Question about Archos 605 WiFi Digital Media Player
My Archos 605 WiFi will not always switch my NTL (Samsung) set top box on to make a scheduled recording.It will however change it to the correct channel if the box is left switched on and make the recording.
I have partly solved the problem by leaving the box switched on (any channel) then when the programme is about to record Archos 606 WiFi will switch the cable box to the correct channel and record. It will not however turn the box off after recording this has to be done manually using the remote handset.
In the instruction manual for the Archos docking station there is a footnote saying that in very rare cases the On/Off function does not always work and I am wondering if the Samsung (NTL) Box is one of them. I cannot get a direct answer from Archos support team on this issue when I have sent numerous E-mails. According to the manual I am working on the correct code number for the Samsung (NTL) box.
Posted on Feb 25, 2009
My archos 605 gen 5 cannot connect to internect
Try:- Menu Settings Language and Region WiFi Region.....set to "EUROPE" Followed by: Menu WiFi Status WIFi ...important that pasword format corresponds to that of your WiFI system eg WEP or WPA. The type of format will dictate the length of code. Generally WPA can accept a longer code than WEP format although a short code can be used for either. If your Archos is set to WEP and your WiFi network set to WPA (or vice versa) the format conflict will not allow the correct password to recognised It should be possible to use the
Dec 30, 2009 | Archos 605 WiFi Digital Media Player
Copying Video from archos 605 wifi to computer
I think the Archos 605 has a 2gb file limit, so the only option would be to split the avi.
Search on Google for an avi splitter - there are some free ones out there.
May 06, 2009 | Archos 605 WiFi Digital Media Player
Can I pre record on the archos 605 wi fi 30gb
You have posed a very good question with a very complicated answer. There are two things you MUST have in order to do what you are asking:
1) Your "docking station" cannot be the Archos mini-dock, b/c the mini dock has inputs only. Your docking station must be the Archos DVR Station - Gen 5.
2) You have to have a digital cable box, FIOS, or digital satellite box.
You will be recording from your cable, satellite, or FIOS box instead of directly from your TV. Hook the red, white, and yellow cable from one of the red, white and yellow outputs of your cable/sat/FIOS box to the specialized adapter of the DVR Station (make sure your Archos 605 is properly docked inside). Here is a link to the connection guide if you don't have it:
http://www.archos.com/support/download/manuals/connection_guide_dvr_station_v1.1.pdf
Once the connection is set up, you must follow the exact directions printed on pp.11-15 of the DVR Station user manual - it will require downloading several pieces of software. My only reccomendation is that you make sure that the Archos 605 is fully charged before proceeding, b/c if it loses power during the process, you may ruin your mp3 player. Here is a link to the DVR Station user manual:
http://www.archos.com/support/download/manuals/english_user_manual_dvr_station_gen5_v3.pdf
If you have followed the instructions exactly, you will be able to schedule your recordings to your Archos 605.
There are two catches that I noticed with this player - 1 major and one not-so major:
1) Not-so major: Your subscription to the TV guide that enables you to schedule recordings will only be free for 1 year
2) Major: The DVR Station forces you to choose between an NTSC and a PAL format when choosing a TV standard for playback. PAL is only for Europe, so never select it under any circumstances. NTSC is shutting down on February 17, 2009 - in a little more than a month. After that time, you may not be able to display the recordings that you have made to your TV itself.
-Tha Mp3 Doctor
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
CAN I PRE RECORD PROGRAMMES ON THE 605 WI FI 30GB
Archos 605 Wifi w/ Archos DVR Station Gen 5
-Tha Mp3 Doctor
Archos DVR Station & 605 wifi PMP
Not sure if this will help you or not, but I have a 404 and was having issues with the scheduler changing the channels for me also. Then I realized that it is a infrared transmitter - the same frequency as a remote I realized what I was doing wrong - Your archos station must be facing the cable box that it is turning on. I had my archos on top of the cable box and it was not working - but when I turned the cable box and the archos station to face each other - so the signal can transfer - it worked just fine. Hope that helps!
Oct 22, 2008 | Archos 605 WiFi Digital Media Player
I cannot get my sons new Archos 605 to video from the tv. I feel like taking it back- what a waste of money!
I've had a similar problem. It finally started working though.....to a fashion.
I can now record the channel I am watching, but it does not record if the TV is switched off and I cannot get the scheduler to work at all.
When I first got mine 2 weeks ago, it would only record ITV, no matter what channel the TV was on.
Then on the 2nd day, it just seemed to kick in and whatever channel I put the TV on, the Archos displayed the corect channel.
Jul 28, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 wifi
I get it why people have to go around asking experts directly(your not the only one).
Can you tell me the connectors behind your television
Jun 01, 2008 | Archos 605 WiFi Digital Media Player
DVR to Archos
That's what the DVR does. All you need to do is play whatever program you would like on your cablebox/DVR and hit record on your archos. It will record it like any program.
DamPinou
Mar 25, 2008 | Archos 605 WiFi Digital Media Player
DOWNLOADING TV SCHEDULER
Mate Ive got the exact same problem ... If anyone out there knows how to fix this solution.. please help! thanks
Mar 17, 2008 | Archos 605 WiFi Digital Media Player
TV Scheduler not turning on Cable Box
I have the same problem and it won't change channels after the 1st program. I just leave the cable box on. This is not the best answer but it works for now.
Jan 17, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 WiFi Digital Media Player Logo
222 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
