Question about SanDisk Sansa Fuze MP3 Player
Sticky thumb wheel
Every once in a while if i use it or not the thumb wheel wil get stuck
  • Mikale Daniel
    Mikale Daniel Feb 20, 2009
    you can also blow into the memory card slot with some compressed air that works good
  • 1,011 Answers
if u can open the casing. just open it and remove the dust that is inside it and causing stuckness.
Posted on Feb 19, 2009
  • SALMAN NASEER Feb 21, 2009
    you can. as i did many a times..
    thanks for rating
I have the same problem
the reason for that is that when its worm the wheel is getting thicker
put it 5 minutes in AC and see it will move very fast
Posted on Feb 09, 2010
Why won't correction tape advance? Works for a few words then gets stuck.
There are 2 types of correction tapes, a sticky type and a non sticky type. The sticky type is for the IBM selectric series. If you have print wheel, you need the non sticky type. Touch the tape and see if it sticks to your finger, if it does, you have the wrong tape.
Jun 19, 2014 | IBM Q27 Lexmark 6781-025 Typewriter...
Back wheel sticking
Its either a sticky caliper on the rear or its in gear .is it stuck all the time or will it move a few feet and then stop quick ? If its stuck all the time id suggest tapping the caliper face with a soft mallet to loosen the caliper pistons a bit . If its moving a bit then stopping then check its in neutral
Mar 13, 2014 | 2011 Piaggio Zip 50
Dvd is stuck in my ACER laptop how can I get it out
The Acer 5610 has an emergency eject hole to the right of the eject button on the right side of the computer. Find a paperclip and unfold it (or small allan wrench), push the end of the paper clip into the hole until you feel pressure. Press firmly and the optical disc tray should come slightly out of the machine. Grab and pull the tray out (gently). This should work even without power to the drive on any machine tray optical drive, if the tray mechanism is undamaged.
For a slot-loading optical drive, it's a bit trickier. You can try sliding another object into the slot and using it to pry or lift the stuck disc. The safest option is to use another optical disc or credit card sized item and double-sided sticky tape. Put a piece of the tape on the item and then remove the paper from the other side of the sticky tape. Slide the item into the drive with the sticky tape towards the stuck disc (down for most computers). Once far enough into the drive, lower your item and press the tape firmly onto the stuck disc. Lift up and try to pull the stuck disc up and out of the drive.
I hope this helps.
Oct 26, 2011 | Acer Aspire 5610 Notebook
Clicking noise coming from front driver side wheel/tire as car is in motion. Sounds almost like there is nail/screw stuck in the tire. Upon inspection, i didnt find anything stuck in the tire. What is this...
Wheel bearing is bad and will need to be replaced. This is a somewhat easy job if you are comfortable with mechanics, but you will need to remove a lot of parts to get at the bearing. You can get a new bearing at your local auto parts store. Please rate
May 31, 2010 | 2006 Nissan Maxima
I have hp surestore DLT1e drive. Tape cartridge stuck!
For that you can try to press and hold the eject buttonfor 30 seconds if the tape doesn't came out then reflash the drive firmware revision.
After all that is the issue persists you can try to:
manually remove the tape by removing the top cover
Locate recessed thumb wheel
Rotate thumb wheel counter-clockwise until you feel resistance. Wheel may spring back when you release it. This is OK.
Locate hole in bottom of drive. Insert #10 Torx driver and rotate clockwise until tape ejects. If there is a lot of tape on the take up reel, this could take some time.
Rotate thumb wheel clockwise to eject the tape.
Apr 08, 2010 | HP Computers & Internet
I held down the 'shift' key too long and now the keyboard restricts the backspace key to one space and wil not alow me to type the same character twice. Se what i am talking about?
Sticky keys I hate that too
hit shift 5 times it will bring up a box
ok to keep sticky keys
cancel to turn off sticky keys
hit cancel.
Oct 27, 2009 | Gateway Profile 4 All In One (MPN...
Key stuck in the ignition. Position indicator
try turning the wheel to the right/left while turning the key in the ignition. You have to apply some force. Your car is probably outliving its road life.
Cheers & Best Wishes
Oct 19, 2009 | 1994 Chrysler LHS
Pentax me super can not advance the film advance
if the re-wind button is not stuck in, then the tab on the advance shaft is broken off. this small piece of metal will jamb the gears eventually.
take or send your camera to a repair shop for a cost estimate before repair as there are no new parts available for this model .
Jun 08, 2009 | Pentax ME Super 35mm SLR Camera
Selector switch stuck in 4lo
pull 4wd fuse inside fuse panel and atc fuse from underhood fuse center, truck wil go back to 2wd,check control box behind pass.side kick panel ,elect. connector at box,full of corrosion will cause weird 4x4 problems!
Mar 27, 2009 | Chevrolet Blazer Cars & Trucks
1997 Lumina in lock down mode
make sure the car is in park or the key wil not come out or start also try to turn the key at the same time turn the wheel to the left
Jan 01, 2009 | 1997 Chevrolet Lumina
SanDisk Sansa Fuze MP3 Player Logo
766 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
