Question about PIONEERPOS StealthTouch-M5 15 Inch All-in-One Touchcomputer PC Notebook
Will not let me used the calabration key is grayed out
I need to calibrate the screen but when I got to the program I'm unablie to access the keys either by touch or by using a mouse.I need the touch not the mouse as this is in a fast food restaurant,Terminal is 2 months old.
tks
Eleanor
All In One Business
506-452-2787
2005 Chevy Malibu Lt v6 3.5, has anti theftwont go off, after ignition cylinder change
Did you change key also ? does it have transponder chip in the head of the key ? Needs to be programmed . You change what ? Ignition lock cylinder an key ?
Important: When replacing either the vehicle keys, PCM, or TDM and the 10-Minute Relearn Procedure is used, ensure that the appropriate calibration is selected for the replacement component on the calibration selection screen of the service programming system. The appropriate calibrations for specific vehicle theft deterrent (VTD) system components are described below.
• When preparing a TDM for replacement, the Prepare Module For TDM Setup Procedure calibration is required. This allows the retrieval of required information from the TDM prior to its replacement.
• When learning vehicle keys and the 10-Minute Relearn Procedure is used, the Vehicle Theft Deterrent Learn For Learning Replacement Keys calibration is required. This clears all previously learned keys from the TDM and enables the TDM to learn new vehicle keys. For learning additional vehicle keys, refer to Adding Keys .
• When replacing a TDM or ECM and the 10-Minute Relearn Procedure is used, the VTD Learn for Powertrain calibration is required. This clears the previously learned fuel continue password in the ECM and enables the ECM to learn the fuel continue password of the new TDM.
Important: When replacing a TDM with a GM SPO Replacement Part, insure the Setup a New TDM procedure is performed prior to the 10-Minute Relearn Procedure.
Connect a scan tool to the vehicle.
Turn ON the ignition, with the engine OFF.
Ensure that all power consuming devices are turned OFF on the vehicle.
With a scan tool, select Request Info. under Service Programming System and follow the scan tool on-screen instructions.
Disconnect the scan tool from the vehicle and connect the scan tool to a Techline Terminal with the current Service Programming System (SPS) software.
On the Techline Terminal, select Service Programming System and follow the Techline Terminal on-screen instructions. Ensure the correct programming procedure is selected based on the component being replaced or programmed. See Important above.
Disconnect the scan tool from the Techline Terminal and re-connect the scan tool to the vehicle.
With a master vehicle key, turn ON the ignition, with the engine OFF.
With a scan tool, select Program ECU under Service Programming System.
At this point the scan tool must remain connected for the duration of the 10-Minute Relearn Procedure.
Jun 13, 2017 | Cars & Trucks
Why aren't o i u keys working?
Try laying down a piece of paper, then carefully flip the laptop screen side down and tap gently along the bottom of the laptop with a plastic utensil to dislodge food debris then make sure there is jammed under the keys....if that doesn't resolve your problem you have the option of using Windows On-screen Keyboard by selecting Start Menu/Programs/Ease of Access when the keyboard pops up on the screen you can now use your mouse to type whenever you have an empty text box, Look for the Options Key located on the Bottom Right if you'd like to add a numeric keypad as well, just be sure to pin it to your task bar...last but not least, you can invest in a wireless usb keyboard and voila! problem solved Best of Luck!
Jan 07, 2016 | HP 2000-369WM AMD E-450 DC 1.65G4GB 320GB...
Where is pc settings/ calabrate located in lenovo c260
From page 21 of the user manual, "The monitor is touch-sensitive thanks to its touch-sensitive screen. A touch screen is an input device just like a mouse or a keyboard, and the user's fingers transmit position information via the touch screen to the computer. With this technology, you only need to touch the pictures or words on the computer display lightly with your finger, and the computer will react. Touch Screen Calibration Prior to first use or whenever the touch screen reacts in a different place where you are touching it, start the calibration program. The procedure is as follows: 1. In Control Panel, select "Hardware and Sound". 2. In "Hardware and Sound" window, select "Tablet PC Settings". 3. In "Tablet PC Settings" dialogue, click "Calibrate" button. User Gesture Instructions for the Touch screen The Touch screen supports single touch and rotational movements, enlargement and reduction multi-touch operations, and the user can transmit position information to the computer via touch. The touch screen uses a very low pressure movement recognition method, which only needs the finger to move lightly on the computer display screen or make a simple hand gesture to be detected by the main computer processor. 16 User Guide 31506537 C260 UG V1.0 (Win8.1)(EN)(R).indb 16 2013-12-6 11:54:06
Nov 30, 2014 | Lenovo C260 Touch 19.5 Pent 4GB 500GB
How do I recalibrate scale on Robinair 34134Z
Robinair Model-34700Z scal calibration follow as bellow:
Press main menu then press up or down arrow till scree appear ''CHANGE DEFAULT'' then press 5454 from the keypad & then YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & then press YES key. now follow the on screen text. Once you calibrate scale then press STOP key to exit.
