Question about JVC AV-27530 27" TV
Tv shutting off timer light blinking
Have a jvc 27" tv, 8 yrs old. Started shurring off yesterday, but could turn back on. Shut off last night, but could not turn back on. Red light blinks on front panel, and sounds like timer ticking. any ideas Please help me, I have a JVC TV model AV-27530 with a RM-C203 that has turned on the light "ON TIMER" on the front panel. What time is scheduled, I don't know but I can't turn on my tv. How can I cancel this function with the TV off?
  • 1 more comment
  • p2cat Mar 12, 2009
    tv won't turn on - timer light blinking
  • benny1520 Mar 29, 2009
    I am experiencing the same problems
    my tv won't turn back on. The light in the front is blinking red and says timer. When I unplug TV and then plug back in the TV starts to come back on then shute down again.
  • 89 Answers
The problem you describe is not really related to a timer function being set. The unit is in shutdown and the light is blinkng to let you know there is a problem.
There are several possible causes. the most common is a failure in the vertical deflection circuit due to a bad vertical IC and possibly a capacitor, zener diode and resistor.
Posted on Mar 13, 2009
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
My 27" Hitachi TV is about 14-15 yrs. Last night
could be alot of things but it comes on by hitting it makes me think either a bad relay or solder connection on the pcb board
Jan 29, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
JVC TV Sleeping
Indicates a power supply failure, needs a few filters replaced expect to pay $100-150 Julio milleniumtvsvc@gmail.com
Jul 23, 2009 | JVC AV-27320 27" TV
TV Turning on and off by its self
You have problems with a condenser that allow the power supply to maintan an acceptable level of voltage in order to keep the TV on. take to a tech to be fixed. unfortunatelly, this problem needs a tech to take measures in the circuitry to find the component that causes the problem.
Nov 06, 2008 | Philips Magnavox TS3260C 32" TV
Your TV is in the protection mode. First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner.Feel free to ask and post whatever the result of your troubleshooting..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 30, 2008 | JVC AV-27D303 27" TV
JVC 27230
Hi, last night I tunred my tv off and when I went to turn it on in the moring, the timer light keeps flashing. I have no reason to set the timer. I've tried to un-plug it and plug it back in but it keeps turning off. What can I do? Thanks
Mar 29, 2008 | JVC AV-27230 27" TV
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
Power light blinks, but tv won't come on
I have the 52" version of the Viera model. Mine went out last night and started blinking twice over and over again. I suspected overheating so i just went to bed and tried it in the morning with no luck. Then I unplugged it for more than ten minutes and plugged it back in and everything worked fine. I hope this helps.
Jan 08, 2008 | Panasonic Televison & Video
JVC AV-27820 27" TV
probably some cold solder joints. take your time and check over whole circuit board and re-solder what looks bad.
Jun 10, 2006 | JVC AV-27820 27" TV
JVC AV-27530 27" TV Logo
687 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
