Question about GE Nautilus 24" Built-in Dishwasher
I can't reatach top( glasses) rack I can't figure out where the clips go into.
  • 170 Answers
The clips attach to the upper tray clip the little roller assemblies (all one piece) onto the bottom of the tray...along the lowest part of the tray...when clipped in place...(I'm not sure but there will be an even # on both sides) you then put the tray back into place and it will roll inside or along a silver track...which may have a slot cut out where the rollers drop down into and then the tray is pushed back...into place and the last roller drops into the slot and the tray will extend along with the arm that the rack is sitting in/on.
I hope this helps...any more ??...just ask....good luck...thanks for rating my effort...The Fang.
Posted on Apr 07, 2009
How to put top back on miele w1926
1 Remove stacking kit from top of unit.
2 Reatach the two plastic clips to the back of washer.
3 engage the two slots on the washer top into the clips , pull forward drop lid down on top of washer then secure with two screws on either side of lid.
Dec 29, 2013 | Miele W1926A Front Load Washer
The top rack does not sweem to get water spay. I put a glass upright on top rack and it did not fill up. The bottom dishes are getting clean could it be the circulating pump
There is a plastic cone on the back, bottom of the top rack. The cone must push into the water tube in the back wall otherwise noo water will get to the top. Make sure the clips holding the cone in place are positioned correctly.
Jul 08, 2011 | KitchenAid Dishwashers
I heard a snap or crack in Passengers sid door when using electric window the operating mech cable will move up and down window does not move anyone know about a window clip to reatach Deville I got it...
you need a new mechanism ,on the cable mechanism is a either a support bracket or a round pin type that goes through the glass ,to be honest i have never seen caddy except on the TV but most vehicles i have repaired have a plastic support that takes the window with a clamp type device ,or a plastic douel that goes through the glass with a U shaped clip to hold it ,the answer is their if you look on the bottom of the glass but if its broke then its a complete window mechanism
Jul 30, 2010 | Cadillac DeVille Cars & Trucks
Always little crumbs in glasses on top rack
Cleaning screens is part of regular use of the dishwasher and how to should be included in the user guide. If you don't have one look for it on the internet by searching for user manual for your model number which can be usually found on the side of the door or frame where the door closes. Good luck.
Feb 13, 2018 | GE Nautilus 24" Built-in Dishwasher
Uninstall Sharper Image Tie Rack from clothing rod
The tie rack just clips on in the middle. the small piece on the top of the bar in the middle of the rack slides to the left to uninstall, to the right to install. on the bottom middle of the rack is a round piece that tightens to hold the rack level. loosen that piece first, that the top middle piece should slide to the left.
Dec 30, 2009 | Kitchen Appliances - Others
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
Top rack is not level. Glasses and cups roll forward
I assume that the bottom rack is level and the upper rack is not.
On the LG dishwashers, you can remove the upper rack by removing the little gray clip at the front of the rails. Each will fall off in your hands. You can then pull the basket out.
Place it on the floor and confirm that all wheels roll properly and all touch evenly. Resolve any problems on the rack via LG service parts.
Inspect the rails still inside the dishwasher, confirm that they are paralel and level.
Replace the upper basket carefully, making sure the wheels all slide into the rail evenly.
Please update me on what was done to finally resolve the problem.
Oct 12, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Replace front pasenger glass
it is a 1/4"rivet usualy have to use a big daddy rivet tool to reatach window to track be careful to pull tool toward you slightly when rivet is about to pop the glass may break if you dont to remove the rivet take a small punch & knock the center out of the rivet makes it easy to drill out.good luck from schleck
Jul 04, 2008 | 2002 Ford Taurus
Upper Rack
Contact Bosch and ask if there are any other rack configurations for this model. From memory I think there might be 1. I also remember that they made an insert to go into this particular top draw...check on that also Regards
Jul 13, 2007 | Bosch 23 in. SHU33A Built-In Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
114 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