NOTE: You should have 9KG/20LBS of weight for scale calibration. Do not change ''TANK TARE'' or any other setting it must be on factory setup.
Hope this will help you to solve the problem & if my solution is useful to you please vote for it
Apr 04, 2011 | Robinair Cool Tech 34700Z Recovery,...
During tank refilling
With switch on press YES/ENTER & STOP/NO key at the same time and watch the screen to come back as normal condition. If it is the same then you have to replace SCALE assy.
After replacing SCALE assy.you must CALIBRATE the new scal before use the machine. For calibration follow as bellow:
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key. now follow the on screen text.
NOTE:you should have 9KG/20LBS of weight for scale calibra
Hope this will solve your problem & if my solution is useful to you please vote for it.
Jul 15, 2010 | Robinair Cool Tech 34700Z Recovery,...
How do you calibrate the scales on A robinar 34800
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 (old typ machine 8787 without F1 botton on key pad) & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen help text.NOTE:you should have 9KG/20LBS of weight for scale calibration.
Hope this will solve you.
May 19, 2010 | Robinair Cool Tech 34700Z Recovery,...
Hi i need to know how to calibrate robinair 347000z mechine
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen help text.Hope this will solve your problem.
May 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
I HAVE AN ERROR CODE
To solve use this steps carefully.. Follow these steps.....
  • On the printer's front panel, press the ENTER key.
  • Using the Arrow keys, scroll to Utilities , and press ENTER.
  • Press the ENTER key and the Up Arrow key simultaneously (allows access to the Service Test submenu).
  • Using the Arrow keys, scroll to Bail Calib , and press ENTER.
  • The bail will rise.
  • Press the Up Arrow key until the bail makes a slight falling motion (approximately 1/4 inch). Each time the key is pressed, the bail will rise slightly.
  • When the bail makes the falling motion, press ENTER to write the calibration value to the EEROM. This is the correct up position for the bail.
  • When the message SUCCESS CALIBRATION press ENTER appears, press ENTER.
  • Press the PREVIOUS key until the main front panel screen appears.
  • Turn the printer off, then on to store the calibration value in the EEROM.
  • Turn the printer on and load media
Thanks
Aug 14, 2009 | HP DesignJet 450c InkJet Printer
Frigidaire range model #fgfl67dcf needs to be calabrated, too hot for setting
OVEN CALIBRATION Set the electronic oven control for normal baking at 350°F. Obtain an average oven temperature after a minimum of 5 cycles. Press CANCEL or CLEAR to end bake mode. TEMPERATURE ADJUSTMENT 1. Set EOC to bake at 550°F. 2. Within 5 seconds of setting 550°F, press and hold the bake pad for approximately 15 seconds until a single beep is heard (longer may cause F11 shorted keypad alarm). 3. Calibration offset should appear in the display. 4. Use the slew keys to adjust the oven temperature up or down 35°F in 5°F increments. 5. Once the desired (-35° to 35°) offset has been applied, press CANCEL or CLEAR. Note: Changing calibration affects both Speed Bake and normal bake modes. The adjustments made will not change the self-cleaning temperature.
Jun 18, 2009 | Kitchen Ranges
My nintendo dslite will not calabrate
maybe the touch screen is defective. did you drop the DS somewhere?
if you do the calibration REALLY fast, it may be able to correct the problem
May 15, 2009 | Nintendo DS Lite Console
PIONEERPOS StealthTouch-M5 15 Inch All-in-One Touchcomputer  PC Notebook Logo
63 people viewed this question
Top PIONEERPOS Computers & Internet Experts
David Payne
David Payne
Are you a PIONEERPOS Computer and Internet Expert? Answer questions, earn points and help others
