Question about Philips Televison & Video
Regarding a Magnavox VCR Model # VR9321at22
Need to know how to change the clock setting so it will accept the date for 2009. It won't go beyond 2008.
It ask for month __/ day __ year __ -- but when you try to enter 09 it comes up with 0? and won't finish the screen
It will accept 08 but not 09.
Can you help us?
Used the year 1998 as it started on the same day as 2009 and that way I could set clock and date and worked out for me anyway.
Posted on Feb 20, 2009
I purchased a rca 4 in 1 rcr804br remote control for my Magnavox vcr/dvd player and programed the remote to the vcr and then I went to menu to try and set clock and the date and I get no response I guess I...
Your RCA universal remote control may not be able to perform all functions of your Magnavox player. In extreme cases, you may only be able to control on-off. A Philips universal remote control might be a better choice.
Jul 03, 2017 | Audio Players & Recorders
Svl-r1000 year 2008
You have really solved your own question, the unit does not have in the microprocessor the means to go past a certain date.
Dec 20, 2012 | Sony SLV-R1000 S-VHS VCR
Purchased in 1996. The date setting does not extend beyond 2010
No only in service can if it posible to reprogramed the EPROM.
Mar 11, 2010 | Televison & Video
Can no set date on VCR past 2008
dig around for old calendars or maybe the internet. compare dates. like for example. (my birhtay) july 12 in 1998 was a sunday. in 2009 july 12 was also a sunday. so u know that all dates in 2009 will line up with 1998. so in setting the vcr, make like its 98.
May 03, 2009 | Televison & Video
VCR Time Setting
Set your VCR to either 1987 or 1998. The dates are the same.
Jan 04, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
VCR will not go to date 2009
I wish you luck on your search for an answer, but vcr's are programmed for a possible life expectancy.  So ur vcr was expecting to be in a landfill by january 2009 and according to its programming there is not a 2009.  Combo units at walmart are realativly cheap now a days I would recommend picking up a new one.
Jan 03, 2009 | Electronics - Others
Magnavox VCR U095 39760450-can not put in 2009 YR to record
I called Magavox and Matt told me they had no information for my very very old vcr. He suggested that I trick the machine and use a date similar to the current calendar. For instance, today is Monday, January 5th. I went back to 2004 and found the same day and date. I programmed my vcr for 30 minutes to test it out and it worked. If you can't beat it, join it. Hope your vcr works too. Happy new year!
Ilene
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Sony VCR date only goes up 2006
Goggle year with same dates as the year you want. It'll show up.
For example if you can't get 2009, then you can set it to 1998. Same starting day, and all other dates will be identical.
Nov 12, 2008 | Televison & Video
Phillps vcr/dvd player
I can't get the TV Stations to come through after we hooked it up the model number is DVP3345V/17
May 07, 2008 | Philips Magnavox DVD/VCR Dual Player
Setting date and time on a Mitsubishi VCR
My Solution for Mitsubishi HS-U500 VCR setting the date for 2008 and beyond:
I had same problem with this old unit as everyone else has.  Since the year really doesn't matter (except maybe when you're setting to tape near a new year), here's how to get the day and dates correct:
On the remote, push Menu button, then select "First time setup", then select "Set the Clock", then select the month.  Now, start adjusting the YEAR and watch how the "days" change with the years.  Adjust the years so that the "Day" (Monday, Tuesday, etc.) matches the date (1,2, 22, 23, 28, etc.) in the month.  Then cycle thru the rest of the items and get out by hitting menu button again.
That's it!  That's my quicky solution.  Caveat: This may not be permanent with leap years and the like, so you may need to check it from time to time to make sure the days match up with the dates.  But you can do this when you go to set up for timed taping.  Hope that "FIXes" it for "Ya"!
Jan 22, 2008 | Mitsubishi HS-U595 VHS VCR
Televison & Video Logo
75 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
