders
Panasonic DVD-S47 DVD Player
Problem for Panasonic DVD-S47 DVD Player
DVD recorders
By man1 - usenet poster
Anyone use one? Just got one for Christmas, a DVD-R/-RW / VCR unit.
It's pretty nice, but I get some zero check errors when I tried to play
the disc I made, a DVD-R, back on my laptop. I found that gmplayer
works the best. This is what I got when I try to play the disc with
gxine, which refuses to play it:
*** libdvdread: CHECK_VALUE failed in nav_read.c:356 ***
*** for dsi-
*** for dsi-
Must be a slight quirk in the player. (g)mplayer gives similar errors,
but succeeds in playing the disc, probably because it isn't linked to
libdvdcss. I'll do some further debugging to see how I can relax the
zero-check feature in libdvdcss. Ogle had the same "problem". I
probably would have better luck with a better recorder, but I'm not
unhappy with it so far.
Solution #1
posted on Aug 01, 2007
Not Rated)
pandamama
Rank: Apprentice
Rating: 0%, 0 votes
Hmm... Did you finalize the disc after you were done recording on it?
The minus format DVD's need to finalized before you can play them in any
players. Could you play the DVD's on the PC with mplayer, xine, or the
like?
Well, the discs are DVD-R, so they use the DVD-VR format as you pointed
out above, which probably differs slightly from the standard PC DVD
filesystem. I think that's the problem.
Was this helpful?
Yes
No
Solution #2
Not Rated)
Rachel007
Rank: Apprentice
Rating: 0%, 0 votes
I have two DVD players, an early Pioneer DV-505 and a new Panasonic DVD-S47
and a Toshiba DR-1 DVD recorder. The Panasonic player has no problems with
any disc whether DVD-RAM/-R/-RW recorded on the Toshiba, but the older
Pioneer player can't play any of the -R/-RW discs at all. Strangely though,
if I do a direct disc copy on the PC using K3b, the copy done on the PC
plays perfectly in the Pioneer. I did read somewhere that older players
can't handle writeable media that well.
Was this helpful?
Yes
No
Solution #3
Not Rated)
Brad
Rank: Apprentice
Rating: 0%, 0 votes
This appears to be a common compatability problem with standalone DVD
Recorders which is not unique to Linux players but also affects many
standalone players. It appears to be caused by the use of the DVD-VR and
DVD+VR formats which use a filesystem that's modified slightly from the
standard used for pressed or PC-written media.
I have 2 players and 1 recorder and so far no disc I've recorded has been
playable by either of the standalone players without ripping them on the PC
and reburning even though using same media on both standalone and PC
recorders.
However so far I've had no problems playing them on Linux (I only have the
DVD Burner and no separate reader, is your laptop's drive a reader or a
burner) so maybe it's a combination of format, player and drive that's
causing your problem?
Was this helpful?
Yes
No
Solution #4
Not Rated)
Ross
Rank: Apprentice
Rating: 0%, 0 votes
I tried it under both Gentoo Linux and FreeBSD, with duplicate results.
It's a Sylvania unit, no model #, unfortunately. It's just a dual
VCR/ DVD-R/-RW unit. I'll try vobcopy as Peter suggested. It's one of
those VCR-type DVD recorders, BTW, not the digital ones you hook up to a
computer. Forgot to mention that. ;-(
Was this helpful?
Yes
No
Solution #5
Not Rated)
Cato
Rank: Apprentice
Rating: 0%, 0 votes
I would suggest trying it under Windows and see what happens.
Might be a defective unit.
Might be defective Linux/freebsd.
Was this helpful?
Yes
No
Solution #6
Not Rated)
Bray
Rank: Apprentice
Rating: 0%, 0 votes
begin Donn Miller wrote:
Yep, that is definitivly a firmware bug in the recorder.
Just two days ago some friend of mine came along with a DVD-recorder which
exhibited similar quirks. Luckily there was a patched firmware available
try "vobcopy" and see what output you get
Who the fuck is General Failure, and why is he reading my harddisk?
Was this helpful?
Yes
No
Popular Solutions for Panasonic DVD-S47 DVD Player
Questions and Unsolved Problems for Panasonic DVD-S47 DVD Player
Do you recommend Panasonic DVD-S47 DVD Player?
Answer
Answer
I subcribe to netflix and the dvds I received I am getting a check disc error. I can play other DVDs... (More)
Answer
I have had this model converted to be all-region Bought some BBC DVDs that were Region 1 (US market)... (More)
Answer
I bought the above DVD recorder 9 months ago - the idea was to keep ahead of the demise of VCRs.... (More)
Answer
Hi everybody, I have a s47 here in Brazil. Well, Panasonic don't have any assistence for this... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic DVD-S47 DVD Player:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
